Old 09-01-2017, 12:04 PM   #1
skelly3030
Drives: 2014 FR-S
87 octane gas - no choice (Hurricane Harvey). Could use some advice
Hello, forum. I'm new here, but have been driving and loving my 2014 FR-S (automatic transmission) for the past 3 years. I've never put less than 93 octane gas in it before, and I understand that using 87 octane gas is wasteful, stupid, and really just a bad idea all around. I've read those threads, so we can skip that part.
However, thanks to Hurricane Harvey, there is now a severe gas shortage all over Texas. Starting 8/30, more than half of the gas stations here in Austin were out of gas entirely. I had about a quarter tank of 93 octane and this morning I waited in line an hour at one of the only stations with gas to get 5 gallons of 87 octane fuel in my car (this was the only fuel available.)
I'm no mechanic, but my basic understanding is that the car's computer will notice the lower octane gas and make some adjustments to both lower the power and up the fuel consumption in an attempt to keep the engine from damaging itself. For once I'm getting an advantage out of having the automatic, as it can basically force you to drive gently/efficiently as long as you keep your pedal off the floor.
However, I'm really not sure how long it'll be before I can put 93 octane gas in my car. Any advice about what I should do until the gas crisis is resolved? Should I avoid driving altogether and try to Uber everywhere, or do you think I'll be okay assuming this doesn't go on for weeks/months? I'd really, really like to avoid shelling out thousands of dollars in repairs thanks to a situation totally out of my control.
Thanks in advance, everyone. Looks like you've got a great forum here.
skelly3030 is offline   Reply With Quote
Old 09-01-2017, 12:08 PM   #2
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Yes the computer should detune as noted. Maybe mixing in some octane booster from pepboys could get you by. I think you need a good amount of that stuff to move it up a point though.
SuperTom is offline   Reply With Quote
The Following 4 Users Say Thank You to SuperTom For This Useful Post:
Spuds (09-03-2017), Tcoat (09-01-2017), Teseo (10-09-2017), why? (09-03-2017)
Old 09-01-2017, 12:10 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
It'll be fine, just baby the car until you can get 93 in it again.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
Quentin (09-03-2017), Spuds (09-03-2017)
Old 09-01-2017, 12:11 PM   #4
Don't worry about it. Just don't hit the track. I have had to put 87 in when in the middle of nowhere a couple of times and to be honest I can't even tell the difference when doing "normal" street driving.
Certainly would not recommend all the time but a few tanks worth will harm nothing
Dadhawk (10-01-2017), humfrz (09-01-2017), Overdrive (09-03-2017), SkAsphalt (10-10-2017), Spuds (09-03-2017), Teseo (10-09-2017)
Old 09-01-2017, 12:11 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Just drive mellow, you and the car will be fine.
Old 09-01-2017, 12:19 PM   #6
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
It's early, OP. Check back later for the replies that tell you that you are going destroy your engine.
PetrolioBenzina is offline   Reply With Quote
The Following 9 Users Say Thank You to PetrolioBenzina For This Useful Post:
Cole (09-02-2017), Detroiter (09-26-2017), funwheeldrive (09-01-2017), sgtcarrot (10-04-2017), strat61caster (09-01-2017), SuperTom (09-01-2017), Tcoat (09-01-2017), Ultramaroon (09-02-2017), weederr33 (09-02-2017)
Old 09-01-2017, 12:37 PM   #7
Like said above, it will be OK. Just drive gently.
Tcoat (09-01-2017), wrh3 (09-02-2017)
Old 09-01-2017, 12:38 PM   #8
skelly3030
Drives: 2014 FR-S
Thanks for the prompt replies everyone, that puts my mind at ease. Can't wait for this gas shortage to resolve itself.
The Following User Says Thank You to skelly3030 For This Useful Post:
Tcoat (09-01-2017)
Old 09-01-2017, 12:47 PM   #9
Same for the rest of us in North America! We may not be out of gas but the storm has forced the prices through the roof. Currently my local stations are running around $5.30 a gallon for 91. At least one station I usually use says no premium for at least a week.
On the bright side we still have cars to put gas in and homes to drive them to which is more than many down there can say at this point.
The Following 7 Users Say Thank You to Tcoat For This Useful Post:
Dadhawk (10-01-2017), extrashaky (09-02-2017), mrg666 (09-01-2017), Overdrive (09-03-2017), strat61caster (09-01-2017), Ultramaroon (09-02-2017), wireman957 (09-01-2017)
Old 09-01-2017, 12:48 PM   #10
Oh ya, they will be along shortly. And they will argue it to the death!
Old 09-01-2017, 12:56 PM   #11
SuperTom
SuperTom's Avatar
Yep prices have jump up here in the Northeast too.
The Following User Says Thank You to SuperTom For This Useful Post:
Tcoat (09-01-2017)
Old 09-01-2017, 12:59 PM   #12
radroach
Drives: car
If it's something you want to watch, you can get an OBD reader and monitor your Timing Advance, FLKC Fine learning knock curve, STFT and LTFT Short term and long term fuel trims. You'll be able to see the adjusted values in real time.
Old 09-01-2017, 01:06 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Amen.
Tcoat (09-01-2017)
Old 09-01-2017, 01:14 PM   #14
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Join the Austin 86 Club on Facebook. Few members have found 93 in the area.
Jyn is offline   Reply With Quote
The Following 2 Users Say Thank You to Jyn For This Useful Post:
Tcoat (09-01-2017), weederr33 (09-02-2017)
87 octane
Octane Booster Mix Advice? Chalk DIY (Do-It-Yourself) Guides 31 06-20-2018 09:11 PM
Takata Wallet by Harvey, green racing belt Jman1759 Miscellaneous 2 08-29-2015 10:59 PM
Need advice for my job choice wallace03 Off-Topic Lounge [WARNING: NO POLITICS] 38 03-19-2014 12:37 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
Hurricane Tt3Sheppard New England 45 11-02-2012 10:19 AM
