#15 |
#16 | |
3hp/tq gain? You need a better tune, quite frankly... even the cheapest cat delete will do more than that with a proper tune. Your baseline is also significantly higher than mine, which means the gains that could be had with an Ace header + tune is actually quite a bit more than 10whp. |
#17 |
Drives: 2020 STI Limited
#18 | |
Drives: 2017 Toyota 86
Based on there gains I would be making 207 on the same dynojet on pump gas. And if that's the case then I need to buy one yesterday, but I havn't seen anyone's personal dynos so I'm still weary.
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
#19 |
#20 | |
#21 | |
btr.life
Drives: 2022 GR86
We have done 20+ tune revisions on the 2017 car with my tuner, I am pretty confident it is a good tune. But, things like this make me question my setup/tune lol. Part of it could be that I am at mile high altitude in Denver, where we have no air ![]() What do you guys recommend to complete the exhaust with an A350? I currently have a Berk front pipe w/ HFC and Blitz VSR exhaust (and another exhaust I can use that is custom made). My car is setup to be nationally competitive for SCCA autocross, I need all the power/torque I can get. Would the CS400 be a better option for that use case?
#22 | |
Drives: 2013 satin white brz limited
With my ace 350 I am running Invidia Q300. Its tame most of the time but when you want to make noise it opens up alot. Personally I feel anything louder then the Q300 would be obnoxious with a full catless system like I have.
#23 | |
Drives: '13 FRS - STX
I question the "need" for low end torque in an autox 86 (sorry if you didn't mean to imply that's what you're looking for in your post and I'm preaching to the choir), yeah it's miserable digging out of those one or two slow corners, but when 90% of your run is above the "dip", seems like a no-brainer to me where the emphasis should be... Last edited by strat61caster; 08-23-2017 at 02:02 PM. |
#24 |
I do infact see that it's possible with a top notch tuner, I meant more that I havnt seen anyone take the off the self DT Ace tune and have the same results, especially because others in the ACE thread have said that they only got an 8HP (And then later 16HP) gain.
#25 | |
Altitude is a factor, but dyno readings correct for temperature/pressure/humidity to "normalize" the readings. That being said, as previously stated, the relative gains are what truly matter. A 20% gain is a 20% gain, whether you're at 200 feet or 7000 feet. Catbacks have little to no effect on power output at a stock NA engine level. I say use whatever gives you the sound you want. I use a stock exhaust. |
#26 |
Drives: 2013 FR-S Argento
Holy Toledo. No doubt this is probably one of the best headers on the market for our cars, and likely Mikes results have quite a bit of tuning time on them. BUT, that's a pretty big chunk of change that could go a long ways to a decent turbo kit. Of course we all have different needs, but not sure how I could spend over 2k on metal tubes lol. YMMV
Sent from my SM-N920V using Tapatalk |
| The Following User Says Thank You to bfrank1972 For This Useful Post: | weederr33 (08-23-2017) |
#27 | |
Drives: 2017 Ice Silver BRZ Limited
I just watched Justin's exhaust shootout video for the 2017 BRZ (Really enjoying these BTW!). In your test of the second, Magnaflow custom exhaust, you've got rpm's displayed in your overlay. Those didn't drop below 4k for the entire span of your run and stayed above 5k (mostly in the 6-7k range actually) for most of the time. Based on that, maybe the torque dip is not as much of an issue as initially thought and you should be aiming at better high end hp? My 2 cents. Headed back to watch the rest of the video.
| The Following 2 Users Say Thank You to Williampreza For This Useful Post: | justinco (08-23-2017), strat61caster (08-23-2017) |
#28 |
Drives: Black BRZ
Is that dip in the 91 plot at 2500 real? With how sharp it is (both down and back) it seems like it would be annoying from every pull away from a stop in first gear.
| CSG Mike's personal 2017 BRZ build and thoughts. | CSG Mike | Member's Car Journals | 235 | 09-09-2019 11:03 PM |
| CSG x MXP Catback + Ace A350 - Review & Video | Majic86 | Engine, Exhaust, Transmission | 14 | 08-06-2018 01:01 AM |
| Do dynos lie? | nikitopo | Engine, Exhaust, Transmission | 21 | 05-10-2017 08:32 AM |
| CSG Mike's 2017 Baseline dynos | CSG Mike | Engine, Exhaust, Transmission | 40 | 01-21-2017 09:20 PM |
| Perrin CAI - Any dynos? | griffinnn | Engine, Exhaust, Transmission | 0 | 03-14-2014 04:56 AM |
