Old 07-08-2017, 11:00 PM   #2213
blkdmnd
Drives: Black 2015 Subaru BRZ, BlackDiamond
Originally Posted by Jive Turkey View Post
This looks amazing w/o the emblem, how do i do this exactly?? did you take it to a body shop to fill it in?
blkdmnd is offline   Reply With Quote
Old 07-19-2017, 07:16 PM   #2214
Lust
Drives: 2017 Subaru BRZ
Didn't have much time to take a quality photo, but here's a shot of my TE37 SLs on the new 2017 BRZ. Tires are 265/35/18 Advan AD08Rs. I'll post more pictures soon after its been corner balanced and has had a proper alignment.
Lust is offline   Reply With Quote
The Following 2 Users Say Thank You to Lust For This Useful Post:
Chayce808 (07-20-2017), keb86 (07-25-2017)
Old 07-24-2017, 10:18 PM   #2215
ColaCan
Drives: '15 BRZ
Hey guys, so I have 18x9.5 +38 wheels with stock suspension. I know that setup will be close to the spring perch. But my question is what is the widest tire I can run if all 4 tires are the same size. 245/35, 255/35, or 265/35? Those seem to be the most common sizes.
ColaCan is offline   Reply With Quote
The Following User Says Thank You to ColaCan For This Useful Post:
Crystalwhitebrzsti (07-08-2019)
Old 07-25-2017, 02:47 PM   #2216
Lust
I'd recommend 245. You can go up to 255 and 265 once you're on coilovers
Old 07-25-2017, 03:54 PM   #2217
ColaCan
Drives: '15 BRZ
Thanks for the recommendation Lust. Have another question for you, would a 245/40 tire fit? Because I don't plan on getting coilovers at anytime unfortunately and I don't want a ton of wheel gap with a low profile tire. Your car is beautiful btw.
Lust (07-25-2017)
Old 07-25-2017, 06:09 PM   #2218
Lust
Any reason you wouldn't want coilovers? 245/40 should fit but on stock suspension will look like a monster truck
The Following User Says Thank You to Lust For This Useful Post:
JT.86 (07-25-2017)
Old 07-26-2017, 08:30 AM   #2219
ColaCan
Drives: '15 BRZ
I have coilovers on mine but these wheels are going on my gf's brz and she thinks the stock suspension is already low and stiff enough. And she tends to bottom out as it is lol. So I was just thinking that maybe with a little bit taller sidewall it would fill up some of the wheel gap and provide a slightly smoother ride.
Old 07-26-2017, 10:49 AM   #2220
churchx
churchx's Avatar
Drives: 2014 GT86
ColaCan: you can also consider these.
Old 07-26-2017, 02:56 PM   #2221
Lust
You will get a better quality ride by switching to an appropriate shock spring combo or coilover. My recommendation is to look at Tein Flex Z. These are very affordable and offer great ride quality when setup right. At the bare minimum if you're dead set on stock suspension, grab camber bolts for the front and SPC LCAs. This way you can get a decent amount of camber and the car will handle better
Old 07-27-2017, 12:49 AM   #2222
ayyyypex
Drives: 2016 FR-S
honestly just pull the emblem off and leave it like that. its just 2 small holes which make like no difference. If you want to get it smooth then yeah, bodyshops gonna have to fiberglass from behind, or (easiest way also super strong) is the make a small and sharp edged pointy patch and heat it red hot and melt it where the hold is from behind
ayyyypex is offline   Reply With Quote
Old 08-09-2017, 03:51 AM   #2223
86socal
86socal's Avatar
Drives: White frs
255/35
18x9.5 +40
86socal is offline   Reply With Quote
The Following User Says Thank You to 86socal For This Useful Post:
sqd (08-09-2017)
Old 08-10-2017, 07:19 AM   #2224
batlwagn
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
Just got these yesterday to replace my 265 Hankook Ventus v12. Tires are Federal 595rs-rr 265/35R18
Sent from my SAMSUNG-SM-G891A using Tapatalk
ALL THE MODS!!
batlwagn is offline   Reply With Quote
Old 08-10-2017, 07:58 AM   #2225
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Originally Posted by Cartman View Post
I'm finally able to join the meaty tire club.
17x9 Rays Gramlight 57CR with 255/40/17 Riken Raptor ZR tires
How are you liking these tires? Pretty cheap for a summer tire. Do the sidewalls feel soft?
ApexEight is offline   Reply With Quote
Old 08-10-2017, 08:29 AM   #2226
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
So far I like the tires, they have a lot of grip for a UHP tire. I have not used them outside of daily driving. As far as the sidewalls stiffness... well the sidewalls are soft compared to the 200 TW tires I use for track... but that's to be expected.
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
ApexEight (08-10-2017)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
