go_a_way1, MisterSheep
Old 08-19-2017, 11:57 PM   #17347
arxm
Drives: 2013 FR-S, 2023 BRZ
If you get spacers you have to get extended lugs(at least I had to with my XXRs). New tires may be best. Might have to go significantly skinnier though... Do you have room for spacers?
darn, id need longer lugs even with just a 10mm spacer? i cant go any skinnier because these 235's are ever so slightly stretched as it is
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 08-20-2017, 12:06 AM   #17348
Ashikabi
Ashikabi's Avatar
I got 5mm spacers and had to get lugs. But my XXRs might have had more meat between the lug well and the mount face than stockers or whatever you may have. The lugs weren't that hard to replace but you'll need extended lug nuts too. Are you lowered? If not, you can get coilovers cuz they are much skinnier than stock springs. I dunno if they still have them but IAG performance had a set of ST coils in their used items for $300.
Old 08-20-2017, 12:44 PM   #17349
arxm
darn im on xxr's too and lowered on eibach springs, i found a set of 10mm spacers with extended lugs on FT86sf for a decent price i might get those but for the meantime can my tires damage the spring? I care less about the tire than my springs since i get almost free tires
Old 08-20-2017, 02:45 PM   #17350
Ashikabi
Ashikabi's Avatar
I don't see it damaging the spring. I'd get some bed liner or undercoating spray to shoot your springs with when you get the interference worked out. Just don't want them to rust
Old 08-20-2017, 06:21 PM   #17351
Hey folks .......I washed my FR-S .....and dried it off ...... yep, the whole car ...... including the wheels ...... in one session .......
Now, even after the wash, the water still beads up ....... does that mean I don't need to wax it ......??
Old 08-20-2017, 06:30 PM   #17352
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
washing your car with a good car wash will not remove the wax. If the water beads up you are good.
fx1mark is offline   Reply With Quote
Old 08-20-2017, 06:34 PM   #17353
Yaaaaaa !..........THAT'S what I want to hear ........
NOW, it can be nap time ..........
Old 08-20-2017, 07:16 PM   #17354
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Did you say beading?
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 08-20-2017, 09:41 PM   #17355
Island beads ....... really small ......
Old 08-20-2017, 10:09 PM   #17356
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Did not fall?
Old 08-20-2017, 11:12 PM   #17357
Did not fall?
Nope, did not fall ...... quite the opposite.
After squatting down to wash the 4th wheel, I almost couldn't stand back up ....
Old 08-20-2017, 11:38 PM   #17358
Ashikabi
Ashikabi's Avatar
Get a mechanics stool. With the casters on it
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (08-21-2017)
Old 08-20-2017, 11:53 PM   #17359
....... but, but ...... my driveway slopes down .........
However, that does give me an idea.
With this, then I could also wax the lower half of the car (for the first time) ....
Thanks!
Old 08-21-2017, 11:23 AM   #17360
Sapphireho
Famous Potatoes
Sapphireho's Avatar
After 1 ankle, and two knee surgeries, I got me one of those roller stools down at the Pep Boys. I only have to go down once, roll around and wax the bottom half and do the tires and rims, then one up. Has a tray under the seat to hold wax/tire black. Love it.
humfrz (08-21-2017), notout86 (08-27-2017)
