Old 08-16-2017, 12:25 AM   #15
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Idk that I'd consider them mutually exclusive, but I'm more than willing to admit that Mike is tremendously more experienced in this than I. Like not even comparably so.
I suppose "competitive" in both is the wrong word. Rather able to do both reliably, cost effectively, and making it fun. I think that's a fairly easy goal to accomplish. Afterall, we see it echoed over and over that it's best to track as close to possible until you find that something is limiting you. And i know people who are pretty skilled at HPDE, with room to grow still, who are running similar setups to what I proposed.
I certainly don't think an oil cooler is necessary for a Spec solo class, but I also don't see it adding any real benefit either. But having the allowance might make some people more inclined to participate in both activities though. It'd be a good way for the SCCA to encourage participation in both their Solo and PDX programs. Most guys I know that do both want an oil cooler for track days, which is a good idea, but are conflicted because of solo classing. You can always ask the people in your class if they don't mind, but it'd be nice to not have to deal with that.
I just think it makes sense in terms of the SCCA encouraging growth in as many of their programs as possible, especially seeing how many people take the path of autocross -> PDX -> club racing over time.
I know my notion of what a spec class would look like is probably far from perfect, but I think it makes decent sense.
P.S. typed this on my phone, and only half-assed on proofreading it, so please ignore any grammatical errors or seemingly rambling trains of thought.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 08-16-2017, 11:29 AM   #16
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
The two are mutually exclusive.
I don't imagine cutting up Corvette's and STI's with a Spec Twin... I just want it to be a little better suited to 30 hot laps at my slow ass pace.
If there's a hole in SCCA classing for 86's I don't think it's between Street and Street Touring, a mild prep for STX doesn't break the bank at <$5k for 90% of the fun. Everybody knows it doesn't take long to put together a parts list for CS/DS that sails past $3k.
Mild prep is just that... mild prep. It's very easy to spend $20k on a more complete STX build.
I think your mild prep that is so simple and easy to do, would be a great class of its own. I just don't see any need for threaded spring perches...
Cueman is offline   Reply With Quote
The Following User Says Thank You to Cueman For This Useful Post:
Shark_Bait88 (08-16-2017)
Old 08-16-2017, 01:21 PM   #17
CSG Mike
CSG Mike's Avatar
Mild prep?
Here's my idea of mild prep for a spec class
White list:
- Any oil cooler
- Any camber plate that does not alter spring or damper stroke/position
- Any rear lower control arm
- Any tranmission cooler
- Any differential cooler
- Any intake/exhaust components
- Any tune
- Gasoline only
- 180whp maximum, on a standardized dyno.
- 17x9 wheel
- 245/40/17 spec tire of sorts
- Open brake pads
2750 Minimum Car weight, including driver
- Includes gutting, standard safety provisions
- Up to 50 lbs ballast allowed, passenger side footwell only
Not mentioned = not allowed.
Racecomp Engineering (08-16-2017)
Old 08-16-2017, 01:44 PM   #18
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Mild prep?
White list:
- Any oil cooler
- Any tune
- Gasoline only
- 17x9 wheel
- Open brake pads
So stock springs and dampers and sways?
No springs and dampers = weird class with wheels and tires that wide and suspension that soft
Free springs and dampers = STX + more money and incentive to make the car unstreetable
ineedyourdiddly
Cueman (08-16-2017)
Old 08-16-2017, 01:50 PM   #19
edj
edj's Avatar
Drives: 2022 Toyota GR86
Mild prep?
<laundry list of road race specific mods deleted>
this spec class is for Solo, not road racing.
thanks for playing.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 08-16-2017, 02:03 PM   #20
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Mild prep?
White list:
- Any tune
While I'm no pro on this topic, what about having a set standard for this rather than leaving it open?
Like:
-OFT Header and Stage 2 tune + OEM air filter + Nameless single exit axleback exhaust
-SPC LCAs + Toe bushings
I would think this would bring more of a level playing field and have a set standard to have less difference between the vehicles. I know the Miata Cup cars use the same brake/wheel/tire combo and have sealed engines. Hell, everything is exactly the same on those cars, aside from the seat and colors/livery.
Old 08-17-2017, 12:26 AM   #21
renfield90
The Stig's German cousin
Mild prep?
White list:
- Any oil cooler
- Any tune
- Gasoline only
- 17x9 wheel
- Open brake pads
Swing and a very big miss. I'm glad you're not involved in making autocross rules.
For spec twin to work, it needs to be accessible (read: easy/cheap to have a competitive car) and it needs to be fun (read: fix some of the warts of the car). That's going to look something like "go to Tire Rack, buy this kit, install it, you're good." Something like this: https://www.turnermotorsport.com/p-3...it/?pdk=AQADAQ
Spec twin probably also means dealing with the torque dip somehow - again, in a cost effective way where nobody has any real advantage by spending money on extra parts or testing. That's either specific header/tune or just specific tune. Hopefully SCCA sacks up and moves past their fear of technology they don't understand in that respect.
The Following User Says Thank You to renfield90 For This Useful Post:
Shark_Bait88 (08-17-2017)
Old 08-17-2017, 01:15 AM   #22
CSG Mike
CSG Mike's Avatar
I'm far more experience in balancing and game theory than you think. The proposed spec was for a track class, not an autox class, as a response to a "crossover" class.
