Drives: 2013 Subaru BRZ & 99' Ford Explorer
RALLY SUSPENSION / LIFT / OFF ROAD
Is there any way to lift the brz up an inch? or maybe a rally/off road coil over kit? what is the best suspension set up for potholes, dirt roads, bumps, dips, catching air, etc....
where can i find this? |
#2 |
Drives: AE86, 2x GT86, TE27
Cusco make a rally set that does what youre after.
#3 |
Because compromise ®
Drives: Red Herring
The Nameless rally car is running MCA suspension.
#4 |
Drives: Slowly
Spend 5k on some MCA Golds and you're set.
Sent from my Nexus 4 using Tapatalk |
#5 |
#6 |
i'm sorry, what?
Drives: Canada
with that avatar, i can't take anything you post seriously
| The Following User Says Thank You to 7thgear For This Useful Post: | Captain Snooze (02-06-2014) |
#7 |
Drives: Sterling BRZ Ltd
Subtle Solutions has strut spacers. I ran King Springs on my STI, gave about 1.5" of lift, it was a blast.
#8 |
Drives: 2014 Subaru BRZ
Is a bagged super high but stiff an option or am I just stupid?
Sent from my LG-H918 using Tapatalk |
#9 | |
Drives: 15 BRZ LTD, 05 FXT
Take a look at the Flatout coilovers if you wanna go up.
#10 |
Only users lose drugs.
Drives: All the time
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#11 |
Drives: 2005 Toyota Camry
#12 |
Drives: 2013 Hot Lava FRS
I did this diy in my mazda 3 by just blowing all 4 struts. Good times.
#13 |
Drives: Subaru BRZ
Here I was thinking that the standard OEM suspension setup was default 'rally' spec, gravel road!
#14 |
Drives: 2014 GT86
Highly doubt it. This is no wrx/sti/evo, where rally use might be way more common. Too little suspension droop travel, too little ground clearance. Main target for suspension setup most probably tarmac tracks, not road-hole ridden bad roads and high jumps.
| DIY: Air Lift Suspension Install | RallySport Direct | DIY (Do-It-Yourself) Guides | 63 | 04-16-2016 11:42 PM |
| Air Lift Performance Air Suspension In Stock at RallySportDirect.com!! | RallySport Direct | Brakes, Suspension, Chassis | 14 | 06-03-2014 11:11 AM |
| Road Rally!! Possible BRZ/FRS meet in Las Vegas?!? | ESC POD | Southwest | 9 | 01-04-2013 01:51 AM |
| Northwest Road Rally | GreenLight America | CANADA | 0 | 11-02-2012 03:52 PM |
| Road Rally!! Possible BRZ/FRS meet in Las Vegas?!? | ESC POD | Southern California | 8 | 10-28-2012 03:01 PM |
