Old 07-25-2017, 06:47 PM   #533
MrDinkleman
Drives: 2016 Oceanic, "base" model
Originally Posted by icybrzzz View Post
email em to me and I'll resize em for you. Very easy to do...
alexandercocar@gmail.com
Thanks but I need to take a couple "along the fender" views to show the poke/non-poke anyway...
MrDinkleman is offline   Reply With Quote
Old 07-25-2017, 10:13 PM   #534
MrDinkleman
So, here we go.
And one last data point I forgot to list: with this setup, I can stuff a roll of 1" masking tape between the inner sidewall and the springs. So call it 7/8" clearance between front tire and spring seat.
And it needs a bit of lowering...
The Following 6 Users Say Thank You to MrDinkleman For This Useful Post:
funwheeldrive (08-16-2017), icybrzzz (07-26-2017), new2subaru (04-14-2018), stevesnj (07-27-2017), surfwaxsmitty (07-26-2017), venturaII (07-26-2017)
Old 07-26-2017, 12:32 AM   #535
surfwaxsmitty
Drives: '14 BRZ 6MT
Originally Posted by MrDinkleman View Post
So, here we go.
It looks friggin awesome man! I was planning on these wheels if i couldn't find a set like I ended up with. There used to be just one pic of a white gt86 with front/side/rear lip kit which made it tough to compare to stock body panels. Thanks for the many pics, keep em comin.
Hope you enjoy them!! Nice tire choice too!
surfwaxsmitty is offline   Reply With Quote
The Following User Says Thank You to surfwaxsmitty For This Useful Post:
MrDinkleman (07-26-2017)
Old 07-26-2017, 11:38 AM   #536
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Looks good! That's the wheel I'd likely go to if I had to change from my current 16" setup.
The Following User Says Thank You to venturaII For This Useful Post:
Old 07-26-2017, 05:18 PM   #537
icybrzzz
Drives: 2015 Scion frz
Those 16" rpf1 with 205/45/16s sound like an awesome setup at 32lbs per corner!
icybrzzz is offline   Reply With Quote
The Following User Says Thank You to icybrzzz For This Useful Post:
Old 07-27-2017, 10:11 AM   #538
stevesnj
stevesnj's Avatar
Nice!
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
MrDinkleman (07-27-2017)
Old 08-14-2017, 08:17 PM   #539
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
The Following 6 Users Say Thank You to NLSP For This Useful Post:
KayC (08-17-2017), Lonewolf (10-30-2017), MrDinkleman (08-15-2017), new2subaru (08-14-2017), stevesnj (08-15-2017), venturaII (08-15-2017)
Old 08-15-2017, 09:43 AM   #540
venturaII
venturaII's Avatar
That's a good wheel size...what's the weight like on those?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 08-15-2017, 02:55 PM   #541
NLSP
NLSP's Avatar
If I remember correctly, they weighed in at 17.8 lbs/8.1 kg on my bathroom scale. The tire is listed as 22 lbs, so overall there isn't really any gain or loss of weight over stock.
Old 08-15-2017, 10:53 PM   #542
MrDinkleman
Noice!
I thought a five-spoke wheel with a polished lip would look awesome-r than multi-spokes and you've proven it.
Now to find some
The Following User Says Thank You to MrDinkleman For This Useful Post:
NLSP (08-16-2017)
Old 08-16-2017, 08:26 PM   #543
NLSP
NLSP's Avatar
Noice!
Now to find some
http://m.ebay.com/itm/4-ROTA-WHEEL-S...%257Ciid%253A1
Old 08-17-2017, 09:58 AM   #544
venturaII
venturaII's Avatar
Even better: Weight: 16.5 lbs
I thought the 17.8 lb weight sounded a bit heavy for a 16...even if they are 'just' cast Rotas...
Old 10-08-2017, 04:33 AM   #545
kuno
STi Rays TE07
16x7 +53
6.3kg/13.88lbs
225/50/16 Bridgestone RE003
Sent from my SM-G920I using Tapatalk
kuno is offline   Reply With Quote
Old 10-08-2017, 04:35 AM   #546
kuno
Sorry, missed the photo
The Following 2 Users Say Thank You to kuno For This Useful Post:
Racecomp Engineering (10-09-2017), Shark_Bait88 (10-30-2017)
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
