| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2014 brz
A/T fluid change gaskets
I'm trying to figure out the part numbers for the 3 a/t gaskets that i need for my fluid change. I tried searching the forum i can find a lot of topics discussing fluid but nothing that lists the A/T gasket part numbers. The diagrams on most of the parts websites don't show correctly for me and the subaru dealer is less than helpful they can't even tell me an accurate price for them to change the fluid. I've been told a range of guesses from $250 to $500(toyota dealer). All of the dealers around me a clueless with this car.
#2 |
*Some really cool title*
Any specific reason for changing the fluid? Our autos are cvt's and as far as I know the fluid does not ever need to be changed. You're probably having a hard time finding info about it because no one ever does it.
Dealership should know though. Try a different one and contact Subaru directly if you can't get an answer from a technician. |
#3 | ||
Drives: 2015 BRZ
#4 |
Drives: 2014 brz
Ya definitely not a CVT.
I'm rolling over 60,000 so its due to be changed. I'll try another dealer today see if they can get me part numbers for those washers. |
#5 | |
Drives: 2015 BRZ
Differential fill plug gasket: SU00300122 Differential drain plug gasket: 1215710010 |
#6 |
Damn, I specifically asked my technician about trans fluid change a while ago, and he told me "it's a cvt so you never need to do that". These guys must really not know much about BRZ's.
| Issues after AT fluid change | 8enj1 | Engine, Exhaust, Transmission | 4 | 07-26-2016 07:06 PM |
| AT fluid change when going FI? | xsnapshot | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 05-31-2016 07:03 PM |
| AT Fluid Change? | Estey | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 45 | 10-23-2014 09:55 PM |
| AT Fluid Change | Terrapin77 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 08-29-2013 09:52 PM |
| Fluid change | siXXtoes | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 12-06-2012 09:39 AM |
