Old 08-29-2017, 10:30 PM   #2843
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Few quick questions:
- Are aesthetic front lips permitted (STi lip)?
- Are aftermarket shifter springs, shifter carrier bushings, and rear shifter bushings legal?
- Is it ok to daily with -3 or more camber if it's a short commute, like 15 miles each way? Don't want to wear out the daily wheels (stock wheels with 225 all-seasons).
Thanks!
ApexEight is offline   Reply With Quote
Old 08-30-2017, 02:15 AM   #2844
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Originally Posted by Shark_Bait88 View Post
If any of you STX folks are looking for new wheels, you might wanna jump on the Konig Hypergrams during Discount Tire's Labor Day sale. 17x9 +40 (should clear most BBK), flow formed, and only ~$565 before tax with the $100 off sale through Discount Tire.
https://www.discounttire.com/buy-whe...ergram/p/47839
Looks pretty good, not bad for 18lbs.
tigermack is offline   Reply With Quote
Old 08-30-2017, 02:20 AM   #2845
e1_griego
e1_griego's Avatar
Drives: Many
I have two sets, both purchased through Discount Tire. They also usually incentivize putting stuff on an account with an extra $100 back for wheels and $100 back for tires.
e1_griego is online now   Reply With Quote
Old 08-30-2017, 02:41 AM   #2846
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Thanks!
Yes to OEM STi lip.
The Whiteline shift bushing is a common legal upgrade. Haven't heard of the others.
DD is fine w/ that camber. Tires won't wear as well as with a street alignment, of course. Never been a big deal for me.
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
ApexEight (08-30-2017)
Old 08-30-2017, 09:59 AM   #2847
ApexEight
Originally Posted by justinco View Post
Yes to OEM STi lip.
Thanks!
Are you refering to the Whiteline positive shift bushing that inserts into the transmission bushing? I was talking about the rear shifter bushings and stuff for the actual shifter.
Old 08-30-2017, 10:06 AM   #2848
cjd
cjd's Avatar
Drives: 2017 BRZ
Thanks!
I believe any bushing can be swapped as long as it maintains original geometry and has no more metal content than stock. I think the springs are legal since the shifter itself is open and they simply replace stock.
As noted, the STI lip is legal... On a BRZ. It still has to have been a factory option.
I'd guess at 30mi/day you'll age the tires out before they wear too far. I haven't run all season tires in years since they're useless, but haven't been disappointed in the wear on summers or snow tires on my bold car... I don't drive most days now so no direct comparison. Still road trip at -3.3 and don't observe any obvious issues.
The Following User Says Thank You to cjd For This Useful Post:
Old 08-30-2017, 10:23 AM   #2849
ApexEight
Awesome, thanks. Yeah, as long as I have good toe settings I too don't forsee the camber being an issue.
Last legality question... Brake master cylinder brace?
Old 08-30-2017, 10:24 AM   #2850
cjd
cjd's Avatar
Drives: 2017 BRZ
Nope. Not legal.
Old 08-30-2017, 10:25 AM   #2851
ApexEight
I lied. There's one more... Grimmspeed strut tower brace while retaining stock braces?
Old 08-30-2017, 03:18 PM   #2852
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
That should be legal
G_Ride is offline   Reply With Quote
The Following 2 Users Say Thank You to G_Ride For This Useful Post:
ApexEight (09-06-2017), cjd (08-30-2017)
Old 09-05-2017, 11:44 PM   #2853
cjd
cjd's Avatar
Drives: 2017 BRZ
I was actually reading the rules yesterday and the toe arms are STX legal if you're using an adjustable LCA and not a modification to the upper arm (I think whiteline offers a camber bushing). Either it was changed in the last year or so or we're both crazy.
14.8.H.1
On double/unequal arm (e.g., wishbone, multi-link) suspensions, only the upper arms OR lower arms may be modified or replaced, but not both.
Bringing this over where it belongs.
Where are toe arms allowed? I'd so like to not mess with the eccentrics... I only see an allowance for upper or lower arms, nothing anywhere about the toe tie rods. Not specifically allowed = not legal... I really hope I'm just blind, but I reread the rules and find nothing. Or are you saying that you can run stock everything and aftermarket toe arm? Not sure I can go without the LCA.
C
Old 09-05-2017, 11:44 PM   #2854
M0nk3y
C
Toe arms are not legal, and open to a wonderful justified protest
Kyle H. - #89 STX
Old 09-05-2017, 11:49 PM   #2855
cjd
cjd's Avatar
Drives: 2017 BRZ
That's what I understand to be the case also. Disappointing, I have plenty of range and only want an easier time doing my alignment... But I understand the rule and will deal with it.
Old 09-05-2017, 11:50 PM   #2856
M0nk3y
Because toe arms change the bushing to a spherical, which is not allowed per ST rules saying you can not change the style of bushing
Kyle H. - #89 STX
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
