go_a_way1, MisterSheep
Old 08-18-2017, 09:01 AM   #17319
Originally Posted by nextcar View Post
These cars came as monospec... but the port of entry could add items like floor mats, trunk liners, etc which would affect the vehicle weight as delivered. This sticker reflects the weight of the port added options to your car.
Correct. In fact there was a recall associated with these stickers in cars that came through Southeast Toyota.
Old 08-18-2017, 09:22 AM   #17320
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
Gave my baby an early diaper change.
Changed the oil (yes full synthetic 0-20) and filter (yes OEM) at 2500 miles.
And before all the 'Stick to the manual' purists start berating me I am aware of all the pros/cons of changing the oil before the recommended 7500 miles.
Believe me, being a lot older than most of the puppies on this forum waiting till 2500 mile to switch out the oil was killing me.
Also sent away oil sample to Blackstone labs so I have a baseline analysis.
"May the N.A. force be with you".
Darth Khan is offline   Reply With Quote
Old 08-18-2017, 09:27 AM   #17321
15limited
15limited's Avatar
There's cons to changing your oil before its recommended? 🤔
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 08-18-2017, 09:35 AM   #17322
Darth Khan
Darth Khan's Avatar
"There's cons to changing your oil before its recommended? "
There is a "theory" that new cars come with 'Factory Break In Oil' which has added additives to protect the engine during it's 'Break In Period'.
And of course there is the waist of money argument (40 bucks for a 25-30k car.... really)
Old 08-18-2017, 09:40 AM   #17323
15limited
15limited's Avatar
Yeah I've heard that, but doesn't make sense to me. IIRC the Subaru dealership I went through even recommend the first change at 2.5-3k miles. I guess when you get your Blackstone results we will know for sure.
Old 08-18-2017, 01:00 PM   #17324
PDM 2
Pokemon Master
PDM 2's Avatar
Drives: 2014 Scion FR-S
Friend pointed out left side of my GCS 4th brake light was fading. After only 3 months of installation, wires properly tucked and protected from water .. Emailed supplier, hope they can do something about this for me.
'10 MazdaSpeed 3 Velocity Red Mica - SOLD
PDM 2
'14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS
PDM 2 is offline   Reply With Quote
Old 08-18-2017, 02:03 PM   #17325
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Could be insufficient power. Where are you drawing power from?
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
Somerandom18 (08-18-2017)
Old 08-18-2017, 02:31 PM   #17326
Were they off by a couple of grams ......
Somebody in the government needs to get a real job .....
Old 08-18-2017, 02:36 PM   #17327
DANG! ....... pops ...... snap out of it ....... we aren't back in the 40s anymore .......
Clipdat (08-18-2017)
Old 08-18-2017, 02:58 PM   #17328
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
looks to me like you lost an LED. If they won't replace it you should be able to take it apart and repair it fairly easily. most likely a bad solder joint.
fx1mark is offline   Reply With Quote
Old 08-18-2017, 03:45 PM   #17329
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Ok, I lied. Mine is not blank, just zeros, and they put it on the outside of the door jam. What laws am I breaking if I take it off?
Old 08-18-2017, 03:47 PM   #17330
No laws for the owner that I am aware of. The dealer selling it new is the only one the requirement would cover.
Dadhawk (08-18-2017)
Old 08-18-2017, 03:48 PM   #17331
PDM 2
Pokemon Master
PDM 2's Avatar
Powers drawn from driver side tail light. Also, yeah if they deny warranty i'll probably try and do that. Literally just bought this 3 months ago
PDM 2
The Following User Says Thank You to PDM 2 For This Useful Post:
Tcoat (08-18-2017)
Old 08-18-2017, 03:50 PM   #17332
Originally Posted by stranger things View Post
I bought my car used a few months ago and just noticed a sticker in the door panel area. Not that I car about 4 lbs. carrying capacity, but does anyone else have this sticker? Just curious what it actually means.
2 Kg or 4 pounds?
No wonder the US gets messed up with metric.
Dadhawk (08-18-2017), new2subaru (08-18-2017), Sapphireho (08-18-2017)
