Old 08-15-2017, 02:12 PM   #1
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
PB blaster and endlinks
My front endlinks are seized and I need to adjust my front bar, is the rubber on the endlinks going to break down if on blaster gets on them? I'm trying to decide if I just need a used set of stock endlinks too.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 08-15-2017, 02:17 PM   #2
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
No, the rubber should be fine. I have used pd blaster on endlinks before along with many other places with plastic or rubber around. But make sure to lube the balls socket joint in the endlink, as pd blaster will thin the grease out if its seeps to it and the joint may seize eventually (I learnt the hard way)
Sideways is offline   Reply With Quote
Old 08-15-2017, 03:08 PM   #3
Keenercarguy
Mountain Runner
Yeah that's what I was afraid of. I might just grab a used set of endlinks for cheap to have in reserve
Old 08-15-2017, 03:34 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Good luck, my car was from up north so almost every nut and bolt under the car was rusted and seized, I ended cutting the end links in half in order to remove the suspension and bought Whiteline adjustable ones instead.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-15-2017, 03:41 PM   #5
jasonojordan
Drives: 2013 satin white brz limited
Another option you can try instead of PB blaster that I have had really good luck with on seized stuff is kroil.
http://www.kanolabs.com/
jasonojordan is offline   Reply With Quote
Old 08-15-2017, 04:07 PM   #6
There is no "rubber" in the rubber parts of these cars. They are PCV/silicone compounds. Would take something way stronger than PB to eat them up.
DAEMANO (08-16-2017), Keenercarguy (08-15-2017)
Old 08-15-2017, 05:47 PM   #7
Keenercarguy
Mountain Runner
Thankfully my car just saw lots of SC humidity and water, not so much salt. I think (read: hope) that if I use penetrating oil and a breaker bar I'll be able to get them loose
Old 08-16-2017, 12:45 PM   #8
sirsol66
Drives: 2013 FRS- Hot Lava
Grab the back of the socket with vice grips. Worked much better for me than trying to use the stupid allen keys.
sirsol66 is offline   Reply With Quote
Old 08-16-2017, 02:31 PM   #9
Joon525
Joon525's Avatar
Drives: 2016 BRZ
One thing I usually do when trying to remove stuff where a bunch of threads are showing is to take a wire brush/wheel and really clean up the exposed threads so that when the nut does break loose you're not trying to overcome the extra friction that rust particles provide in the threads.
Also, spray the PB Blaster the night before working on the car and again a few hours before working on it.
A lot of people spray it and wait 5 minutes which may not be enough.
Joon525 is offline   Reply With Quote
Old 08-16-2017, 04:31 PM   #10
wparsons
wparsons's Avatar
Front end links are like $40 each Canadian, I wouldn't bother messing with used ones for that price. I'd bet they're about $25 US each.
flickr
D_Thissen (08-16-2017)
Old 08-16-2017, 08:15 PM   #11
Keenercarguy
Mountain Runner
If a friend of mine that I trust has a set with very few miles I'd still take them over mine. It'd be hard to be worse so anything would be an improvement. No reason to bother spending $50 on things worth $15
Perrin Endlinks norcalpb Brakes, Suspension, Chassis 7 08-25-2017 07:20 PM
OEM Suspension + Endlinks Jav Brakes, Suspension, Chassis 0 08-06-2015 09:33 PM
WTB FRONT ENDLINKS fr_s Want-To-Buy Requests 2 06-25-2015 07:15 PM
Endlinks Question astar23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-14-2015 12:32 AM
Front Endlinks goke186 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-31-2012 01:16 AM
