Old 08-15-2017, 11:32 PM   #15
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Correction: its like 86mph at 4k rpm, and 68 at 3k rpm.
mjanmohammad is offline   Reply With Quote
Old 08-15-2017, 11:53 PM   #16
spike021
spike021's Avatar
Yeah, I drove the freeway today and double-checked the numbers. 68-70mph is definitely about 3k rpm. Higher goes 3500-4000rpm.
spike021 is offline   Reply With Quote
Old 08-16-2017, 01:50 AM   #17
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
You can't set a cruise speed above 4k rpm, but you can set it below 4k and use the stalk to raise the speed.
Got it, same as the old cars then. I wonder if that's supposed to be some sort of a safety feature?
- The Ancient BRZ Sacrament
by Zaku
Old 08-16-2017, 01:20 PM   #18
qqzj
Drives: MDX, Camry
A much more efficient way of asking the same question is to just asking about the 6 gear ratios and diff. ratio. It will be very helpful if somebody can list all of them. It is widely known that the 17 has a smaller diff ratio. Not sure whether they changed gear ratio to compensate. I have a 13, and the differential final ratio is already too big for me as DD, I am actually thinking use a slight larger tire to lower the ratio. I do not need to be fast, just want to make the car less 'jerky' in the 1st gear.
I am actually thinking about using 225 45 R17 tires on stock wheels. The overall circumference is about 1.4% larger, i.e., less RPM at given MPH and slightly (5%) increase in sidewall to make the car more forgiving on harsh road surface. Has anybody tried this? Helpful comments will be greatly appreciated. Thanks.
qqzj is offline   Reply With Quote
Old 08-16-2017, 01:35 PM   #19
LudwigMiles
Drives: '13 BRZ
I always forget there is a 6th gear.
I am often cruising in 5th.
LudwigMiles is offline   Reply With Quote
Old 08-16-2017, 02:06 PM   #20
spike021
spike021's Avatar
I've actually done this a bit recently and just stuck in 5th longer rather than going right to 6th.
Burning oil (2017 manual) dostoyevsky Engine, Exhaust, Transmission 12 09-30-2019 02:38 PM
FI Options For 2017 86 W/6 Speed Manual impactblack Forced Induction 4 02-06-2017 10:03 PM
2017 FT-86 More power for manual but not for automatic transmission Yoniyama Scion FR-S / Toyota 86 GT86 General Forum 52 05-31-2016 09:01 PM
DFW Crusing 9/16 Recap! hostkiller FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 54 10-30-2012 03:34 PM
