#393 |
Drives: 05 Ford Focus ZX4
Car is looking good. I want to see it with all your stickers/magnets attached to it, to make it look more like a race car. Haha.
#394 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Today, I am going to remeasure and readjust the suspension from the settling. Have an Alignment planned tomorrow after work, if theres anymore settling..hopefully it can get it over with..
... I think this time...I am going to be in the car for the alignment. Makes sense, right?? Prepping for CentDivs on Saturday and Sunday.. so far 7 entrants in STX... 2 BMW 325's (one is a 2 driver car)... a late model Nissan Sentra, a 2012 Mustang, and a WRX..I know that one of the Bimmers is a national level car/driver, so I will see where I stand.. I am pretty sure this is going to be followed by the national staff as well, *at least thats what a little birdie told me* Hopefully I can step up and drive to that level also and the car performs the way I want it too. Plus I will still be sorting out the car and the settings on the suspension. ahhhh sooo much to do. More later. Have a great 4th everybody.Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#395 |
Conedancer
.. hmm never knewBill
#396 |
Drives: Widebody '94 Miata R-Package
I had KW V3's on my RSX and they were amazing.
![]() I <3 my Miata. But I <3 my new BRZ even more! |
#397 | |
i'm sorry, what?
Drives: Canada
fatty tubes = mono also don't hold me to this but i believe only gas shocks can be inverted
#398 | |
Conedancer
#399 |
i'm sorry, what?
Drives: Canada
yeah i don't know why those pinks were labeled as inverted because as far as i'm concerned their design is standard. The body/housing is attached to the hub and only the shaft is attached to frame.
inverted generally means the body housing attached to the frame and the shaft to the hub. perhaps inside they are different, but as far as i'm concerend they are a regular type of damper.
#400 |
Conedancer
I hear ya... Motorcycles have a distinguishing 'inverted' look... where they connect to the triple clamp.... no biggie..I think we are on the same sheet of music..
![]() Bill
#401 |
Drives: 2013 FR-S Asphalt
Only monotube shocks can be inverted. Frankly inversion isn't a big deal its still a damper and most of the weight is in the housing not the damping portion anyway.
#402 | |
Drives: Legacy GT
Well, how else are you going to invert a strut suspension? The damper cartridge is "inverted" in the housing, which does slightly decrease unsprung weight but mostly makes the assembly stiffer and stronger. IMO this type of thing is more worthwhile for a strut than a shock because of that. Starting to get off topic though. Looking forward to the results from today. |
#403 |
Conedancer
its a 102 out... waiting till this evening to adjust..
...toooo damn hot..
#404 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
Well... you CAN invert certain twin tubes which are designed for it. Standard twin tube designs have pressurized gas in the reservoir tube, when you invert this design, gas enters the base valve, gets in the pressure tube, and messes up the damping forces. However, there are twin tubes which are designed without this free floating pressurized gas. Most steering dampers for trucks(mounted horizontal) are twin tube, they just use a foam sleeve or gas bag as the compressible volume, this prevents the gas from going through the valving. there is nothing preventing you from "inverting" a twin tube that is designed like this and it working fine. We used to do some specialty inverted twin tube designs for lifted truck specialty applications and motorcycles when I used to work as an aftermarket damper engineer.
Last edited by Sccabrz192; 07-04-2012 at 08:43 PM. Reason: Edited for clarification |
| The Following User Says Thank You to Sccabrz192 For This Useful Post: | Scooby South (07-04-2012) |
#405 | |
Detroit Region, MI
| The Following User Says Thank You to Sccabrz192 For This Useful Post: | 7thgear (07-05-2012) |
#406 |
Conedancer
Final adjustments...
done..
| Subaru/Scion warranty and autocross | Ribface | Tracking / Autocross / HPDE / Drifting | 55 | 06-17-2015 08:30 PM |
| Will you Autocross your 86? | Ribface | Tracking / Autocross / HPDE / Drifting | 131 | 06-22-2012 05:48 PM |
| Which autocross class? | jpdarty7 | Tracking / Autocross / HPDE / Drifting | 66 | 06-21-2012 05:53 PM |
| FR-S at a CA Autocross | oneday | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-26-2012 03:38 PM |
