Old 07-17-2017, 08:02 PM   #43
Jakinit
Drives: 2017 CWP BRZ Limited (MT)
Just got my toycam3 and something isn't right. The picture below shows the harness that came with the radio on the left and the toycam3 on the right. Others have had this just plug and play, but mine are clearly different. The one that came with the head unit plugs into the car just fine. The toycam 3 does not. Am I just an idiot?
Jakinit is offline   Reply With Quote
Old 07-17-2017, 08:57 PM   #44
HBKeazy!
Drives: 2017 Toyota 86
Kenwood DDX917WS head unit -- any installed?
For subarus you need the ax-subusb2 and you need to make a custom harness from the ax-sub28swc, you can also make the oem aux port to work with this harness.
HBKeazy! is offline   Reply With Quote
The Following User Says Thank You to HBKeazy! For This Useful Post:
Jakinit (07-18-2017)
Old 07-18-2017, 12:06 AM   #45
Jakinit
In addition to what HBKeazy! Shared this guide is excellent.
http://www.ft86club.com/forums/showthread.php?t=111866
He also found the guide.
The Following User Says Thank You to Jakinit For This Useful Post:
HBKeazy! (07-18-2017)
Old 07-18-2017, 04:40 PM   #46
willimusk
willimusk's Avatar
Drives: 2017 BRZ PP CWP
Originally Posted by Krion View Post
The issue is with their harness. I forget exactly what the audio guy I took my car to said but it did indeed have something to do with how it's connected to the amp. He ended up wiring something in and now it's fine.
Sorry, I know that probably doesn't help too much!
Actually, you helped a lot. I took mine to a local shop and explained. They found that the remote trigger for the amp was not wired. Took all of a minute to fix. Carbon will definitely have to address this if they plan to sell more units to US buyers. Perhaps Aussie HUs are wired a little differently.
Anyway, all's well now. Damn, this unit sounds good with real bass!
Thanks again.
willimusk is offline   Reply With Quote
The Following User Says Thank You to willimusk For This Useful Post:
Old 08-17-2017, 03:18 AM   #47
matty100
Drives: Subaru BRZ
Oem camera
If I have a 2017 BRZ that came with backup camera do I need to get the 12-6v AX tomcam3 adapter?
Does the FM radio work in the states ?
matty100 is offline   Reply With Quote
Old 08-19-2017, 12:23 PM   #48
Jakinit
Yes to both questions. The radio works, and you need to drop the voltage to 6V for the camera.
Old 04-25-2018, 01:36 PM   #49
Oliverklozov
Drives: 2014 Subaru Impreza WRX Hatchback
DDX917ws compatible with 2014 WRX Base Hatch
Hey guys, I'm looking to get a Kenwood DDX917WS from fasmoto shipped to Canada. Just wondering if anyone has any experience with installing this unit into a North American WRX. I see a few have done it in a BRZ but I want to make sure it will be compatible with my WRX. Any info would be much appreciated.
Oliverklozov is offline   Reply With Quote
Old 04-26-2018, 09:40 AM   #50
ncted
Drives: 2017 BRZ Limited
Does the 2014 WRX have a 200mm dash opening for the head unit? I can't find any documentation to that effect. Most non-Toyota cars do not have 200mm openings. Perhaps you should ask over on nasioc.com?
ncted is offline   Reply With Quote
Old 04-26-2018, 05:50 PM   #51
gpvecchi
gpvecchi's Avatar
Guys, if you're interested DDX918WS came out: practically same specs, except for a little smaller screen but 720p.
Any chance of region change on 917?
Old 04-26-2018, 10:48 PM   #52
Oliverklozov
Yes is does. I'm more concerned with the wiring. I still want all my OEM steering wheel controls and usb/aux ports to work. Also I've heard that the tuner doesn't pick up the same frequency.
Old 04-26-2018, 11:11 PM   #53
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
I had the 917 and now the 918. Everything works on my 86 except dvd as it is region locked.
el-guapin is offline   Reply With Quote
Old 04-27-2018, 02:01 AM   #54
Oliverklozov
Really hope it fits my 2014 WRX. How much of a difference is the 917 to the 918? Is it worth the price difference?
Old 04-27-2018, 12:17 PM   #55
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
The viewable screen size is smaller in the new 918. BUT it is HD. There are new settings, icons and better sound processor. My main reason to upgrade was the ability to control the optional Whetron Cameras for 360 viewing. Im still waiting for those to become available.
Old 04-27-2018, 12:40 PM   #56
ncted
Why would the tuner not work? FM in Australia is 87.5-108 MHz. FM in US is 88-108 MHz. Things like HD Radio and tags might not work, but the stations should tune just fine.
Kenwood DDX916WS head unit -- any installed? willimusk Electronics | Audio | NAV | Infotainment 39 07-27-2017 11:47 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 04:37 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 07:44 PM
Soo i installed a new head unit....gaps Sniper2606 Electronics | Audio | NAV | Infotainment 2 01-16-2014 06:12 PM
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 01:07 PM
