Old 08-09-2017, 01:12 AM   #15
Teseo
Drives: frs
Take advantage of the recent TSB that came out addressing the faulty throw out bearings in these cars. My clutch has the issue, but I am out of warranty now so when my TOB grenades prematurely I will need to spend hundreds of dollars replacing it.
It will cost you like a grand out the door, if they want tou charge more go to other place. I was there mate
The Following 2 Users Say Thank You to Teseo For This Useful Post:
funwheeldrive (08-09-2017), Ultramaroon (08-09-2017)
Old 08-09-2017, 01:20 AM   #16
Water has to be above boiling temp in order to evaporate? Why is my oil cooler thermostat fully open at 180*F?
Guess it's time to fire off a strongly worded letter to Mocal.
I reckon ol @guybo had a "brain fart" when he typed that reference in his post ......
Old 08-09-2017, 01:25 AM   #17
Question ...... will a dealer replace a TOB under warranty, if it ain't broke ...... ........ but I doubt it .....??
Old 08-09-2017, 03:08 AM   #18
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
In my experience with stealerships, they will try and pass it off as a wear-and-tear item and try and do everything in their power not to replace it even if you're under 36k, much less 60k.
I soon exceeded 60k after my poor experience with dealerships and got a buddy's shop to install an ACT clutch while taking care of the TOB issue. Not a free fix, but I didn't want the TOB to strand me.
dhuang is offline   Reply With Quote
The Following 2 Users Say Thank You to dhuang For This Useful Post:
Celica00 (08-09-2017), humfrz (08-09-2017)
Old 08-09-2017, 05:48 AM   #19
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
But at stock, the oil temp still gets up to 215-230 normal working temp doesn't it? Just because the thermostat opens at 180 doesn't mean that the oil temp stays 180. The car is designed to let the oil temp get well above boiling for this very reason I mentioned ;-)
guybo is offline   Reply With Quote
Old 08-09-2017, 10:17 AM   #20
funwheeldrive
It sounds like some people have had success if the clutch pedal squeak is obvious when the dealer inspects it. Mine only squeaks and groans when it's super hot outside and I've been driving the car for a long period of time. I'm sure it will get worse over time though...
The Following 2 Users Say Thank You to funwheeldrive For This Useful Post:
DaBoBo21 (08-09-2017), humfrz (08-09-2017)
Old 08-09-2017, 10:39 AM   #21
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I had mine replaced under warranty back in April. Not a thing wrong with the first one, I just happened to bring up the TSB to my adviser at the time and he was on board with having the revised part installed to avoid future issues. He said in addition to the BRZ, it's fairly common with the newer WRXs, as well.
DaBoBo21 is offline   Reply With Quote
The Following 2 Users Say Thank You to DaBoBo21 For This Useful Post:
funwheeldrive (08-09-2017), humfrz (08-09-2017)
Old 08-09-2017, 01:16 PM   #22
Since ol @Ultramaroon is off to work (to contribute to SS, so as my SS checks (which I paid into for 50 years) will keep coming), I will respond for him.
I think what he is ah picken on is your statement:
"The oil has to regularly run well over 212F to burn off water in the crankcase from normal condensation".
I too, consider that statement somewhat misleading.
For example, the last time I judged a wet T shirt contest, water was evaporating off of the wet T-shirts the girls were wearing ....... I'll admit those tits were HOT ...... but I doubt they were 212 degrees F or over ......
humfrz - another HOT, smoky day in Puyallup ......
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Tcoat (08-09-2017), Ultramaroon (08-09-2017), wireman957 (08-09-2017)
Old 08-09-2017, 01:35 PM   #23
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Why ethanol free? Ethanol is an excellent fuel and keeps the engine cleaner. It increases octane rating and is an excellent solvent to keep the fuel system and injectors clean. The thinking that ethanol is somehow inferior is stone age thinking going back to when cars weren't designed for it and the fuel system would be damaged by it. The 86 is designed to run on E15 reliably.
As for a reliability mods-
Unless you are going FI, don't install an oil cooler. The oil has to regularly run well over 212F to burn off water in the crankcase from normal condensation. An engine that does not run hot enough is going to have reliability issues.
Install an oil catch can. It's good for the long term health of the engine by preventing deposits from building up on the valves.
E10. Many manufacturers, including Toyota, Subaru, and all the Japanese ones pointedly repeatedly state never to put more than e10 in their vehicles. Heck it is even in the owners manual.
Also e10 gets worse gas mileage, sometimes by quite a bit.
But it really isn't a big deal as long as it is just e10.
why? is offline   Reply With Quote
The Following 4 Users Say Thank You to why? For This Useful Post:
chaoskaze (08-10-2017), mrg666 (08-09-2017), Tcoat (08-09-2017), Ultramaroon (08-09-2017)
Old 08-09-2017, 02:03 PM   #24
The engine and oil can tolerate excursions above boiling. I draw the line at calling it a requirement. LOTS of conflicting opinion out there but I've never found any official anything to support the argument either way.
Toyota/Subaru set 80* C (176* F) as the standard temp for oil pressure test. That's good enough for me.
Tcoat (08-09-2017)
Old 08-09-2017, 03:26 PM   #25
Breadstickz
Drives: 2017 Inazuma BRZ
sorry to kind of hijack the thread a bit but does anyone know if the TOB issue is still on the 2017s?
Breadstickz is offline   Reply With Quote
Old 08-09-2017, 04:56 PM   #26
The TSB States 13 to 16s but it was issued in April 17 so yours could be covered if it was an early 17 built in late 16. Usually they give a VIN range but this one just says years.
http://www.ft86club.com/forums/showthread.php?t=117440
Adam_L (08-10-2017), Breadstickz (08-09-2017)
Old 08-09-2017, 07:25 PM   #27
Breadstickz
Thanks Tcoat, You're the best bud!
Old 08-09-2017, 07:40 PM   #28
mrg666
pessimistic skeptic
mrg666's Avatar
My crickets love E10. Since I don't like crickets I use ethanol free. Ethanol free doesn't make much difference for me in gas mileage. But I am comparing 91 octane ethanol free with 93 octane ethanol gas. I will fill with 93 octane again next time to see how the crickets are doing and check the gas mileage. There is also air temperature. The car hates hot and humid air; power and mileage suffer miserably with such weather. I gotta find a nice week to test 93 ethanol gas.
The Following User Says Thank You to mrg666 For This Useful Post:
why? (08-10-2017)
FR-S / BRZ reliability stats mkaresh Scion FR-S / Toyota 86 GT86 General Forum 82 03-12-2017 03:40 PM
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 10:55 AM
FI Reliability pheonixone Forced Induction 42 02-22-2015 01:51 PM
