Old 08-30-2017, 04:04 PM   #15989
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
OptiCoat Plus Ceramic Coating. The result is even more dramatic then I can catch with photo's.
Guru Woodman is offline   Reply With Quote
The Following 2 Users Say Thank You to Guru Woodman For This Useful Post:
jcw99 (08-31-2017), OrangeGuitar (08-30-2017)
Old 08-30-2017, 04:34 PM   #15990
StraightOuttaCanadaEh
Wes
If you don't mind, where did you have it done and what did they charge you? Feel free to pm me. Thanks!
Old 08-30-2017, 05:12 PM   #15991
Guru Woodman
I sent you a looooooong pm
Old 08-30-2017, 05:21 PM   #15992
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Added a chin strap to go with the mustache.
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
chermo12 (09-03-2017), OrangeGuitar (08-30-2017)
Old 08-31-2017, 04:41 AM   #15993
HSUBLU
Drives: 2017 BRZ WR Blue
Perrin 2.5" Catback Resonated exhaust installed.... took me 3 hours. I'd never done an exhaust before, and fine tuning the position of the tips took me forever. Kind of worried, the mid-pipe to front pipe bolts are supposed to be torqued to 25 ft-lb but my torque wrench wouldn't fit so I had to try and get it done by hand... we'll see what happens when I fire it up in the morning.
HSUBLU is offline   Reply With Quote
Old 08-31-2017, 10:09 AM   #15994
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
You should have watched my videos to get an idea of the process first
I wouldn't worry about the torque. I've swapped exhausts around probably half a dozen times on my 2017 BRZ, never once torqued anything. Just make sure it is solid tight.
justinco is offline   Reply With Quote
Old 08-31-2017, 10:16 AM   #15995
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Some times I regret painting over the OEM sterling silver. It's such a beautiful color subtle color. Sigh....
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 08-31-2017, 04:50 PM   #15996
BirdTRD
Simply Forgotus
BirdTRD's Avatar
I like to think of it as "Stealthy"... it literally flies under the radar! Zero unwanted law enforcement type attention. (knock on wood!)
Old 08-31-2017, 08:33 PM   #15997
Is Always Angry
Is Always Angry's Avatar
Drives: Low and Slow
if you don't mind, where did you get this? I've got a SSM also and damn that looks good!
Is Always Angry is offline   Reply With Quote
Old 08-31-2017, 09:43 PM   #15998
BirdTRD
Simply Forgotus
BirdTRD's Avatar
No problem. It's Bayson R CS-Style off Ebay. http://www.ebay.com/itm/390661121250
There's also the ST-Style. http://www.ebay.com/itm/390891778133
The Following User Says Thank You to BirdTRD For This Useful Post:
Is Always Angry (08-31-2017)
Old 08-31-2017, 10:17 PM   #15999
osidak
Drives: '17 BRZ w/PP
Finally got around to tinting the windows
osidak is offline   Reply With Quote
Old 08-31-2017, 11:46 PM   #16000
Is Always Angry
is the only difference that the ST has the larger little winglets on the outer edges?
Old 08-31-2017, 11:51 PM   #16001
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Picked up some groceries in it.
The Following User Says Thank You to justinco For This Useful Post:
Clipdat (09-01-2017)
Old 09-01-2017, 12:10 AM   #16002
Zentec
Drives: 2017 Toyota 86
Originally Posted by BRZyJ View Post
Combined some random stuff I had laying around into something to stick on the fuse box lid...
Nice over all color theme
Zentec is offline   Reply With Quote
The Following User Says Thank You to Zentec For This Useful Post:
BRZyJ (09-01-2017)
