Old 08-14-2017, 09:31 PM   #1
Ashikabi
Ashikabi's Avatar
OBD plug not working... Kinda
So I have a cheap OBD Bluetooth transmitter that works with my gf's 350z and her f250. It previously worked with my FRS. Now it refuses to work with my FRS. When plugged in to the other 2 vehicles a light on the Bluetooth unit comes on with the key OFF. In the FRS, no lights come on ever. I thought my plug was bad but my ECUtek dongle works fine. So why does my ECUtek dongle work but the Bluetooth doesn't? I already tried bending pins and I tried the Bluetooth with and without an extender
Old 08-15-2017, 12:10 AM   #2
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Mine gets lights but doesn't show up on my phone, determined it was an incompatible device with my phone :/
slizoth is offline   Reply With Quote
Old 08-15-2017, 12:22 AM   #3
Ashikabi
Ashikabi's Avatar
But I've already used it. That's the weird part. The unit doesn't even try to come on but works fine on the other 2 cars
Old 08-15-2017, 01:09 PM   #4
slizoth
slizoth's Avatar
Definitely strange, could be a bad connection. Make sure it's seated correctly and then trace the wires / check the fuse.
Old 08-15-2017, 02:55 PM   #5
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
The OBD2 port on the FR-S and BRZ is very finicky. It's easy to bend the pins if your OBD2 dongle isn't a perfect fit.
If you install and remove the dongle a bunch of times, it's pretty common to bend the pins.
As a first troubleshooting step, try using an OBD2 extension cable between the Bluetooth dongle and your car. $8 on Amazon: http://amzn.to/2vY3sU4
TofuJoe is offline   Reply With Quote
The Following User Says Thank You to TofuJoe For This Useful Post:
STV3 (08-15-2017)
Old 08-15-2017, 04:03 PM   #6
Ashikabi
Ashikabi's Avatar
Already did
Old 08-15-2017, 05:07 PM   #7
TofuJoe
Ohne Titel
TofuJoe's Avatar
@Ashikabi - your next option is to either try a different dongle, or re-pin the OBD2 port.
Old 08-15-2017, 05:11 PM   #8
Ashikabi
Ashikabi's Avatar
Do you have more info on repinning? Google didn't turn up squat for me but I may be using the wrong terms
Old 08-15-2017, 05:19 PM   #9
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
BT adapters don't last forever, luckily, they're cheap. Just get another one off Amazon.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-15-2017, 07:14 PM   #10
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
I've noticed the harness is wound REALLY tight, and I need to adjust mine sometimes to get my ecutek cable to link properly. Removing the tape and freeing up some slack may help. It's likely just one pin is being pulled back some or losing the crimp from the tension.
DIE1000DEATHS is offline   Reply With Quote
Old 08-15-2017, 09:29 PM   #11
TofuJoe
Ohne Titel
TofuJoe's Avatar
http://www.ft86club.com/forums/showthread.php?t=39137
Old 08-16-2017, 09:44 AM   #12
steve99
Drives: FT86
Fuse is blow
The obd port power is supplied by fuse
The Bluetooth dongle requires power from obd port
check for 12v on pin 16 of obd port
The Ecutek cable gets it power from laptop
Old 08-16-2017, 09:02 PM   #13
Ashikabi
Ashikabi's Avatar
Fuse is blow
No power to pin 16 but all fuses are good. Broken wire?
Old 08-17-2017, 06:28 AM   #14
steve99
Drives: FT86
https://www.google.com.au/url?sa=t&r...wTIabWl0Jc6WWw
Lnk to brz wiring diagram above
Search for OBD. Their is a specific OBD fuse 7.5 A pull it and check with multimeter
Its possible it broken wire but unlikely
What kinda bulbs? LordTaikun Scion FR-S / Toyota 86 GT86 General Forum 8 05-16-2015 02:33 PM
Getting OLD kinda sucks... blackhawkdown Off-Topic Lounge [WARNING: NO POLITICS] 44 06-13-2014 11:41 AM
Grammar help? (kinda random) DBacon1052 Off-Topic Lounge [WARNING: NO POLITICS] 3 12-14-2013 06:26 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 11:53 AM
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug sikest Electronics | Audio | NAV | Infotainment 7 01-21-2013 10:38 PM
