#1569 | |
Drives: Toyota GT86
If you don't mind turning tuning into a hobby and spend countless hours reading and tinkering, then yes it would probably benefit from a MAF scaling. Expect to do a lot of other adjustments afterwards. A quick fix might be to reduce the values above 3.2 volt in your MAF scale by 4%. Before doing so, do a few more logs with 50 miles apart and check that your LTFT is stay around the 1.56 value it's at now. If your LTFT jumps around it won't be a good solution.
#1570 |
Drives: Scion FRS
http://www.datazap.me/u/nobunnyhere8...n?log=0&data=1
Here is my newest log, not the best so bare with me. This is with the New 3.0 EL 91 tune shiv has sent to me. If you seen anything that can or should be looked at let me know. Thanks!! |
#1571 | |
Drives: FR-S Whiteout
Going a little lean from 6500rpms and it started to pull timing. Try logging in 3rd gear with more consecutive pulls in the log. Your log cut off before it even hit redline.
Intent > Content
cowardice is the mother of cruelty. |
#1572 |
Drives: Scion FRS
DATAZAP.ME is not opening right now, so I cannot load a new run I did today in 3rd gear to red line. Is there any other way to upload a run ?
#1573 |
Drives: Toyota GT86
I need a bit of help.
Can someone tell me why I have AFR command of 14.7 here? ![]() Situation: 1) Driving in 5th at at 4000 rpm. Car is rolling with zero accelerator pedal input in OL. 2) I slowly feather in the pedal up to 48%, at 15% it changes to CL and at 26% back to OL. 3) As it changes to OL, AFR command jumps up to 14.7 with a load of 0.99 (in my POL table I have 12.14 at 4000 rpm/1.00 load). 4) As it passes through this 14.7 area, AFR goes up to 13.35 and it starts to pull timing, eventually dropping IAM. http://datazap.me/u/tor/tor-2312-100...mark=7271-7275 Although the IAM drop is very slight, it's annoying. Where is this 14.7 commanded coming from? Thanks.
#1574 | |
Drives: UK GT86
I really wouldn't worry about a drop of 0.02. That's less than 0.1 of a degree less than maximum at the most
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Spuds (09-02-2017) |
#1575 | |
Drives: Toyota GT86
The problem is not so much that it drops IAM by 0.02. But as it continues to be lean and as load reaches 1.16 it gets -1.3 FLKC. The problem is that since it doesn't knock under WOT, I want to add more timing and don't want to create problems when driving at partial throttle.
#1576 |
I've noticed the same thing on my logs. The car doesn't seem to actually target 14.7 CAFR during this time. Not really sure what causes it.
| The Following User Says Thank You to phrosty For This Useful Post: | Wayno (09-02-2017) |
#1577 | |
I have a feeling it has something to do with the secondary O2 sensor malfunctioning under those conditions. I've not really investigated, as it doesnt cause KC on my car, so I'm not 100% sure. Something related to heat the O2 sensor, I'm guessing.
Intent > Content
#1578 | ||
Drives: Toyota GT86
There is a lot of tipin going on at the same time so maybe that could also be the reason actual AFR is not getting that high? Quote:
I have the secondary o2 sensor corrections disabled. But still I would be surprised if that would have influence on AFR command, since it has it's own separate corrections. Looking at my logs, the only other places I ever have 14.7 is during overrun. At the beginning of a pull, where you come from off throttle, I suppose it could be a logging delay? Thanks for your replies.
#1579 |
Drives: 2013 SSM BRZ
First log
Hi guys,
Still very new to tuning. Please if someone can help me analyze my log. Mods: stock intake, catted header, catback exhaust. 2013/38k km Tune: "v3.0 Stage 2 UEL 91-93" I was really only worried about the adv multiplier going below 1.00. Always have run 91 where (before this log) it went down to 0.34 a 0.54. This log is when I switched to 94 and tried to do a 3rd gear pull. It helped bring it back up to 0.65 only. http://datazap.me/u/fl4tbxr/sept-1-2...0?log=0&data=1 Is my engine prone to knock? Anything else look out of the whack??
________________________________
instagram - @FL4TBXR Last edited by chermo12; 09-02-2017 at 06:37 PM. |
#1580 | |
Drives: Toyota GT86
| The Following User Says Thank You to Tor For This Useful Post: | chermo12 (09-02-2017) |
#1581 | |
Drives: FT86
If you IAM was getting down to 03 on 91 then id avoid running 91 on that tune , maybe run the earlier less aggressive tunes. On 94 it looks acceptable, still some knock and its running rich, but looks like log was fairly soon after flashing ?? as the ltft at mid upper rpm is still 0. Caniadian fuel seems worse than USA fuels from logs ive seen. Apparently husky 94 is good |
| The Following User Says Thank You to steve99 For This Useful Post: | chermo12 (09-02-2017) |
#1582 | |
Drives: FT86
Maybe try reducing or zeroing CL to OL delay timers "When the closed loop delay value is non-zero, this table will be used to determine the transition from closed loop to open loop and back again. When the base pulse width, ((2707.09/Injector Flow Scaling) * Engine Load (g/rev))), rises above the threshold in this table, the process to exit closed loop begins. The current delay value is a counter threshold for which the throttle threshold must be continuously exceeded (otherwise counter is reset to zero and CL to OL transition does not take place). When the base pulse width drops below the threshold (and below a predetermined delta), fueling will transition from open loop to closed loop.</description>" https://forums.nasioc.com/forums/sho....php?t=1474186 |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
