Old 09-02-2017, 08:46 AM   #1583
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Tor View Post
Which temp was above normal?
I have the secondary o2 sensor corrections disabled. But still I would be surprised if that would have influence on AFR command, since it has it's own separate corrections.
Looking at my logs, the only other places I ever have 14.7 is during overrun. At the beginning of a pull, where you come from off throttle, I suppose it could be a logging delay?
Thanks for your replies.
Here is a log with the commanded AFR hitting 15.18 for a short amount of time then back in line with what's been set on the fueling tables as I start to increase throttle at the beginning of the pulls. It's intermittent, but happens more often after the engine has been warmed past normal operating temps. 15.18 afr does not exist on any table in my tunes. So, I automatically assume is some sort of malfunction.
http://datazap.me/u/solidone/z7-kc1i...3608-3918-3925
Not 100% sure why it happens.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Tor (09-02-2017)
Old 09-02-2017, 01:41 PM   #1584
phrosty
Originally Posted by chermo12 View Post
Tune: "v3.0 Stage 2 UEL 91-93"
You're beta testing Shiv's new tune, you should be giving him feedback.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
chermo12 (09-02-2017)
Old 09-02-2017, 06:35 PM   #1585
chermo12
chermo12's Avatar
Drives: 2013 SSM BRZ
That is way too much knock. With the catted header you may be way better off flashing a stg 1 tune and taking it from there. The AVCS settings (variable valve timing) may be more suitable since there is still a cat. It will probably make more power too.
-Yeah, it scares me. I'm not sure if something's up with the catted header I just installed or if it's too early to datalog so soon after flashing?? If things don't improve significantly, I'll try flashing back to Stage 1. (It does smell a bit funny. Is that due to running rich? or a possible leak?)
If you IAM was getting down to 03 on 91 then id avoid running 91 on that tune , maybe run the earlier less aggressive tunes.
On 94 it looks acceptable, still some knock and its running rich, but looks like log was fairly soon after flashing ?? as the ltft at mid upper rpm is still 0.
Caniadian fuel seems worse than USA fuels from logs ive seen.
Apparently husky 94 is good
-I'm assuming the 94 is helping (crickets sound has returned which confirms the the 94 fuel). Today, I was only able to do a 2nd gear pull, but the AdvMulti went up to 0.79 (from 0.65 last log) today.
-You're right, I've only driven 150+ km on this tune so far. How long should I be driving on a fresh flash before I should datalog more accurately?
-I still had 15% of Shell 91 left in the tank, but I filled up with Petro 94. I'll try to look for Husky 94 for my next fill up.
Here's my 2nd gear pull log:
http://datazap.me/u/fl4tbxr/sept-2-2...0?log=0&data=1
-Oh, I didn't realize they're still in beta. I thought they were done, but just not updated on the official OFT downloads page. I will email Shiv my logs and see if he can give my feedback. (I figured the forums would have a quicker response)
________________________________
instagram - @FL4TBXR
chermo12 is offline   Reply With Quote
Old 09-02-2017, 06:52 PM   #1586
steve99
Drives: FT86
Their is still some knock. If you could log FLKC instead of say coolant temp it will be easier to see knock.
Usually your ok after 150 km
Try doing two or three light throttle runs ( say arround 10% not critical but just light strwad throttle) from 2000 to 6500 or so. Second gear just let the rpm build slowly at light steady throttle. This should kep ecu in closed loop learning mode and speed up fuel trim learning, and also reset your iam to 1
chermo12 (09-03-2017)
Old 09-02-2017, 07:53 PM   #1587
Nobunnyhere.86
Drives: Scion FRS
http://www.datazap.me/u/nobunnyhere8...l?log=0&data=1
Still waiting on a reply from shiv been a while but I know he is busy.. Could someone let me know if this 3rd gear pull looks to be going lean and has some knocks in places they shouldn't ?
This is the BETA 3.0 stage 2+ 91 tune from Shiv. On my last tunes the MAF was not properly showing but shiv helped fix that issue with the new 3.0 , not much of a power or torque difference but definitely more efficiency feels with the tune..
Nobunnyhere.86 is offline   Reply With Quote
Old 09-02-2017, 08:19 PM   #1588
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's definitely not lean, it's richer than commanded for most of the pull.
It is pulling timing in a couple of places but noticably up top. Are you running the correct hardware for a 2+ tune as that typically occurs when there is a lack of VE (restriction) if it's not simply too advanced.
.: Stealth 86 :.
Kodename 47 DJ:
Nobunnyhere.86 (09-03-2017)
Old 09-02-2017, 10:26 PM   #1589
Nobunnyhere.86
Drives: Scion FRS
Good to know its not running lean, and may I ask what you mean by its pulling timing?? I'm not familiar with that part. And as far as I now Shiv told me that if I am running catless headers I need to run the 2+..
