#127 |
Drives: C5, GT-86, '24 Colorado TrailBoss
I bet handbrakes hate living there
#128 |
Drives: 2014 Lightning Red Subaru BRZ
Is there a reason it can't be used on a regular basis?
#129 |
Those scizzor jacks are not very sturdy can tip over if not on a perfectly flat surface. Don't ask how I know
#130 |
Drives: DGM BRZ
In my opinion it can be used regularly as long as you are careful. I haven't built blocks yet so I use the scissor jack to lift the car up a bit until I can fit my regular jack under, but only in my level garage. The handle hole is starting to oval but other than that it seems fine.
#131 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
By design, as it's an emergency item. The device isn't meant to be used other than for the emergency tire changes you may need to get done to get you back on the road. The engineers don't expect you to need to change a flat tire ten times a year. You're really only going to get so many safe uses from it, and after that it's going to be a dice roll until the assembly fails. Granted, you're not keeping the vehicle constantly supported by the jack while you're working on it, but to get the vehicle up on stands you're using it anywhere from 2 to 4 times to get the corners up to get stands under them. I'm pretty sure the owner's manual even warns against using it for regular maintenance.
-O/D
2016 FR-S, Hot Lava |
#132 | |
Sittin' Sideways
-O/D
#133 | |
Drives: 2015 BRZ Limited
![]() They work great, and the pinchweld rubber pad is a fantastic deisgn! Search "Bal 920" for the stands, and "Bal 1350" for the pads. |
| The Following User Says Thank You to JeremyR For This Useful Post: | saltywetman (04-29-2020) |
#134 |
Drives: '13 BRZ
I think only a few people in this entire thread addressed the pinch weld issue correctly.
Like one person said, the car should not be supported on the pinch weld at all. Look at the factory jack, the pinch weld fully seats into the slot, and the weight of the car is on the SIDES of the pinch weld. The cars are still new, but eventually, your pinch weld will rust, and bend, and collapse. I see a lot of people have bought "adapters" or V-shaped jack stands, but they are not deep enough to clear the entire pinch weld. Same goes with a slotted puck. If the pinch weld hits the bottom of the slot, it is not doing anything. At that rate, it's no different than putting the pinch weld on a flat surface. The puck cut away needs to fully clear the weld so ZERO weight is on the weld seam. Has anyone confirmed which slotted puck is deeper than the entire weld, so the weight rests on the body alongside the weld, and not the weld itself? Does anyone place the jack stand elsewhere? Last edited by LudwigMiles; 08-22-2017 at 07:25 PM. |
#135 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
You'll be fine if you place the jackstand in the reinforced area of the pinch weld. Never place underneath the pinch weld of the front fender, that's an easy way to bend that section. If you look along the pinch weld toward the front, you'll see a section that is a little thicker. It has a circular thing above it. Center the slope of the jackstand there and raise it to where it's as close as possible and lower the car gently.
| The Following User Says Thank You to ApexEight For This Useful Post: | Tcoat (08-23-2017) |
#136 | |
Drives: '13 BRZ
If I got a puck with a slot, since the inner and outer depths are different, all the weight would rest on the inside part of the pinch seam. So, all I really need is a slot that is 1/2" deep, since the puck will not be touching the outer part of the seam. Does that make sense? |
#138 | |
Drives: '13 FRS - STX
Jack stands; only if they are worn out, poorly made, or if the jacks aren't sitting right (i.e. the car is cockeyed on some angle and the jack is not sitting on it's feet properly, certainly possible with how you jack it up), visual inspection for cracks or rust that compromises strength on a regular basis is a must and it's simple to give them a once over before you start using them. Jacks are typically hydraulic or mechanically activated, those mechanisms can fail much more easily than a chunk of simple metal that is a jack stand. But I presume you just meant jack stands. |
#139 |
Drives: 2017 BRZ PP
#140 |
Drives: Neptune GR86
This might be a silly question... but if the pinch weld is still making full contact with the jack, what's the purpose of this?
| Jacking up car - using garage jack | NYNOMAD | BRZ First-Gen (2012+) — General Topics | 2 | 06-27-2012 09:36 AM |
| Front jacking point | dsgerbc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-30-2012 06:19 PM |
| Supporting Mods | Double4Free | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 02-21-2012 06:33 PM |
| Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. | Mitch | Other Vehicles & General Automotive Discussions | 43 | 01-09-2012 09:07 AM |
