Old 08-13-2017, 08:24 PM   #477
86Craze
Drives: 2016 FR-S
Originally Posted by SuperTom View Post
I love my MeisterR they have softer spring rates which make daily driving perfect with an aggressive drop.
Thanks Tom. I picked up the Flex Z set last week. 86 speed was having an 8/6 sale with 86 bucks off on a set of Flex Zs. Haven't installed them yet, the car is mid turbo kit install right now.
86Craze is offline   Reply With Quote
Old 08-19-2017, 10:16 PM   #478
moK
Drives: White BRZ
I've had these for about a year but I'm still having trouble finding the perfect comfort setting for them. Setting them softer (10 or 11s) feels decent on these crappy LA freeways, but they feel like bottom out going over low speed speed bumps or surprise potholes. Setting them stiffer (8-9) stops this to an extent, but feels pretty jarring on the freeway. Im currently about 3/4ths of an inch lower on stock tires running about 32psi all around just to make the ride more comfortable.
What softer sidewall tires do you guys recommend? I've seen Extremecontact DW and PSS being thrown out pretty often.
moK is offline   Reply With Quote
Old 08-19-2017, 10:49 PM   #479
Teseo
Drives: frs
Why you went coilovers first place?
Old 08-19-2017, 11:54 PM   #480
Kaotic Lazagna
Drives: GR Corolla
That's odd. I have mine beyond maxed out in the front in terms of lowering (removed the locking rings) and had to adjust the pre-load in the rear to match the height. I have the dampening set to the middle, and imo, it rides almost the same as stock, except for going in really low speeds over bumps. Also, I have my tires set to 40 psi.
Shoot, it rides more comfortably than my Yaris that sits on Tein S.Tech springs on OEM dampers.
Old 08-21-2017, 04:27 AM   #481
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
Try EDFC man !
Envoyé de mon T6pro en utilisant Tapatalk
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 08-21-2017, 12:55 PM   #482
KnightRyderx2
Drives: 2014 FR-S
Originally Posted by KingBaeless View Post
I Would Only Be Using For Street Driving, Thanks For The Feed Back.
How Low Are You?
I am at the lowest in the rear; the front can go another 1/3" or so. I forgot to measure the before to compare.
KnightRyderx2 is offline   Reply With Quote
Old 09-26-2017, 11:51 AM   #483
fl4t ftw
Drives: 2013 DGM BRZ, 2016 FiST
Hi all. I just got around to installing these on my BRZ. I have the rears maxed (I think), but there’s still like an inch and a half of thread left on them. I can’t imagine they’re all the way to the bottom of the lower mount. They’re advertised as a 3” drop max in the rear. I’m nowhere near that and had zero issues with the front hitting my desired height. I still have like a 1” wheel gap in the rear. Any ideas what’s going on?
fl4t ftw is offline   Reply With Quote
Old 09-26-2017, 02:48 PM   #484
Kaotic Lazagna
Drives: GR Corolla
You'll need to adjust the pre-load in the rear now since you've maxed out the shock length. That's what I had to do.
Old 09-26-2017, 07:30 PM   #485
fl4t ftw
Preload is an independent adjustment on these coilovers. I’m just very surprised that I already maxed out the shock. I suppose I could try to go absolutely minimal with the preload, which will slightly increase droop, and drop the height a bit, but I can’t imagine there is any “normal” way to get the advertised 3” drop in the rear.
Old 09-26-2017, 08:24 PM   #486
Kaotic Lazagna
Drives: GR Corolla
I think the advertises included preload.
Old 09-26-2017, 08:33 PM   #487
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I believe the recommended drop is with recommended preload. Going into the maximum range, you'll have to lower the preload (essentially shortening the shock travel)
EndlessAzure is offline   Reply With Quote
Old 09-27-2017, 12:45 AM   #488
fl4t ftw
Thanks guys. So basically just try to minimize preload? Should I just snug it so the spring doesn’t move around?
Old 09-27-2017, 02:05 AM   #489
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I think your real issue is you live in the wrong city.
The Following User Says Thank You to chaoskaze For This Useful Post:
moK (09-29-2017)
Old 09-27-2017, 04:30 AM   #490
EndlessAzure
Wheels for Brains
That should be okay. I don't recommend unloading the spring more than necessary. If you do, just be extra cautious when you approach moderate bumps.
It happened to me accidentally on my Tein Flex A's, and I started bottoming out way more than normal. Luckily I checked and fixed the preload quickly. See here
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
