Old 08-04-2017, 06:17 PM   #1
circuithero
Drives: 2006 Infiniti M45S
Dedicated Drift Platform: Toyobaru vs 370Z
Looking to get an opinion from the collective hive mind here who may have more experience with the platforms specifically for drifting. Being on FT86 I know there is a slight bias but I find you guys are pretty open minded and have seen excellent, well mannered discussion come up when comparing vehicles. I know we have had people switch between the cars both ways. For intent of the compare I am talking pre updated MY17 cars and a sport package 370Z, price of entry being roughly the same. I am aware I can get a cheap E36, weld the diff and skid. Let's say that is not feasible.
The intent of this comparison is purely as a basic/entry/KISS drift platform exclusively. I've owned a 2013 FRS and G35 back to back so I am familiar with the FRS's steering feel and weight advantage. I am not as familiar with the updated 370Z platform. Also have 4+ years of tracking, instructing experience but no direct drifting experience except catching oversteer on track/autox. The idea is to have something to maximize seat time on while minimizing wrench time. So basic mods for consistent and reliable skids. #Learning
FRS/BRZ:
  • Header/Tune
  • Coilovers
  • Tie Rods
  • RLCA
  • Remove front sway bar
PROS: Cars are lower weight, which means less consumables cost and easier transitions. Steering feel is superior and so is the seating position. Also the stock differential is sufficient which means this can be left alone.
CONS: Lack of power is not the best, I have gotten accustomed to having some torque. This also makes adjusting line and initiating a bit more difficult (IMO, from my 2013 Scion FRS experience) on throttle. Have to throw the car at speed, not enough power in the higher speed stuff or a bunch of clutch kicking. I have read also in the drifting thread this can cause some issues in tandems. My fear here would be as I have some background with high performance driving, I would outgrow the stock power and be tempted to go with boost. Which is $$$ and I am not interested in going down that path again. Been there done that.
370Z:
  • Coilovers
  • 2 Way Diff (VLSD is useless for consistency sake)
  • Tie Rods
  • Oil Cooler (Apparently they run hotter than 350Z?)
  • Anything else? Not as familiar with this platform...
PROS: Stock power and torque is enough for any drifting I would like to do/learn. No need to upgrade engine and compromise reliability, not something I see outgrowing power wise. I like the engine note a bit better and the aesthetics slightly more.
CONS: Consumables will be more because of weight. A bit more of a pig and opposite of the PROS for the FRS.
Thoughts/feedback from our drifters here?
circuithero is offline   Reply With Quote
Old 08-09-2017, 01:13 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
FRS
I never cared for the Z. Feels like a pig in comparison. Numb, dull, slow to rotate, etc. I also personally hate the sound of the VQ engine. But that's subjective.
The lack of torque and steering angle are the only downsides to the FRS in my opinion. Both are easily fixed though.
With headers and tune, there is ample power to use 4th gear in drifting. I was doing tracks with 4th gear entries when my FRS was stock power. If there's too much grip, just increase the rear tire pressure.
Tandem is also easy with the FRS, especially when you have the extra angle and power. Remove ABS fuse so you can left foot brake in chase without having the LSD braking kicks in and causes you to drop out of the powerband. You'll run a bit of a shallow line and angle to chase higher powered cars, but it's still more than capable. I ran door to door with a 500hp 1JZ ProAm car with a stock powered FRS. I had to run shallow line and angle to stay close, but I could still do it.
The lower power and lower weight also comes with lower running costs. Less fuel and tire consumption means it's less cost to drive, which means easier to get more seat time... and that's what matters most.
[ame="https://www.youtube.com/watch?v=2o4xBhq9FJg&t=14s"]FRS Drift Compilation - YouTube[/ame]
^This is from when I had mine. All the clips in the video are from the first 6 months of ownership with my car back in 2013. Stock power and stock steering angle. Just coilovers, LCAs, and an axleback exhaust. There's some tandem in there too.
The Following 7 Users Say Thank You to TylerLieberman For This Useful Post:
bcj (08-09-2017), circuithero (08-09-2017), DAEMANO (08-09-2017), Spuds (08-09-2017), strat61caster (08-09-2017), Tcoat (08-10-2017), TofuJoe (07-13-2019)
Old 08-10-2017, 08:53 AM   #3
Teseo
Drives: frs
No eurobeat? Shame on you
Old 08-10-2017, 10:57 AM   #4
TylerLieberman
Drives: '24 GR86
I actually had some eurobeat blasting in the car at a bunch of events lol. It's awesome sitting there on grid with the windows up and the A/C & stereo blasting, while everybody else in their old cars have to sit there with their windows down and doors open just to get some fresh air and keep from dying in the heat.
