Old 08-11-2017, 06:35 PM   #1
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Melted Bushings
I had to end a track day early last weekend because my 22mm Whiteline swaybar passenger side bushing melted due to its proximity to my ACE A350 ceramic coated header overpipe. It wasn't just a little melted either. The top half of it is completely gone. Has anyone else come across this and found a solution? The steering linkage is also very close and shows where it may be hitting in extreme instances. Just wrap it? Any advice?
B T is offline   Reply With Quote
Old 08-11-2017, 06:51 PM   #2
NOI
NOI's Avatar
Drives: 2 Subarus and a 2013 FRS
Yikes
NOI is offline   Reply With Quote
Old 08-11-2017, 08:14 PM   #3
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Pictures? Have never heard of this issue on our platform yet. Surprised the stock ones aren't melting on other people's cars
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 08-11-2017, 10:25 PM   #4
LudwigMiles
Drives: '13 BRZ
This is the downside of modding your car. Pics please.
LudwigMiles is offline   Reply With Quote
The Following User Says Thank You to LudwigMiles For This Useful Post:
Zer0 (08-13-2017)
Old 08-12-2017, 11:20 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
The whole area near the overpipe is very cramped. I haven't seen what it's like with the ACE header. Can you take a photo? You may be able to put some heat shielding near the bush.
1974 TA22 Celica
2013 86 GT
Old 08-13-2017, 02:16 PM   #6
B T
Old 08-13-2017, 04:59 PM   #7
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
err your exhaust is touching...? how is that a surprise.....
see if you can move the exhaust upword a bit, i had this problem with my header when i just installed it, i end up sorta pushing it up while installing the whole thing again.
Cuz my overpipe was rattling my car under acceleration. *such a given
Old 08-13-2017, 10:02 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
Wow, that is ugly
@AceHeader-MT @CSG have you guys come across this before?
1974 TA22 Celica
2013 86 GT
Old 08-14-2017, 12:24 AM   #9
Impureclient
Drives: 2015 FR-S
Does any other header get that close to the sway bar to touch or is it just the Ace?
Old 08-14-2017, 06:16 AM   #10
psc
Drives: Toyota 86 GT
what are your exhaust gas temperatures?
this is partly why I'm considering leaving my overpipe stock with its headshields.
psc is offline   Reply With Quote
Old 08-14-2017, 09:35 AM   #11
IDFWU 420
Honarary Member
IDFWU 420's Avatar
Drives: 2015 FRS
I thought ceramic coating was supposed to help deal with heat issues... damn OP! that looks horrible.
IDFWU 420 is offline   Reply With Quote
Old 08-14-2017, 11:50 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
If there is contact, due vibration at that point coating gets damaged anyway, so how can it protect? +with contact there is much more heat conducted then via heat radiation, if there had been even though small but gap with air.
Problem with that little space to work with is how to get long enough runners for most efficient exhaust gas scavenging. Nameless tucked excess in front of engine, Ace - using overpipe part. No clue, which approach is better, but from this case it seems that it's always worth double check any clearance issues one may have, not just when vibrations between parts can be heard.
Old 08-14-2017, 04:06 PM   #13
You guys are mixing up the sequence of events. The sway bar came into contact with the overpipe after the bushing melted.
Cole (08-14-2017), mrderp (08-14-2017)
Old 08-14-2017, 04:18 PM   #14
B T
indeed, Ultramaroon. There was no contact prior to the bushing melting. I had more important things to monitor during my track day than EGT. I had 4 or 5 20 minute sessions at Florida International Rally and Motorsports Complex. Each run was 20 minutes apart. I think a majority of the melting happened after parking (4 cool down laps). I didn't hear it banging while I was still on track. I'm still running the stock front pipe, waiting on my ACE unit to come in. The lack of flow past the overpipe could have contributed to this.
The Following User Says Thank You to B T For This Useful Post:
Cole (08-14-2017)
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 06:32 PM
Clutch Release Bearing Melted Haulin Engine, Exhaust, Transmission 37 05-29-2016 07:35 PM
Buddy Club Tails Damaged/Melted? Krazy Cosmetic Modification (Interior/Exterior/Lighting) 13 01-07-2016 12:11 PM
Perrin exhaust with added benefit of melted plastic s30series Engine, Exhaust, Transmission 3 09-12-2014 09:44 PM
Muffler delete on track (melted bumper?) celica73 Tracking / Autocross / HPDE / Drifting 12 04-01-2014 05:27 PM
