Old 11-28-2016, 01:27 PM   #71
gramicci101
Off Topic
Originally Posted by switchlanez View Post
do they rub the bumper tab on the outside with 265/35-18 tires?
Sent from my Pixel using Tapatalk
The guys in the meaty tire thread should be able to answer that. @Jive Turkey's initial post suggests that the rear will rub on the bumper tab unless you trim it.
Old 11-30-2016, 12:55 AM   #72
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
yup will rub, so either trim it diagonally to cut the corner off or let your tires trim it for you.
Jive Turkey is offline   Reply With Quote
Old 08-09-2017, 09:51 AM   #73
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Customer BRZ on black Mach V Awesome wheels, and Mach V springs.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 08-17-2017, 06:31 PM   #74
jlimNW
Drives: 2017 Toyota 86
--Dan
Mach V
Hey Dan,
I have a 2017 86 that's lowered 1" using TRD springs. Would I have any fitment issues in the front? I saw that the springs used by the BRZ above is lowered .75" in the front.
I've been referencing the flush offset spreadsheet and it says +42 offset at 17x9 will work, but not necessarily with a 1" drop. Any insight? Love the wheels, would love to pick them up.
Thanks in advance for any info, and sorry if this has been asked already. Tried searching but my google-fu is rather weak and my forum searching abilities seem even worse.
EDIT: Think I found a user that has a similar situation. It appears it's a no-go without some camber and/or spacers. Guess it's back to the hunt for wheels again.
jlimNW is offline   Reply With Quote
Old 08-22-2017, 09:23 AM   #75
Mach V Dan
That depends on what tire you run, but I doubt a 0.25" difference is going to matter much. Note that the suspension compresses under loads and bumps no matter where your lowering starts out. That is, as the tire moves through its travel, it can rub no matter if the car is at full height or lowered.
Many of our customers run them with a 1" drop.
I don't follow your logic. Camber will tilt the top of the tire in. Spacers will push the tire out. Those are opposite actions. What exactly are you concerned about?
I never had ANY rubbing on my car with 255/40R17 tires. A 245/40R17 is a better choice (since it's closer to the stock tire diameter) and would be an easier fit since it's 10mm narrower.
--Dan
Mach V
Old 08-22-2017, 01:43 PM   #76
jlimNW
--Dan
Mach V
Ahh, sorry I'm not making sense. It's all rather new to me so I'm learning everything on the fly. I didn't fully understand camber at the time.
I was trying to figure out how to get these wheels flush or near flush on a 1" drop. I was referencing the flush wheel offset chart. It seemed as though with a 48 offset being flush, 42 would be poking out about 6mm.
I guess I was trying to ask how to get these wheels flush or is it impossible? Since it's not possible to increase offset, would it only be possible to have both wheels flush with each other and not the fenders (both poking out 6mm)?
Sorry for the confusion!
Old 08-22-2017, 11:21 PM   #77
Mach V Dan
They don't really poke out. The fronts are pretty much flush to my eye; the rears are slightly inset.
Just look back through this thread. They fit. If you like the style, price point, and weight, run the wheels.
--Dan
Mach V
Old 08-27-2017, 08:28 AM   #78
Hostile_Kittens
Hostile_Kittens's Avatar
Drives: 2015 Subaru BRZ
I do wish the offset was a little lower. I run a about 3.5* camber and needed a 3mm spacer to be comfortable with my wheel clearance.
Hostile_Kittens is offline   Reply With Quote
Old 04-19-2018, 11:00 PM   #79
TorqueMan777
TorqueMan777's Avatar
Drives: 13 BRZ, 18 STI
Just picked these up a few days ago, can’t wait to get tires on them and get them on the car!
Racecar spelled backwards is racecaR, because RacecaR
TorqueMan777 is offline   Reply With Quote
Old 03-28-2020, 12:08 AM   #80
sroby
Drives: 2015 Firestorm 08/05/15
Center caps
Originally Posted by CrazyWookiee View Post
These look almost just like the 5Zigen FN01R-C's.
I know it’s an old picture. But do you remember where you got those particular center caps ? I’d like them on my Mach v 18,s.
Thx so much STEVE
sroby is offline   Reply With Quote
Old 05-08-2021, 12:34 AM   #81
Vesartis
Vesartis's Avatar
Drives: 2016 Subaru BRZ Series.HyperBlue
Matte Bronze on my HyperBlue BRZ
Vesartis is offline   Reply With Quote
awesome, mach, wicked awesome
Mach V Awesome wheels Mach V Dan Wheels and Tires 187 11-18-2022 09:18 AM
Wheel Directory: Mach V Wicked Awesome 18x9.5 +42 Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 11-21-2013 10:36 PM
Wheel Directory: Mach V Awesome 17x9.0 +42 / 18x9.5 +42 Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-04-2013 10:21 PM
FS: Mach V Awesome NIB Silver Socal RiskyTrousers Wheels and Tires 8 03-02-2013 10:54 PM
