Old 08-29-2017, 02:01 PM   #1
sid94
Drives: 2013 frs
Timing cover leak
I got a leak coming from my timing cover in the driver's side I'm out of warranty
Baisically what I want to know if anybody on here has resealed it themselves, I'm a tech so it's not a problem just want to know if anyone here has the list of the parts I would need to do the job
I have extended warranty but if the cost of parts is less then my deductible I'd rather do it myself
I'm going turbo next week so I wanna get this took care of before
sid94 is offline   Reply With Quote
Old 09-07-2017, 04:39 PM   #2
kandiflippin
I'm having the same issue and following this to see what's said, I can't find much as far as DIY, there was a TSB floating around on one of the threads for some o rings and had some recommended things to do if you do pull it off but I haven't been able to find it again yet.
kandiflippin is offline   Reply With Quote
Old 09-09-2017, 08:58 PM   #3
sid94
Drives: 2013 frs
I ordered the parts and i will be doing a DIY once this bitcj ass hurricane passes cause I have noticed that I'm not the only one with this problem
The Following User Says Thank You to sid94 For This Useful Post:
Teseo (09-09-2017)
Old 02-15-2018, 08:46 PM   #4
PDXsuperfly
Drives: 2013 FRS
Did you ever find a good write up?
PDXsuperfly is offline   Reply With Quote
Old 04-03-2018, 03:06 PM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I got one of my passenger side got towards the top there's not much that you could do about it. Other than pulling the motor and resealing it. There's a liquid gasket that's applied, not a drop-in gasket unfortunately. I don't really lose much oil don't have to worry about it because my 3K oil changes. I'll deal with it when I add my rods and pistons personally.
I wish I never got divorced because my new intake manifold, rods and pistons, head studs & valve springs would be installed already. I got to wait for a new girl to move in to help me with bills before I pull the motor. But I'm already working on that....
these damn rods and Pistons have been staring at me for a year now it's really pissing me off...
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Timing Cover Oil Leak AllDayJonRay Issues | Warranty | Recalls / TSB 18 06-06-2016 03:12 AM
Timing Cover Oil Leak Keenercarguy Issues | Warranty | Recalls / TSB 66 05-30-2016 11:59 PM
Timing Chain Cover Leak alexand3r Engine, Exhaust, Transmission 17 09-29-2015 11:05 AM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
