| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: Scion FR-S 10 Series
Michelin X-Ice Xi3 have great cold weather, dry road handling and great braking on ice. Blizzaks have very soft compound in the cold and bad handling on cold dry road but will stop for you. The tire seems to roll over onto itself during turns and fast ramps. However, they are excellent choice for our cars for areas with lots of snow since the tread pattern is chunky. Probably the best tires if you never want to get stuck in snow (blizzaks).
With regards to tires for area with little to no snow all winter. I would go for Michelin X-Ice Xi3 and take off max performance summers or stocks when weather is below 7degC. -Z |
#16 | |
Drives: DGM BRZ
In my All season recommendation I was still assuming it was a second tire set. Summer tires in summer and all seasons on during the mild winter. |
#17 | |
Drives: 2016 BRZ
#18 |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Going to put this out here. I'm not trolling by posting this.
I currently daily my widebody boosted 86. I've gone thru two winters being just on stock body without many hiccups running blizzaks. Question is now that I'm on a widebody set up, do I treat it the same way as I would normally? just get wider tires to compliment the new set up? I read somewhere that you generally want to go down a size on the rim size and width? can anyone confirm?
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
#19 |
Only users lose drugs.
Drives: All the time
Well, do you want it to look good or perform well? If you're after good winter weather performance, bolt on a set of 205/55-16 winter diggers. They'll look weird in a widebody, but I'd rather get some odd looks than slide into a tree in slush/snow.
I suppose you could get spacers to push the skinny wheels/tires out a bit under the flares...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#20 |
Drives: 2014 GT86
Pitty there is only one 15" listed with confirmed fittment for ours in wheel directory. Imho 15" would be THE wheel/tire to go for winter :/
#21 |
Drives: 15 BRZ LTD, 05 FXT
I run 185/65-15 Arctics on 15" Enkei RCG4's in winter on my Forester XT. It's glorious.
#22 | |
Drives: 2013 Firestorm FR-S
![]() I'd love to find a set of those and use them in the winter too.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#23 | |
Drives: 2014 FR-S
Running Nokians never gave me any issues. Sure, it's the only tires I've used on the car in the winter, but they're definitely one of the best brands for winter tires. Might be a bit more expensive up front than cheaper brands, but road hazard can come in handy if you get unlucky.
It's also good to know that if you fuck up, it wasn't the tires. Getting into an accident due to cheap tires can easily cost you more than the difference between the tires. Safety first. Quote:
#24 | |
I do have a set of 16s on steelies I can use... what's the rule of thumb? Winter sets should be not as wide as stock right?
2014 Subaru BRZ
#25 | |
Give or take ish. Meanwhile I have no regard for the speedo, and pick the tire I want... brb 185/65-15
#26 |
so I should be running like 17x9 fronts and 17x10 rears XDXDXD
2014 Subaru BRZ
#27 |
Drives: 2014 GT86
Soloside: i highly advise not to run staggered especially in winter. Imho on low grip situations such as on ice/snow that understeer will show through even more ugly :/.
#28 |
Drives: 2014 GT86
@JazzleSAURUS & @Shark_Bait88 - what i'm complaining about - that there is no such info in wheel directory. I'm sure there are other 15" that will fit over stock brakes too .. but that info cannot be found easily in this forum, even while might be of interest for many (for winter driving)
![]() Shark_Bait88: if/when you'll meet him, would be nice to get offset and such also for those Tom's wheels you mentioned. The more confirmed/known, the better. JazzleSAURUS: can you try those Enkei-s RCG4 from Forester also on twins? Just to check clearance (and if fit, what width/what offset)? |
| Meaty Tire Thread | Jive Turkey | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2552 | 12-28-2025 10:06 AM |
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Do we have a tire weight thread? | Ashikabi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 06-30-2017 08:51 PM |
| Yet Another Summer Tire Thread | zberz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 04-29-2017 01:25 PM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
