Old 07-04-2012, 07:00 PM   #1
HATED1
HATED1's Avatar
Drives: 86
Drifting the 86 Questions
Hey guys, just wanted to ask some questions for those who have drifted the 86 on a track.
1. Any overheating issues with the powersteering?
2. Any problems with the stock clutch as far as clutch kicking to initiate?
3. Is the e-brake sufficient to lock-up the rear? does it need to be adjusted?
4. Any over heating questions at all?
5. Is the stock LSD pretty aggressive?
thanks for any info you guys can provide.
HATED1 is offline   Reply With Quote
Old 07-05-2012, 12:18 PM   #2
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
As i have not fully drifted the car but have gone sideways i can answer some.
1) no it should not over heat since their is no powersteering, it is electronically enhanced (if that makes since i forgot what they really called it)
2) cannot answer this
3)Yes the e-brake is good enough to lock the rear, just make sure you do a proper weight transfer before you pull it
4)yes it is.
WolfsFang is offline   Reply With Quote
Old 07-05-2012, 01:38 PM   #3
Ocho-Seis
Ocho-Seis's Avatar
Drives: Raven FR-S 6MT
Nothing needs to be done. This is from two hours of drifting on my Closed Course and I still came out perfect. Nothing over heated or anything. And I'm talking 2 hours straight.
063012_4 by TXMan915, on Flickr
063012_3 by TXMan915, on Flickr
063012_2 by TXMan915, on Flickr
063012_1 by TXMan915, on Flickr
063012 by TXMan915, on Flickr
Ocho-Seis is offline   Reply With Quote
The Following User Says Thank You to Ocho-Seis For This Useful Post:
MarkRacerX (07-05-2012)
Old 07-05-2012, 02:13 PM   #4
drifter
Drives: truck and old car
Where is your closed course at?
drifter is offline   Reply With Quote
Old 07-05-2012, 02:34 PM   #5
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Drives: 2016 Hot Lava 6MT FR-S
Negative - the twins are built with much margin for cooling in this regard.
Negative, I kick that mofo all day and she loves it.
For sure - although, I've noticed some weird clunking noise while driving, I'm told it's the nature of the in-wheel hub style e-brake. It seems to work well to upset the chassis and initiate a slide - just make sure you get back on the power AS SOON as traction breaks, otherwise it just won't get where you want it to be.
Negative. Haven't had the brakes give me any issues, or the engine.. perhaps me, but that's fixed with a few icy colds
The stock LSD is a Torsen type - hydraulic vs. mechanical. It has some advantage in exiting corners, but has some disadvantages going into them. If you were a pro drifter or tracker, you'd probably go a mechanical diff. I'll wait till mine blows up (as torsens do, whereas mechanical ones tend to wear out) before I think about replacing it with anything, if ever. Day to Day, it's fantastic.
EsoBOFH is offline   Reply With Quote
The Following User Says Thank You to EsoBOFH For This Useful Post:
Old 07-05-2012, 02:35 PM   #6
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
How many tire changes after "2 straight hours" of drifting?
GenkiElite is offline   Reply With Quote
Old 07-05-2012, 02:40 PM   #7
Ocho-Seis
Ocho-Seis's Avatar
I went through about 2 Sets. 2 hours was more of an exaggeration. (With potty breaks and rehydrating and all.....It gets hot in that cabin.)
And My Closed Course is in Texas.
Old 07-05-2012, 03:21 PM   #8
HATED1
HATED1's Avatar
Drives: 86
thanks for the info guys, I had a 240sx and 350z which needed numerous mods to keep it reliable and on the track for a period of time. Im glad to hear that the frs is good right from the dealer.
Old 07-06-2012, 12:24 AM   #9
Ravine
Ravine's Avatar
Drives: Red FT-86 GTS Auto
Sounds like a bloody expensive hobby.
Ravine is offline   Reply With Quote
Old 07-06-2012, 04:31 AM   #10
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
So these mods may be considered as an overkill?
1) engine oil cooler
2) rear mech LSD
3) enlarged diff cover with baffle and cooling ribs
I am not yet planning to race real hard, but like the feel of extra safety
I had Cusco RS 1,5 way LSD on my Forester and I loved it, but was a bit annoyed with clunks driving in the city or in tight turns
MSTiFK8R is offline   Reply With Quote
FR-S NAV Questions Dan86 Electronics | Audio | NAV | Infotainment 6 07-01-2012 03:24 PM
Questions Do Boy Engine, Exhaust, Transmission 4 06-22-2012 03:33 PM
Drifting Questions Shin Scion FR-S / Toyota 86 GT86 General Forum 56 05-30-2012 08:22 PM
Questions about BRZ/FR-S @ NYIAS bimmerboy BRZ First-Gen (2012+) — General Topics 26 04-16-2012 11:55 PM
Couple of questions :P speedy07 BRZ First-Gen (2012+) — General Topics 25 02-17-2012 04:29 PM
