Old 02-21-2016, 09:58 PM   #57
scarfo
Drives: gts 86
There are a couple of kits running around in Aus, all used the app to tension the belt and none have snapped.
Even if it is the best method kraftwerks wouldnt tell you to do is as it would open up a can of worms.
I don't know the consumer laws in the states but 4 snapped belts, after installing the based off their tech support information, try and swing the refund.
scarfo is offline   Reply With Quote
Old 02-26-2016, 04:11 AM   #58
k_mono_FRS
k_mono_FRS's Avatar
Drives: 94 EG6 si, 97 DelSol si, 14 Monogra
I don't get it! Why not just DL the Gates app? It'll take all but 3 or so min to install on your phone. It doesn't matter what Kraftwerks says or recommend for belt tension specs. Weather, temperature and humidity affect belts differently based on your location. Its like installing the same performance parts your friend did and expect the same power. Who knows... it might just fix your headaches with this kit.
k_mono_FRS is offline   Reply With Quote
Old 02-26-2016, 08:27 AM   #59
outburst
Drives: Suburu BRZ Limited
I'm 10k into my one and only belt. Used the gates app because everything else in the instructions either felt loose or way too tight. 60Hz feels just right. Took about a month to finally completely settle.
I figured I'd share because there are plenty of horror stories about the belts, but I'm positive there is much more success than horror stories.
outburst is offline   Reply With Quote
Old 08-03-2016, 04:27 AM   #60
michaelneal9900
michaelneal9900's Avatar
Drives: 2013 Scion FRS
My car was supposed to be finished today, but when my mechanic started it after 10 minutes the belt snapped! I don't know the specifics on how much he tightened the belt, but we ordered a replacement and hopefully it goes better this time.
michaelneal9900 is offline   Reply With Quote
Old 08-03-2016, 09:21 PM   #61
vgi
Drives: frs
all mechanics are not created equal
vgi is offline   Reply With Quote
Old 08-03-2016, 11:03 PM   #62
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-04-2016, 10:26 PM   #63
michaelneal9900
Just got everything finished today, drove the car 100 miles with no problems this time, hopefully it stays that way. Now I have to buy 700cc injectors for the e85 tune
Old 09-01-2017, 11:06 PM   #64
Beechnut87
Drives: White 2015 Series Blue BRZ SC
My first belt snapped after about a year of driving as a daily plus one track visit. Its most likely due to me neglecting to check it since i have been fairly adamant about checking the tension based on how hot/cold it is outside but its broke none the less.
My dilemma was if i should do the upgrade and get the 35% off for those of us who have the old kit still or to buy the replacement 20mm belt.
Beechnut87 is offline   Reply With Quote
Kraftwerks Review projek_01 User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-23-2015 03:44 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 02:33 PM
DPS Kraftwerks Scion FRS - KW / Invidia / Kraftwerks / Enkei rickspecd Member's Car Journals 40 06-26-2014 12:42 PM
