Old 08-08-2017, 09:24 AM   #4103
amcp1
Drives: frs
Tagging @CounterSpace Garage and @Jackson Racing, maybe they have some thoughts on the matter. I couldn't find any leaks last night.
amcp1 is offline   Reply With Quote
Old 08-08-2017, 01:52 PM   #4104
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
Jackson Racing Supercharger Owners Thread
Extra filters can be ordered from @CounterSpace Garage or directly from @Jackson Racing.
There is a non-JR branded version of the filter availabe, and you'll also want to buy a K&N cleaning kit.
Thanks Mike. I already have cleaning kits for my motorcycle filters. I hate cleaning those things. Too much oil, too little oil...
keithr is offline   Reply With Quote
Old 08-08-2017, 07:46 PM   #4105
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
For tech support, give us a call, or email tech@jacksonracing.com
-Jackson Racing Staff
Chris
Jackson Racing is offline   Reply With Quote
Old 08-08-2017, 08:08 PM   #4106
amcp1
Drives: frs
Thank you Chris. Just replied to an email from tech@jr.
Old 08-09-2017, 10:49 AM   #4107
amcp1
Drives: frs
I believe the source of the problem was found. The bypass valve (diverter valve) does not hold vacuum. A buddy tested it at idle and found the valve lets unmetered air into the intake hose tee at the back of the intake manifold. Thats a decent air leak. FYI folks.
Old 08-09-2017, 01:09 PM   #4108
Sleepless
Drives: 2016 FR-S
Had the same problem. Have you taken it off to look inside? Mine partially melted and bits of its plastic got into the valve, preventing it from fully closing. A few others have had the same issue. Jackson does not offer a solution but at least one person switched to an aluminum valve.
Sleepless is offline   Reply With Quote
Old 08-09-2017, 11:20 PM   #4109
amcp1
Drives: frs
I wasnt able to see anything inside the unit out of the ordinary.
Old 08-12-2017, 04:02 PM   #4110
mrg666
pessimistic skeptic
mrg666's Avatar
Is this a compatible bypass valve?
https://www.amazon.com/gp/product/B01L0F2LD2
Old 08-13-2017, 12:57 PM   #4111
LS1M
Drives: 2015 BRZ
I think it's backwards. The bypass valve on the JRSC opens when there's a vacuum pull on the diaphragm, to prevent compressor surge on closed throttle. The one shown in the link looks like it opens at high pressure.
LS1M is offline   Reply With Quote
Old 08-13-2017, 09:38 PM   #4112
mrg666
pessimistic skeptic
mrg666's Avatar
Thanks! Do you know any other compatible bypass valve? I want to replace my plastic valve with a metal one.
Old 08-14-2017, 04:30 PM   #4113
Sleepless
Drives: 2016 FR-S
See this post in this thread: http://www.ft86club.com/forums/showp...postcount=4004
Old 08-14-2017, 06:52 PM   #4114
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by Sleepless View Post
If that xspower diverter for Audi, Porsche is working for our JRSC kit, then the one I linked above at Amazon should also work. They are for the same cars.
Old 08-24-2017, 04:32 PM   #4115
ozone42
Drives: SSM BRZ Limited
Anyone have a recommended replacement bumper that fits better?
I've searched the thread, and I know people say it can be done with the stock resevoir, and I believe that's sometimes true... sometimes.
But it's not true with mine, hoping there's some options out there!
ozone42 is offline   Reply With Quote
Old 08-25-2017, 01:19 PM   #4116
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
If it is not fitting, then you have the piping aligned incorrectly.
JDMChris is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
