Old 08-07-2017, 10:42 AM   #1919
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
No better way to spend 86 Day!
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
cbryant514 (08-07-2017), dattran86 (08-07-2017), DocWalt (08-08-2017), GTHachiRoku (08-07-2017), Williampreza (08-07-2017)
Old 08-09-2017, 06:44 PM   #1920
ATL BRZ
ATL BRZ's Avatar
Installed the new 3 inch Dezod Motorsports catback today.
[ame="https://www.youtube.com/watch?v=zyNcw8jRnJs"]Turbo Subaru BRZ free revs with new Dezod Motorsports 3 inch catback. - YouTube[/ame]
I love the extra deep rumble and the turbo feels like its spooling a little faster now too!
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
dattran86 (08-10-2017), NLS8520 (08-10-2017), pgranberg11 (08-11-2017)
Old 08-11-2017, 04:24 PM   #1921
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
This looks awesome. I wonder how DB levels compare to the resonated 3 inch perrin. I like that this one is truly 3 inch all the way through... Perrin cuts back to 2.5" after their big resonator at the back..
pgranberg11 is offline   Reply With Quote
The Following User Says Thank You to pgranberg11 For This Useful Post:
ATL BRZ (08-11-2017)
Old 08-11-2017, 05:27 PM   #1922
ATL BRZ
ATL BRZ's Avatar
Don't go 3 inch if DB levels matter to you. I'd only recommend doing it on a turbo car since the turbo keeps the volume down considerably.
Old 08-11-2017, 10:45 PM   #1923
Thedishdoc
Drives: 2015 Scion FRS
This thread is epic. Only sorry I'm not able to like it.
Thedishdoc is offline   Reply With Quote
The Following User Says Thank You to Thedishdoc For This Useful Post:
ATL BRZ (08-14-2017)
Old 08-12-2017, 07:33 PM   #1924
NLS8520
Drives: N/A
I know you were running Miller's Nanodrive on your BRZ when it was NA, now that your turbo'd are you going to continue using Miller's Nanodrive and what viscosity?
NLS8520 is offline   Reply With Quote
Old 08-12-2017, 07:43 PM   #1925
ATL BRZ
ATL BRZ's Avatar
Yes. 5w40
The Following User Says Thank You to ATL BRZ For This Useful Post:
NLS8520 (08-12-2017)
Old 08-14-2017, 04:51 PM   #1926
ATL BRZ
ATL BRZ's Avatar
[ame="https://www.youtube.com/watch?v=9skLnIFj80g"]JDL Turbo Kit 1000 mile review/lessons learned - YouTube[/ame]
The Following 6 Users Say Thank You to ATL BRZ For This Useful Post:
ApexEight (08-14-2017), Deep Six (08-25-2017), Hicklinc (02-09-2018), M1K3 (08-15-2017), NLS8520 (08-15-2017), Roadcone (08-15-2017)
Old 08-15-2017, 08:12 AM   #1927
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Active mufflers help a bunch
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 08-15-2017, 01:03 PM   #1928
ATL BRZ
ATL BRZ's Avatar
So does a turbo
Old 08-23-2017, 09:46 AM   #1929
ATL BRZ
ATL BRZ's Avatar
Got busy this weekend with Gridlife prep!
Ducted and sealed my cooling package with a $19 roll of high density foam from the local fabric store.
The foam is thick but pliable so stuffed it between the radiator and the frame and it will not move but I taped it down with Gorilla tape for extra security at speed. It conforms to the current home furnishings fire retardant codes and it will not decompose below 356F which my heat exchangers will never see.
Next, I installed new, stiffer engine mounts from Torque Solution
I was absolutely dreading this job, but it turned out to be a breeze which took about 30 minutes. I knew the passenger's side mount wouldn't be bad, but I had heard from many people that the driver's side mount was impossible to get out without dropping the exhaust manifold. For me, that would mean basically the whole turbo kit had to be removed. But after using a transmission jack to lift the motor about six inches, I removed the metal shield from the mount in place, flipped the mount upside down and snaked it out between the exhaust runners and the oil man without any major snags!
The new mounts do their job well and the NVH increase isn't bad at all. I can only feel the difference at idle and coming off idle. They actually make clutch engagement easier, especially paired with this:
Whiteline transmission mount insert bushing! That was a straight forward install and it definitely cleaned up a lot of slop that the mount was allowing without it.
Last but not least, I pulled my fuel pump assembly back out and quickly snapped in the new Verus Engineering fuel starvation door!
This little door snaps in to a pre-existing hinge (thanks, ToyoBaru?) and keeps a supply of fuel in the basket and prevents starvation under high demand, low supply situations, like a hard left-hand turn when running E85 and boost (like me). The starvation issue has been very prevalent and mine has actually starved a couple times when the car was NA and running E85. It's not something I want to leave to chance or be inconvenienced by having to run a full-to-the-brim tank every session on track. This door saved me and others thousands of dollars by avoiding an expensive surge tank setup to fix this annoying issue.
Buttoned everything up, and now we're ready for some fun this weekend at Road Atlanta for Gridlife!
The foam is invisible with the bumper on!!
The Following 7 Users Say Thank You to ATL BRZ For This Useful Post:
dattran86 (08-23-2017), DustinS (08-23-2017), jubella2 (08-23-2017), malubawla (08-23-2017), Teseo (08-23-2017), TeutonicShift89 (08-23-2017), VerusEric (08-23-2017)
Old 08-23-2017, 10:59 AM   #1930
Teseo
Drives: frs
Nice!! I was considering a sheet metal for ducting the intake but this should work too. Thanks for sharing
The Following User Says Thank You to Teseo For This Useful Post:
ATL BRZ (08-23-2017)
Old 08-23-2017, 11:03 AM   #1931
jubella2
jubella2's Avatar
Drives: DGM BRZ
So clean!!
jubella2 is offline   Reply With Quote
The Following User Says Thank You to jubella2 For This Useful Post:
Old 08-23-2017, 12:32 PM   #1932
Jonsey
Jonsey's Avatar
Did they change names again?
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following User Says Thank You to Jonsey For This Useful Post:
SkAsphalt (08-24-2017)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