Right now my set up is Skunk 2 EL Catless headers, Stock OP, MXP catless front pipe, stock mid pipe with a axleback exhaust . My intake box is stock but I did cut and modify the inlet of it to allow more air that I saw be done on youtube (rookie mistake). Also running 91 premium gas from Techron Chevron.
Old 09-03-2017, 07:25 AM   #1590
Tor
Tor's Avatar
Drives: Toyota GT86
Maybe try reducing or zeroing CL to OL delay timers
But wouldn't it make sense that the point where it occurs is after it already switched to OL. I.e. I would assume Tactrix would still log the ECU as being in CL during the timers count down. If that is the case it would already be in OL as AFR command spikes up. Also, still, where does it get 14.7 from?
Interesting as it happens just after a transition to CL too in your log. So maybe you are right and it's a glitch. Or maybe something is some logic that we don't know about at play.
I'll keep an eye out for it in the future, but not think that much about it otherwise. If it reoccurs often on a level that it's a problem I'll try reducing the timers and see if it makes a difference.
I flashed my increased timing by the way and it soaked it up so well that I'm going to add more.
8th of 8 pulls back to back:
http://datazap.me/u/tor/tor-232-pull...zoom=3973-4080
Tor is offline   Reply With Quote
Old 09-03-2017, 11:40 AM   #1591
chermo12
chermo12's Avatar
Okay, so I added FLKC to my logs, drove 160km since the last reflash and disconnected the battery to reset the ECU. (IAM back to 1.00)
After the reset, it felt to be running a bit smoother at idle and noticed the IAM was steady at 1.00 for my entire drive today, which I was happy to see.
Here are 2 logs from today: (Did some 2nd gear slow pulls + a 3rd gear pull to redline)
Log 1: http://datazap.me/u/fl4tbxr/sept-3-2...0&data=1-12-13
Log 2: http://datazap.me/u/fl4tbxr/sept-3-2...0&data=1-12-13
Old 09-03-2017, 03:18 PM   #1592
solidONE
solidONE's Avatar
Nice! have you check how much power yielded from the changes?
Intent > Content
Old 09-03-2017, 03:56 PM   #1593
Tor
Tor's Avatar
Drives: Toyota GT86
I tried and it is thoroughly disappointing!
Okay, the difference is also not that big. I'm up at a max of 31.17 at load 1.2 @6000 rpm. You don't see that in the log as I have 1 deg Timing Compensation per Cylinder A+B throughout up to 6400 and thereafter increasing to max 3.16.
That and the rich mixture up top seems to let it accept that much timing
I suppose this will be okay for the track. Tried to simulate as much as I responsibly could on backroads too:
http://datazap.me/u/tor/tor-232?log=...zoom=3288-5406
And my usual autobahn pulls:
The 5th gear is difficult for it (it's uphill too), but still less than -2 FLKC. Notice in 6th as it accelerates from 5500 to 5600 (uphill, no more punch), it doesn't knock at all.
So that makes me want to try out this next on top of the other changes:
This is within 0.35 to 0.7 deg of E85 timing between 5200 to 6000 rpm at load 1.2!
I doubt this will be suitable for the track. But I want to see how far I can push it and have a 1 pull hero tune ready if I want to get it dynoed. Or maybe I will be surprised at it will work out, or I can maybe try to make changes to TCPC if it knocks.
With the extra-extra timing I will already extend the top area back to 6800 rpm. The MY17 stock tune seems to use this table a bit more actively than older:
Hopefully these changes should provide some actual messurable improvement.
Old 09-03-2017, 04:37 PM   #1594
Nobunnyhere.86
Drives: Scion FRS
if my car is pulling time on my pulls, how would I correct that?? also just out of curiosity are these OTS tunes maximized with the amount of power gains you can get out of your car?
Old 09-03-2017, 07:54 PM   #1595
steve99
Drives: FT86
I dont think anyone knows 100% how the ecu works down to these levels.
I just see a lot of wrx guys that alter these timers, just worth a try
What you are saying is correct, if ecu works the way you think
Tor (09-04-2017)
Old 09-04-2017, 02:25 PM   #1596
jpsimon
Drives: 2015 STi
Hey all as of 1:30pm EST (September 4th) for the next couple hours datazap is going to be down as I move everything over to AWS. So in the mean time go drink some beer and do some grilling.
Sorry for the inconvenience but there were some issues popping up on the server I had been using and needed to do this ASAP. Moving forward there shouldn't be any more downtime!!
Also just FYI i'm working on a Windows and OSX datazap app with some cool new features. So stay tuned!
2016 340i xDrive / 6MT / M Sport
www.datazap.me - free shareable interactive datalog viewer
jpsimon is offline   Reply With Quote
The Following User Says Thank You to jpsimon For This Useful Post:
trvth (09-08-2017)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
