Old 09-02-2017, 02:54 PM   #57
Somerandom18
Drives: 2017 manual BRZ
Some people have an issue with their car called forced induction. It destroys MPG hahaha.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 09-02-2017, 03:17 PM   #58
Originally Posted by PetrolioBenzina View Post
I suspect that some of the mileage figures posted here and other places are taken from the average mileage display from the car, and those numbers are mostly useless. Actual math at the pump is the only way to get real average MPG.
Mine is pretty simple:
(109,439 Miles) / (3,311.57 GAL-US) = 33.05 MPG Lifetime
The other way to approach it is not worry about it. I fully understand there are circumstances when it is an issue, but why even worry about it unless you have to? Drive the car, and switch to the Miles Per Grin standard.
I don't disagree with you, and I don't worry about it, just have the habit of tracking these things with my vehicles. I have been amazed at the mileage I've received from the FRS. I was going to be quite happy with anything in the mid 20s frankly.
Old 09-02-2017, 03:22 PM   #59
Originally Posted by -Willis-86touge View Post
If you are get 28+mpg then you either baby your car to much and probably drive on the highway all the time...
Yet I do neither of these unless you consider "highway" two lane backroads run at speed (or slightly above).
I'm not surprised by the wide range of mileage folks get, that's going to be true with any stock car. If you took any car on the market and handed out to the drivers having this discussion, we would most likely get the same spread, and I would wager it would be at almost the exact same ratios.
By the same token, if you took us all, but us in the car on a track, we would most likely all run out of fuel within a few minutes of each other. It's all very situational.
strat61caster (09-02-2017), why? (09-03-2017)
Old 09-02-2017, 03:48 PM   #60
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I track mine, too, it's just that I don't obsess (not saying you or others do) about it. It turns gas into fun, and worth every penny. I'm on the low end of the scale, and I consider anything over 25 to be good. I also see how low I can drive the MPG every now and then as well.
Low mileage is jut something I expect as a result of the way a drive most of the time. Hoping that the 86 OFT E85 tunes are released before winter, so I can really drop that MPG number.
PetrolioBenzina is offline   Reply With Quote
The Following 2 Users Say Thank You to PetrolioBenzina For This Useful Post:
Dadhawk (09-02-2017), strat61caster (09-02-2017)
Motor Trend the leftovers of best... Coaster Other Vehicles & General Automotive Discussions 0 01-24-2017 07:26 PM
Motor Trend Car of the Year... Dorb BRZ First-Gen (2012+) — General Topics 1 11-13-2012 07:33 AM
Motor Trend: FR-S first test Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 0 04-25-2012 12:53 AM
BRZ First Drive in June Motor Trend BMWDavid BRZ First-Gen (2012+) — General Topics 25 04-23-2012 09:02 PM
BRZ Motor Trend article terrypm BRZ First-Gen (2012+) — General Topics 4 03-28-2012 03:25 PM
