Old 08-31-2017, 05:50 PM   #29
cjd
cjd's Avatar
Drives: 2017 BRZ
Eh. I'd look at fluid, double check the reverse lockout plate position (and if you're not sure the shifter has never been removed, make sure it's in the right way... it can be installed backwards but... has issues...) And maybe double check technique, just for good measure.
I can (and occasionally do on course, if there's not a turn with the shift) shift without lifting all the way up to the revlimit without problems... which will kick the tail way out if I'm not going straight, so it doesn't happen much. If memory serves, I've always been able to do this. But, if it matters, I now have: Motul fluid, both shifter/transmission bushings (Whiteline), STi motor mounts (they're a direct swap... look identical, really)...
If I get the timing slightly wrong, it's a lot less happy about it, but that's a rare thing.
Old 08-31-2017, 06:12 PM   #30
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I've read about the same thing @R2 is talking about. Saved it via screenshot on my phone will browsing the FB groups. Dude said it made a night and day difference.
https://photos.app.goo.gl/SG6j5iqnVNSojimT2
ApexEight is offline   Reply With Quote
Old 08-31-2017, 10:17 PM   #31
Originally Posted by R2 View Post
I got locked out on 3-2 shifts on track for almost 5 years on this car until I adjusted the reverse lockout plate to the right. It seems that aggressive shifting on track caused me to go a little too far to the left and I couldn't make the shift into second. Moving the plate a bit to the right prevents this over travel.
You guys might be onto something. Having adjusted a few of these, I can testify that alignment is key.
Fortunately, it can be verified easily in the driveway. Put it into second gear and lift the lockout ring. Feel for where the shifter is in the middle of the second gear gate. Then with the lockout dropped, compare the leftmost position of the shifter to where it sits unobstructed.
Lots of words but I'm happy to clarify if I'm not explaining clearly. Here's the way the service manual explains it. Their method is more idiot proof.
Oh, and edit for truth: I'm glad I bit my tongue last night because I wanted to chastise OP for shifting F&F-style. @celek was much more diplomatic than I would've been.
Old 09-01-2017, 12:59 AM   #32
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
If I am shifting at high rpms (6k plus) then 2nd n 5th are always grinders if I'm not careful. I have Whiteline transmission bushing, Perrin shift bushing and MTEC shift springs. I need to do fluid. Maybe then it will be better. Much different if I have been driving for over a half hour. Anything less and there isn't enough heat there or whatever for smooth, aggressive shifts.
Old 09-01-2017, 10:53 AM   #33
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Confirmed: moving this bracket to the right a hair fixed it!!!!!
Sent from my SM-G930V using Tapatalk
Old 09-01-2017, 11:04 AM   #34
StraightOuttaCanadaEh
Wes
well that's interesting! thanks! So it shifts smoothly from 1st to 2nd at WOT now?
Old 09-01-2017, 11:28 AM   #35
ApexEight
Glad it worked for ya.
If you remove the plate entirely, does the actual shifter come out? Thinking about re-greasing mine
Old 09-01-2017, 11:51 AM   #36
DarkPira7e
DarkPira7e's Avatar
1st to second, even non WOT shifts feel more "straight" from first to second. WOT shifting has 0 notch now. Also, I didn't remove the bracket to see if the shifter came out
Old 09-01-2017, 12:00 PM   #37
n0thing
Drives: Subaru BRZ
Did you move the bracket closer to the shifter, so the gap measures 1mm as per the repair manual? I've had a similar problem for a long time, that the gate seems blocked if I shift 1-2 @ >4k rpm or under heavy acceleration.
n0thing is offline   Reply With Quote
Old 09-01-2017, 12:23 PM   #38
DarkPira7e
DarkPira7e's Avatar
Honestly I didn't measure. I half tightened until I stopped feeling to gate when moving from 1st to second
Old 09-01-2017, 12:27 PM   #39
n0thing
Drives: Subaru BRZ
this is with car off, and clutch in?
Old 09-01-2017, 12:33 PM   #40
DarkPira7e
DarkPira7e's Avatar
In this photo my foot was off of the clutch pedal in neutral
Old 09-01-2017, 01:00 PM   #41
R2
Nice, glad that worked for you too.
R2 is offline   Reply With Quote
Old 09-03-2017, 01:38 AM   #42
hongkongbeef
Drives: 2017 Subaru BRZ PP, 2016 Subaru WRX
I have a 2017 BRZ PP and I get the 2nd gear grind at low rpms when the car is cold. I get it less when the car is warm but it doesn't go completely away.
hongkongbeef is offline   Reply With Quote
Slight pull to the left on accel, pull to the right on decel mightaswell Issues | Warranty | Recalls / TSB 18 01-12-2021 07:50 PM
Fender pull pleong Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-29-2014 11:59 PM
If they Pull The Plug exam2300 Scion FR-S / Toyota 86 GT86 General Forum 18 06-26-2014 11:59 AM
Datalogging 2nd gear pull? 1Cor10:23 Software Tuning 11 04-04-2014 01:42 AM
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 06:12 PM
