Old 08-08-2017, 10:16 PM   #1
oppiee
Drives: 2014 Scion FRS (Red)
OFT question
Hey guys,
Currently just started running on OFT EL stage 2, 93 oct. I was wondering what parameters I should be looking for in torque (OBDII ) to make sure the car is running normally with tune.
Thanks!!
oppiee is offline   Reply With Quote
Old 08-08-2017, 10:43 PM   #2
JermMX5
Drives: 2017 Toyota 86
Originally Posted by oppiee View Post
Hey guys,
Thanks!!
Knock correction is the biggest as far as I'm aware. You want to make sure it's not constantly pulling timing do to detonation.
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 08-08-2017, 10:49 PM   #3
Teseo
Drives: frs
Why not use the oft itself? You can looks parameters too
Old 08-08-2017, 11:08 PM   #4
oppiee
on OFT are we looking at the ignition advance multiplier?
Old 08-09-2017, 08:07 AM   #5
JermMX5
I don't have my OFT yet, but you'll be looking for something like Knock control, or KC value, it might be KC learned.
Old 08-09-2017, 08:11 AM   #6
oppiee
Icic thank will take a look! I am just debating if I should try the UEL map for the MXP EL header b/c looks like an UEL lol
Old 08-09-2017, 03:11 PM   #7
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
There are plenty of threads talking about what to log on your OFT. Just off the top of my head RPM, engine loads, knock parameters, AFR commanded and actual, MAF voltage, ignition advance, fuel trims, oil temps are all important things to monitor.
http://www.ft86club.com/forums/showt...highlight=Logs
Intent > Content
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
OFT question Karl07 Software Tuning 8 02-14-2017 04:19 AM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
a question about tax... pr086 Scion FR-S / Toyota 86 GT86 General Forum 34 06-07-2012 09:11 AM