A realistic "spec twin" Autox class?
- Camber bolts
- Tires
- Open dampers
- Open sways
- "street tires".
No other mods. If you're so insistent on a "spec" damper, then make OEM spec. As you said, make it accessible. Less mods, more accessible.
Sounds eerily familiar doesn't it?
Torque dip doesn't need to be eliminated; everyone is subject to it. It's a "feature", not a "bug".
As always, deeper pockets mean larger advantage. If you want to eliminate the "deep pockets" advantage as much as reasonable, you can even:
- Spec alignment
- OEM 17x7 wheels only
- Spec tire (and size)
Old 08-17-2017, 01:45 AM   #23
strat61caster
- Camber bolts
- Tires
- Open dampers
- Open sways
- "street tires".
- Spec alignment
That class already exists
ineedyourdiddly
CSG Mike (08-17-2017)
Old 08-17-2017, 08:43 AM   #24
M0nk3y
- Camber bolts
- Tires
- Open dampers
- Open sways
- "street tires".
- Spec alignment
Idea from Spec is to let everyone onto the same playing field and thus eliminate the players that spend $4k on MCS or JRZ suspension.
If I was to take a stab at it...
17x8 Wheels, +- 5mm offset with a min weight the wheel must weigh
Eibach Springs/Swaybars
Sealed Koni Yellows - Dyno'd to maintain spec standards
Camber Bolts
RCAs
200tw Tire, later to be one spec manufacture
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
Cueman (08-17-2017), Shark_Bait88 (08-17-2017)
Old 08-17-2017, 10:41 AM   #25
JermMX5
Drives: 2017 Toyota 86
Camber Bolts
RCAs
This right here is more in line with what I think they'll do, I think they're going to have some sort of catback allowance though. Remember the SCCA is all about being able to take your car you already own and making it fun/competitive, they know pretty much everybody already has an exhaust and that it's such a common mod that catback I think will be in there.
I highly doubt headers will go in there unless it is a standardized one. Because a tomei vs an ACE has a pretty big power difference.
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 08-17-2017, 11:35 AM   #26
CSG Mike
CSG Mike's Avatar
Camber Bolts
RCAs
Even that can be gamed. Spec dampers are virtually impossible to enforce, and can be designed to "degrade differently" if you know what I mean.
Custom wheels can be made to meet a minimum weight while minimizing inertia.
Without a hard spec part that is common, you cannot eliminate the spenders. Even then, there's always the guy that will show up with sticker tires to every event.
Old 08-17-2017, 11:47 AM   #27
M0nk3y
If they're sourced through 1 manufacture, and sealed by that manufacture...AKA Koni of America. Then I would see it being very difficult to game that system.
Yes, someone could elect to have quicker rebuild intervals, thus having a "fresh" damper. But not like you can get said damper through multiple vendors and have shim inside one cater to your preference.
Sure, custom wheels will and can exist, but if a reasonable weight is determined and you can source a wheel that's within 1 lb of that, does that other person really benefit? I'd doubt that.
Lastly, depending on what tires are offered and what exist, "sticker tires" aren't really a thing anymore.
I just corded a set of Rival 1.5s with about 150 runs, and won Oscoda ProSolo on them by close to a second. Most tires also need a couple heat cycles to come in.
Shark_Bait88 (08-17-2017), strat61caster (08-17-2017)
Old 08-17-2017, 12:47 PM   #28
strat61caster
Claimer rule at big events, cough up the money and you buy the fast guys dampers. 16 nuts and they're yours, bring a spare set of stock suspension to get you home. If the cost of the claim is the same as retail for the dampers it's more expensive than getting your own rebuilt, theoretically the person getting bought out hasn't lost anything (except maybe a fresh rebuild) and gets to buy a fresh set.
Edit: I think I'd prefer that over a sealed/spec/regularly dyno'd damper. Much cheaper overall on the sport to regulate than paying for damper dyno time, allows freedom to pick Koni, Bilstein, or alternative (like OE). And despite what you may think (oh no the top 3 cars are going to have their dampers stolen every big event!) claims are rare. As a kid when someone claimed an engine there were whispers coast to coast of what happened. Before everyone put everything online so it was literal word of mouth.
Yes someone with big pockets can go out and get dyno time and custom rebuilds and dyno a hundred dampers to find the best set, but when the risk exists that all that effort will be wiped out it keeps people from pushing the envelope too far beyond the costs.
And of course if anything is found illegal during teardown (i.e. slotted bolt holes or perches at the wrong height) the claimer gets refunded and the parts either confiscated, branded, etc. as any other tech inspection failure.
Edit 2: Yes this doesn't prevent people from blowing thousands of dollars, it just raises the risk in the risk-reward equation and typically keeps people from going bonkers. For example, claim is ~$900 enough for a set of new Koni Yellow or Bilstein B6's, but that probably wouldn't prevent me from paying ~$600 to send a set of Bilsteins to Poway to have a custom valving done on them. If I do well and get claimed I suck up the loss and repeat the process, cost of doing well in the class. But it would probably prevent 99% of competitors from going out and paying someone like FCM for a fancy rebuild because at that point the returns are minimal.
Vendors will likely put together packages like a matched set of Koni Yellows for $200 more than off the shelf, but I don't think that's a bad thing.
ineedyourdiddly
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
