Old 08-24-2017, 01:58 AM   #1
Hagfish
Drives: 2013 FRS
Backup cam - tapped into reverse at the bulb
Hi all- sorry if a similar post/question exists, but I was unable to find the answer searching through the posts, as most or all of the cam installs seem to involve wiring into the front panel under the steering wheel and/or using an upgraded head unit with a screen.. I went the cheaper route and bought an autovox m1 with a separate LCD screen mounted on my dash (only 30 bucks!).. Anyways, I'm just looking for you smarter folks to hopefully tell me that I got my wiring right..
The power for the camera has the standard +- red and black wire. The wires from the FRS going into the reverse bulb fixture are green and dark grey (not quite black).. I went ahead and tapped black into dark grey and red with the green wire.. It's all working so I think I'm good to go, but I just wanted to make sure I got it right and won't be doing any damage to the battery or anything if I have it reversed.. Would it even be working if I reversed it? Again, sorry if this has been covered- and thanks for any input!
Hagfish is offline   Reply With Quote
Old 08-24-2017, 02:32 PM   #2
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
no, it wouldn't work if the wires were reversed.
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
Hagfish (08-24-2017)
Old 08-24-2017, 02:56 PM   #3
Hagfish
Drives: 2013 FRS
Thank you for the response- I figured that would be the case, but I haven't done a whole lot of wiring and was worried I'd screw something up if I guessed wrong.. Oddly, through all the searching and downloading of wiring diagrams, etc- I was never able to find any info or documents on the green\grey wires to the reverse bulbs.. Thanks again!
Old 08-24-2017, 05:00 PM   #4
fx1mark
fx1mark's Avatar
you should use a multimeter and confirm positive and negative before connecting to make sure you don't damage anything by hooking them up backwards.
Old 08-24-2017, 05:21 PM   #5
Hagfish
Drives: 2013 FRS
You saying I still should? Or I should have before I started? I thought about it, but for those of you who haven't done it, it's a real b*** tapping into that reverse light- even with partially removing the fender..
Old 08-24-2017, 06:30 PM   #6
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
I just jammed the camera's red wire into the light harness, no splicing, tape or anything. It might work its way out eventually, but its been working for 9+ months. I seem to remember using an existing ground in same general area too. Not the most elegant solution, but you can indeed put in a camera without touching the factory wires or messing with the fender.
BRZyJ is offline   Reply With Quote
Old 08-24-2017, 10:25 PM   #7
fx1mark
fx1mark's Avatar
I meant before you started and if you ever do any kind of wire modification on your car. you took a chance by hooking it up without testing. I've installed a backup camera on my car. I don't know what you mean by removing the fender. I tapped into the reverse wire near the drivers left foot.
Old 08-24-2017, 10:40 PM   #8
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Did you know the reverse light plugs into the main wiring harness just below the trunk latch inside the trunk? Very easy to access the wiring there...
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following User Says Thank You to nextcar For This Useful Post:
Boomerang (08-25-2017)
Old 08-25-2017, 05:34 AM   #9
Hagfish
Drives: 2013 FRS
Yea I started realizing/thinking as the fender was laying on my garage floor- there's gotta be an easier way.. But- all of the youtube videos I had watched about installing one of these backup cams, people were tapping into the wire directly at the reverse bulb.. Lucky for them, the bulb is usually accessible right from the trunk!! Not so much with the FRS. Anyways, it was a process but I did get it done..
To answer you nextcar-- unfortunately I did not realize that and OMG it would have been so much easier, but I still don't know where I would have found that info unless I just didn't search hard enough.. Like I said, every post I found seemed to be about people going into the box under the steering wheel, which with my kit, I'm not sure would have worked.. Now that you mention this though, I'm considering rewiring it!
Old 12-23-2021, 02:18 PM   #10
nripinbabu@gmail.com
Drives: brz
Can you please share any photo to show the wire color ?
nripinbabu@gmail.com is offline   Reply With Quote
SOLVED: No Reverse/Backup Signal or Lights sidetrak06 Issues | Warranty | Recalls / TSB 46 06-30-2025 10:42 PM
FR-S / BRZ Reverse/Backup LED Bulbs! See Comparison Photos, Ships Same-Day! Diode Dynamics Exterior Parts - Lighting 72 11-30-2021 03:19 PM
FS: Professionally Painted/Tinted w/ Clear Coat Backup Reverse Light Assembly - $120 STS-V Exterior Parts (Aero, Lighting, Etc.) 4 08-24-2014 07:02 PM
Interior LED + Reverse backup package? Intake Scion FR-S / Toyota 86 GT86 General Forum 1 07-12-2013 12:46 PM