New cars rock.
The Following 3 Users Say Thank You to TylerLieberman For This Useful Post:
strat61caster (08-10-2017), Tcoat (08-10-2017), Teseo (08-10-2017)
Old 08-10-2017, 11:04 AM   #5
circuithero
Great feedback, thanks Tyler. I just read your large post on your build thread for getting the car drift ready. A lot of good information there. Much appreciated!
The Following User Says Thank You to circuithero For This Useful Post:
TylerLieberman (08-10-2017)
Old 08-10-2017, 11:41 AM   #6
TylerLieberman
Drives: '24 GR86
Thanks. Glad you found it helpful.
It was a bunch of info I had compiled through personal experience with my own car, as well as what friends of mine had discovered through their own experiences.
Old 10-04-2017, 05:34 PM   #7
Twin4Life
Twin4Life's Avatar
Drives: '14 Genesis Coupe 3.8 Grand Touring
I havent logged on in months, serious personal life issues that sucks the life out you. Putting real tires on the 86 throws off the friendly demeanor it has stock. I dont think youll be doing much credible drifting should you go that route.
Twin4Life is offline   Reply With Quote
The Following User Says Thank You to Twin4Life For This Useful Post:
~el~jefe~ (10-11-2017)
Old 10-11-2017, 01:40 PM   #8
~el~jefe~
Drives: 2019 MX-5 RF
the 370Z is a much better car to have fun with drifting. Just start it up and drift as is. Power is key to drifting, power and rear wheel drive is all there is. The BRZ can drift but really does not have to as it has an actual sports car, low center of gravity build. To drift in the BRZ/FRS one has to push up the power. Putting 18" 235+ sticky tires makes it not driftable without a big bump in torque. I would never get a FRS for drifting unless I desired to put forced induction on it.
~el~jefe~ is offline   Reply With Quote
Old 10-11-2017, 03:16 PM   #9
ST185RC
Drives: White Out FR-S
Both under the same driver skill and stock for stock:
torque in the 370z will make drifting easier.
skill in the 86 will make drifting more rewarding.
ST185RC is offline   Reply With Quote
Old 10-11-2017, 03:25 PM   #10
I disagree with most of this. Weight, balance and control play a much greater part in drifting than just raw power. In fact high power is probably the least important part of a drift car. A 370Z is actually harder to drift since the weight makes it harder to control.
These are not powerful cars:
strat61caster (10-11-2017)
Old 10-11-2017, 03:26 PM   #11
Torque will make initiating the drift easier. Controlling it is a whole different matter.
Old 10-11-2017, 04:42 PM   #12
ST185RC
I agree. I've done a bit in both and I can say that loading the springs in the 370z is much less forgiving than loading the spring in the FRS thanks to a few hundred extra pounds.
I still find the 370z easier to maintain a slide thanks to the torque, which is why I say the FRS is still more rewarding to get sideways.
The Following User Says Thank You to ST185RC For This Useful Post:
Tcoat (10-11-2017)
Old 10-11-2017, 05:13 PM   #13
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
The Following User Says Thank You to chaoskaze For This Useful Post:
_Kodiak (04-09-2020)
Old 10-11-2017, 06:11 PM   #14
ST185RC
How much power and torque do you reckon these guys have to drift / power slide with?
[ame="https://www.youtube.com/watch?v=R5AZ8yYHNts"]best drift on bicycle combination - YouTube[/ame]
The guy at 1:20 is keeping a mad drift going yo.
Dedicated race car suspension ? Valentino Tracking / Autocross / HPDE / Drifting 63 10-19-2015 10:27 PM
Magazine dedicated to Twins sftateofmind BRZ First-Gen (2012+) — General Topics 1 04-01-2015 01:02 AM
It's what makes a toyobaru, a toyobaru. Optimus Prime FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 04-06-2014 05:51 PM
Did this little Toyobaru drift video sometime back... jamomatt BRZ Photos, Videos, Wallpapers, Gallery Forum 4 03-22-2014 03:06 PM
what if you dedicated $2,000 brichard0625 Engine, Exhaust, Transmission 28 04-07-2013 01:13 AM
