Old 08-29-2017, 07:56 AM   #29
paulca
Drives: Toyota GT86 Coupe Red (UK)
Not sure about US/Canadian specs but the UK 2017 86 has an added e-diff. So if one wheel spins the ABS fires to stop it momentarily to allow torque to transfer to the other wheel with grip.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 08-30-2017, 05:19 PM   #30
dara
dara's Avatar
Drives: Scion FRS
No Problem
I have been Driving in Calgary and Saskatoon for the past few years. The car is easy to drive and I have never been stuck.
dara is offline   Reply With Quote
Old 08-30-2017, 06:50 PM   #31
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
I drive it in the winter, if I can find it
Guru Woodman is offline   Reply With Quote
The Following 2 Users Say Thank You to Guru Woodman For This Useful Post:
Tcoat (08-30-2017), Yousend (09-21-2017)
Old 08-30-2017, 08:46 PM   #32
who buys a white car in Canada anyway?
Guru Woodman (08-30-2017)
Old 09-20-2017, 05:07 PM   #33
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Respect the conditions, get good, thin winter tires, respect the conditions. Take time to practice when nobody is around, it'll be much safer than learning when everyone in their AWD SUVS has their butthole clenched as tight as it can go is driving alongside you. That's how it is here in Vermont, I've been driving low RWD cars (mostly e36 BMWs) in the snow since 2008 and have yet to get into a situation that could have been avoided with another driveline choice. (getting body hung because I want to get into my driveway without shoveling 2' of snow is my choice, not the car's fault)
Old 09-20-2017, 11:07 PM   #34
milkydude12
milkydude12's Avatar
Drives: none
I have a heavy foot, so ill try to work on that before winter hits (After much delay, I've decided to get the Toyota 86 this friday ), for sure, ill definitely be getting some good winter tires (ill put them on the OEM prius rims).
milkydude12 is offline   Reply With Quote
The Following User Says Thank You to milkydude12 For This Useful Post:
why? (09-21-2017)
Old 09-20-2017, 11:18 PM   #35
Cole
Not a troll
Cole's Avatar
OEM Prius rims? I don't believe the twins come with Prius rims. Or wheels, for that matter.
Cole is offline   Reply With Quote
Old 09-21-2017, 02:35 AM   #36
milkydude12
Drives: none
Ah, nvm, I see that now XD it looks better now than when the FRS was still in production (I just absolutely hated the stock rims on those), however im still going to use the stock rims for my winter tires . Im planning to use a set of these https://www.ft86motorsports.com/whee...-red-opal.html for summer use.
Old 09-21-2017, 08:23 AM   #37
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I'm not in the Great White North, but given we had 130" of snow just two years ago and regularly are over the 100" mark for the season, I think that qualifies as 'real' winter...lol. I DD my car and provided you invest in a full set of good snow tires, and use some common sense when driving in poor conditions, the car does just fine. In fact, it's a hoot...just drive it like you would any lightweight rwd car in low traction conditions. The only drawback to the car is the ride height; traction generally isn't a problem, but clearance is obviously restricted compared to most other vehicles, so stay away from the sloppy berms left by plows between lanes and at intersections.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 09-21-2017, 08:38 AM   #38
Yousend
Drives: 2014 FR-S
What is this common sense you speak of? If I look at the average Joe here, you have to mash the accelerator in desperation if you're stuck. Try to enter a busy street from a dead stop as cars are speeding past you and force them to brake hard. If anything, common sense is the last thing you want to use when driving in poor conditions.
On a serious note, take it slow. Too much gas and your tail will kick to one side when one of the sides loses grip. The car will let you know, you will feel it. It also behaves really well when you want it to, it is very responsive and communicates very well.
Yousend is offline   Reply With Quote
Old 09-21-2017, 03:06 PM   #39
Jordanwolf
Rice King
Jordanwolf's Avatar
wat.... du u evn kno wut dis kar iz?
btw, don't go to a car meet (or anywhere a enthusiast could show up) then call your wheels rims, true enthusiasts will avoid you like the plague
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 09-21-2017, 04:43 PM   #40
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
aww, but I want to freak out those SUV drivers on bald all season tires as I drive by them doing the speed limit because they are afraid to go over 40. It only takes a little slide and they think the world is ending!
why? is offline   Reply With Quote
Old 09-21-2017, 06:11 PM   #41
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Lowered 1.5 inches.
In the snowbelt dead center of all the great lakes.
Daily driven for 3 winters.
Drive minimum of 1,300 kilometers a week.
Have never been stuck.
With good snow tires zero the thing is a tank in the snow.
I have had to stop to help push AWD cars out of my way several times.
Do it!
Thanks for ruining my, "it will blow up in a ball of fire" chance here.
Old 09-21-2017, 07:28 PM   #42
Hey, I said I never got stuck not that it never blew up in a ball of fire. Hell the first commercial for the thing shows a ball of fire.
SkAsphalt (09-22-2017)
canada, questiion, snow, toyota
TPMS in Canadian 2017 BRZ? wolffbite CANADA 6 04-05-2017 09:31 PM
Canadian 2017 BRZ - good negotiated price? nico_rsx CANADA 16 03-09-2017 10:48 PM
Canadian International Auto Show 2017 STOOPIDSTANCE BRZ Photos, Videos, Wallpapers, Gallery Forum 0 02-28-2017 07:58 PM
2017 Toyota GT86 on Snow and Ice - Video mark0006 Scion FR-S / Toyota 86 GT86 General Forum 11 01-13-2017 01:14 PM
How do you say Yellow in Canadian (2017 Inazuma Edition) DatsunDimer BRZ First-Gen (2012+) — General Topics 40 12-17-2016 12:05 PM
