Old 08-14-2017, 08:18 PM   #15
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by wparsons View Post
I'd say I'd take the diff, but I don't even want to guess at how bad shipping would be up to Canada.
Pm me we can figure it out
ILLSMOQ is offline   Reply With Quote
Old 08-14-2017, 08:32 PM   #16
ILLSMOQ
I installed most of the parts for the back half of the car today.
Gotta figure out where to mount the resiviors for the shocks still.
This kit is beefy....fits very tight but it fits well. Overall I'm impressed with it.
I had to grind the knuckles so the larger axles would fit.
The front portion of the diff is a solid mount and the mount bosses are offset on the square tube mount. If you mount it backwards the diff won't fit.
Let me know if you have specific questions, I changed so many parts today, I can't recall any other installation tips I might have on the diff.
Only real complaint is that it didn't come with the drive shaft to diff flange bolts...And more annoyingly, they didn't bead blast the housing...it's a rusty mess that they simply soaked with black paint. Not that big a deal but every time something touches it rust flakes off.
Big axle shafts
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Sportsguy83 (08-16-2017)
Old 08-14-2017, 11:19 PM   #17
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
We have had to clearance the knuckles for every dss pro kit axle outer. You would think they would mention that by now lol
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
ILLSMOQ (08-14-2017), slicktop (08-21-2017), Sportsguy83 (08-16-2017)
Old 08-14-2017, 11:49 PM   #18
ILLSMOQ
Some simple instructions/tips would have helped too, but if you're experienced enough to take on a swap like this...I guess the little things are no brainers.
Old 08-15-2017, 02:18 PM   #19
rob 2fast4u
rob 2fast4u's Avatar
Drives: 2JZ BRZ
hey man I'll be taking out my whole rear end... if you want it let me know Im in Nova Scotia
rob 2fast4u is offline   Reply With Quote
Old 08-21-2017, 01:51 AM   #20
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Yep, a few millimeters here too.
As for my rear end, I have a solid mounted 8.8 in the car now. Rebuilt w/ 3.55 gears which are a little too tall I think. Might go back down to a 4.10.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
wooly35 (08-21-2017)
Old 03-12-2018, 03:39 AM   #21
Gokart86
Drives: Black GT86
Dear All experts,
My name is Alex, from Malaysia, actually the Borneo side. I’ve just got a used AT GT86 to start a build. Actually my first intended mod to my build is actually shorter final drive. Due to the location I’m at, there’s like only 1 tuner who are familiar with our cars. He told me that I have to get a full kit for example all the shims, bearings, etc (not just ring and pinion)
I’ve been lurking around the forum regarding final drive parts. I’ve read some posts tons of times and still do not dare to pull the trigger of getting a full rebuild kit which is meant for Supra Mk3 which is suppose to be indentical to our cars.
My question is if the internals/guts for a Supra mk3 read differential is identical to our FRS/GT86? I meant not just the ring and pinions but all the spacers, shims , bearings nuts,etc..
Over here, it’s very hard to source for any parts locally being a third world country. And most parts we have to Import from overseas. So for the final drive there pinion and rings are easier to source however, the other small parts needed is a big problem. As they are just so many small parts to make a proper build.
After sometime of reading in the forum and sourcing online, I’m looking at this rebuild kit from drift motion to go along with a 4.56 on an A/T 86 for my build. As for 4.56 ratio is due to my build is actually heading towards a SC kit in the future.
http://www.driftmotion.com/DM-MK3-29...t-p/dm3462.htm
Would this be compatible with our stock GT86/FRS carrier?
Looking forward to all your experts replies. Many thanks in advance.
Rgds, Alex
Gokart86 is offline   Reply With Quote
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
2JZ swapped BRZ ... rh9 Engine Swaps 32 12-08-2014 01:50 AM
How many of you Swapped your 86 for 15 WRX ? Xti Scion FR-S / Toyota 86 GT86 General Forum 45 08-09-2014 09:09 AM
BRZ Swapped with LS2 weedtank FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 09-05-2013 05:02 PM
