Old 08-24-2017, 02:09 PM   #57
churchx
churchx's Avatar
Drives: 2014 GT86
gtengr: aftermarket overpipe doesn't net much by itself. It's catless header that nets most. What happen to net more gain for ace - not because it's construction has replaced overpipe, but because it has longer runners, that happen to be more optimal for better exhaust scavenging on our engines. Just that by design choice ace chose to put some of that extra pipe runner length using overpipe portion, unlike Nameless (also having long tube header design) that tucked that extra length in rising bend in front of engine. Each design has some pros & cons, eg. nameless's has better suspension/engine clearance at overpipe portion, but worse in front of engine, and also haven't got rid of torque dip. Nameless/PLM long tube headers IIRC had OFT tune for them. Both Nameless & Ace have nice area under curve showing good gains across the rpm range. Everybody can pick their own poison
Old 08-25-2017, 12:04 PM   #58
JermMX5
Drives: 2017 Toyota 86
Here's the post I was looking for finally: http://www.ft86club.com/forums/showp...postcount=1207
Mike any input on that? 16HP is only 2 or so more HP than the OFT + OFH which would put it at a horrible $/HP.
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 08-25-2017, 02:54 PM   #59
CSG Mike
CSG Mike's Avatar
I can't comment on cars that I haven't seen in person. Most of the time, there is something mechanically wrong with the car.
One bad example vs everyone else with an Ace header? Statistically insignificant.
It's akin to the occasional "my JRSC only made 30whp" or "my Edelbrock kit wont idle" thread that pops up.
Ghost of Akina (08-25-2017)
Old 08-25-2017, 05:19 PM   #60
Kodename47
Kodename47's Avatar
Drives: UK GT86
Or just that some engines are naturally stronger (produce more power) than others.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-25-2017, 06:41 PM   #61
Unless you have cams and/or a build engine...
Gotcha. Bottleneck's upstream of the header.
CSG Mike (08-25-2017)
Old 08-25-2017, 06:52 PM   #62
CSG Mike
CSG Mike's Avatar
Precisely. Also, not recommended for cars that aren't being raced, as the bottom end gets hit pretty hard.
Ultramaroon (08-25-2017)
Old 08-25-2017, 08:39 PM   #63
Sure, but I don't care about that.
Old 08-25-2017, 09:29 PM   #64
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Originally Posted by brzaapi View Post
EDIT - Any BRZ I own would have the ACE350 and the DTFF kit w/ tune. Flex and header run well, that would be my minimal setup and I could live happy with just those two mods.
This combination with perrin filter and air tube is what i have, totally agree. Way happy. Delicious flex tune from late 2016.
Brzzee is offline   Reply With Quote
Old 08-26-2017, 11:55 PM   #65
BuffDriver
Drives: 2016 Subaru BRZ
Still wish CSG Mike would cough up some info on what ceramic coat is used. With no heat shield like on the OEM header in daily driving the engine compartment must be getting a lot hotter.
A) Wonder how much hotter engine compartment on a 98 degree summer day in stop n go traffic on the street with and without the coating? { Oil pan temp hotter due to radiated heat? }
B) And when I researched I kept running into comments but no facts on even stainless deteriorating from the metal getting too hot under the ceramic in header applications. Lots of speculation, conjecture and hearsay but no definitive proof the metal gets damaged like with wraps. If there is NO damage then why do so many header mfg void warranty if aftermarket coated.
So what is CSG using that's OK?
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
BuffDriver is offline   Reply With Quote
Old 08-28-2017, 01:08 AM   #66
CSG Mike
CSG Mike's Avatar
Because the manufacturer cannot control what ceramic is used. Not all ceramic is equal.
The conditions of stop-and-go traffic is nowhere near as rigorous as sustained WOT on track.
My car's seen 40+ minute extended sessions on track without issue. Radiant heat absorbed by the oil pan, relatively speaking, is irrelevant compared to the heat generated by sustaining extended 5500+ RPM.
Tomei includes wrap for the oil pan because of proximity.
As for the air under the engine bay, I would assume in 98F+ degree weather, you'd have AC on, which will force airflow through your engine bay.
wparsons (08-28-2017)
Old 08-28-2017, 01:41 AM   #67
swarb
Because ceramic coating is applied in different ways, some of which use higher temps that what the metal would see under normal conditions.
Also, the coating will make it difficult for inspection(under a microscope) to see why the metal fatigued and failed.
The Following User Says Thank You to swarb For This Useful Post:
Old 08-30-2017, 04:34 PM   #68
Jakinit
Drives: 2017 CWP BRZ Limited (MT)
Seeing this makes me sort of regret going for the Tomei UEL with overpipe. I have to get mine on the dyno and see what it's putting down.
Mike, unrelated but do you think a drop in filter would give any kind of bump to a '17?
Jakinit is offline   Reply With Quote
Old 08-30-2017, 04:38 PM   #69
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
My name's not Mike, but, you're not going to feel anything with just a filter alone.
justinco is offline   Reply With Quote
The Following 2 Users Say Thank You to justinco For This Useful Post:
juliog (08-05-2018), weederr33 (08-30-2017)
Old 08-30-2017, 04:44 PM   #70
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Thanks Mike!
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
justinco (08-31-2017), SkyeHack (12-26-2017)
CSG Mike's personal 2017 BRZ build and thoughts. CSG Mike Member's Car Journals 235 09-09-2019 11:03 PM
CSG x MXP Catback + Ace A350 - Review & Video Majic86 Engine, Exhaust, Transmission 14 08-06-2018 01:01 AM
Do dynos lie? nikitopo Engine, Exhaust, Transmission 21 05-10-2017 08:32 AM
CSG Mike's 2017 Baseline dynos CSG Mike Engine, Exhaust, Transmission 40 01-21-2017 09:20 PM
Perrin CAI - Any dynos? griffinnn Engine, Exhaust, Transmission 0 03-14-2014 04:56 AM
