Old 08-21-2017, 09:08 AM   #29
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Originally Posted by churchx View Post
@JazzleSAURUS & @Shark_Bait88 - what i'm complaining about - that there is no such info in wheel directory. I'm sure there are other 15" that will fit over stock brakes too .. but that info cannot be found easily in this forum, even while might be of interest for many (for winter driving)
Shark_Bait88: if/when you'll meet him, would be nice to get offset and such also for those Tom's wheels you mentioned. The more confirmed/known, the better.
JazzleSAURUS: can you try those Enkei-s RCG4 from Forester also on twins? Just to check clearance (and if fit, what width/what offset)?
Hey @churchx I had actually tried them on my BRZ before I tried them on the FXT. They didn't clear, first touching the brake caliper, then when a 20mm spacer was tossed on, they touched the hub where the tie rod meets it.
While playing around on @LiftedBRZ s car, we confirmed that they DID clear WITHOUT spacers when we converted the front brakes to Subaru OEM 4 pots, the brake package that was in mind on the group n cars when the RC-G4 was being developed.
Hope that's helpful, I actually was hoping to run the RC-G4's on the BRZ, and keep running the 16" '00 5 spokes on the Forester, but when all was said and done I was very happy with the results...
A brake package any bigger than 4 pots is very unlikely to fit!!
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Racecomp Engineering (08-21-2017)
Old 08-21-2017, 09:13 AM   #30
JazzleSAURUS
EDIT: Double post :O
Old 08-21-2017, 09:33 AM   #31
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Soloside: i highly advise not to run staggered especially in winter. Imho on low grip situations such as on ice/snow that understeer will show through even more ugly :/.
Alright thanks for the advice. I'm gonna see if I can some how find a set of used17x9 or 17x8 RPF1's locally to me for sale so I can throw them up as my winter set.
If all else fails, I'll 17x9 rota them.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 08-21-2017, 09:56 AM   #32
JazzleSAURUS
Do you have your stock wheels still?
Getting a more narrow, taller snow tire is beneficial as opposed to something wide.
215/50-17 on the stocks would be mint.
why? (09-07-2017)
Old 08-21-2017, 10:18 AM   #33
Soloside
Unfortunately I sold my stockers.
2014 Subaru BRZ
Old 08-21-2017, 10:20 AM   #34
JazzleSAURUS
Get a set used with a dash of curb rash for a hundred bucks! A lot of people used their stockers for winters so there's a chance you could even pick a set up with used winter tires already on them.
Something wide like that 17x9 will be horrible in the snow on a car this light!
You can also look for stock WRX wheels, (02-05 wheels are PLENTIFUL and cheap!)
Hope one of those options works out for ya.
Old 08-21-2017, 10:54 AM   #35
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I recently picked up a set of stock BRZ wheels with no tires or TPMS for $60! The deals are out there.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post:
JazzleSAURUS (08-21-2017), why? (09-07-2017)
Old 08-21-2017, 10:56 AM   #36
churchx
churchx's Avatar
Drives: 2014 GT86
+1 to wrx 16" wheels. Used borrowed set of them just fine through last winter (for next bought own 16" set). About only "drawback" - wheels look very tucked in due deep offset of wrx wheels. Nothing bad for handling, and as already noted, they are plentiful & cheap, and look much better then steelies.
Old 08-21-2017, 11:15 AM   #37
Shark_Bait88
Bugeye 16x6.5 wheels are great for winter.
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
why? (09-07-2017)
Old 08-21-2017, 12:37 PM   #38
JazzleSAURUS
Glad you guys are rocking the 02-05 WRX wheels!! The sunken in aesthetic is fine for me, I run 20mm spacers with WRX fitment summers too, so it pushes them out to just the right place and I don't have to change up different spacers for it to look good.
If you're running a 'regular person' spacer, they'll look great. And the wheels actually look really tough with a tall sidewall AT/Winter.
Old 08-21-2017, 10:03 PM   #39
JazzleSAURUS
Originally Posted by kneercirl View Post
In your opinion, which tire is better for deep snow/slush? The Blizzak or Scorpion. I plan on mounting one of these two on my stock 20" wheels next month
20" wheels...stock?
Blizzaks are great but don't last long. Arctics are better in deeper snow, and last much longer.
why? (09-07-2017)
Old 09-06-2017, 10:31 PM   #40
~el~jefe~
Drives: 2019 MX-5 RF
there really is no or not much of a reason to get a smaller tire width for winter. the contact patch is determined by the weight of the car, not the tire one gets. You use a 125 width tire, the tire will contact the same amount front to back and just looks squished. At a certain point this is exaggerated, like if you got 305 tires, then youd have a lot of extra stuff contacting snow. But going from 215 to 205 is very small amount but will reduce the engineered and tested design of the car. I can see however that it is a cheaper tire and that is great x4. But that is it. A proper snow or for me, performance winter, is more important than the narrower part. Dont you people drive on dry roads like 50% of the winter once it thaws out?
~el~jefe~ is offline   Reply With Quote
The Following User Says Thank You to ~el~jefe~ For This Useful Post:
why? (09-07-2017)
Old 09-07-2017, 04:09 AM   #41
churchx
churchx's Avatar
Drives: 2014 GT86
~el~jefe~: i drive "on dry roads" (cleaned up from snow/ice with salt mostly) in city 95% of time. BUT! I prefer to ready car for worst cases. It's those 5% that can prevent you from going or add a lot of time to get to those 95%, those 5% where you may lack traction on countryside road/iced uphill/unplown yard or road/right after heavy snowfall & not yet cleaned/to avoid crash/etc. I want to be able to rely on car to get me where and when i need and for that i need good proper winter tires, not just something that somewhat may do.
why? (09-07-2017), Yousend (09-07-2017)
Old 09-07-2017, 08:21 AM   #42
Yousend
Drives: 2014 FR-S
It's not like push the car anywhere near its limit in the winter on dry pavement... No comment on roads with fresh show though.
Yousend is offline   Reply With Quote
Meaty Tire Thread Jive Turkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2552 12-28-2025 10:06 AM
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Do we have a tire weight thread? Ashikabi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 06-30-2017 08:51 PM
Yet Another Summer Tire Thread zberz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 04-29-2017 01:25 PM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
