Old 08-07-2017, 09:57 PM   #15
Submarinesonce
Drives: Frs
leave the suspension alone unless you want to spend a fair bit on it.
better tires, light wheels, catback, header, tune, brake pads.
that will make your car just a little quicker, grippier, and make it stop shorter for around $3-4000 depending on the parts you pick
Submarinesonce is offline   Reply With Quote
Old 08-07-2017, 10:01 PM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by Xaftos View Post
Not a troll. I just don't think I know how to research properly *shrug*
Well good. Looks like you already have a lot of good responses.
My .02. Sounded like you are on a budget. If I had one of these cars with a tight budget I would:
1. Get an OFT,
2. Get whatever I could to free up breathing out the rear that my state will allow (headers, pipes),
3. Drop in a filter,
4. Run e85 if available.
After that, your budget is way blown.
And cosmetics, do whatever the fuck you want. No one cares and it is your car.
RallySport (08-07-2017)
Old 08-08-2017, 09:17 AM   #17
Thank you so much, and that's exactly why I've been waiting and observing for so long because I'm just unsure. If a header, drop-in, and tires are what you recommend then I will go ahead and begin. Is my header choice in the OP up to par? I've heard good things.
I generally try to stay away from recommending certain products since I have not used them myself but from all information your choice of that header is a wise one.
Keep in mind that just adding a header (or other parts for that matter) without a tune is going to give you minimal gains. The ECU can adjust to some degree but to take real advantage of changes you need to tune for them.
Old 08-08-2017, 09:53 AM   #18
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Originally Posted by carsebuco View Post
New tires. Finally switched from stock and holy chit, it makes a huge difference.
Not just new tires,new wider wheels in general. I went from the shitty 215's to 235's and you wanna talk about a difference! The car sticks to the road like glue now! I feel like this is the easiest mod to significantly change the driving dynamics of the car.
I've heard that putting in a short shifter is another easy change,that's somewhat cheap,you could do to improve driving dynamics.
I personally feel like a new full exhaust setup is pretty much a waste of money unless you are going FI. The "gains" aren't worth the price. All you are really paying for is sound,which leads to a placebo effect that you think the car is faster.I have heard that a TRD exhaust (and I'm sure others as well) helps with the torque dip,but I still just don't feel like it's worth $1000+.
Th3rdSun is offline   Reply With Quote
Old 08-08-2017, 10:08 AM   #19
A catback does nothing for performance but a header and tune will show some gains.
If the TRD catback exhaust has any effect on the torque I have never noticed it. The improved sound is worth every penny to me though.
Old 08-08-2017, 12:09 PM   #20
Sapphireho
Famous Potatoes
Sapphireho's Avatar
The tuner (William Knose of Delicious Tuning) who tuned my car said I could get 10 more HP if I put the stock exhaust back on. They say the TRD is more restrictive. They said they cut apart a TRD and the pipes are actually smaller. I'm still keeping mine. I love the sound and the look. I have enough HP.
Clipdat (08-08-2017), Tcoat (08-08-2017)
Old 08-08-2017, 12:17 PM   #21
DarkSideFRS
Drives: 2013 pearl white FR-S
inlet tube, sound generator delete and k&n filter
DarkSideFRS is offline   Reply With Quote
Old 08-08-2017, 12:57 PM   #22
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
IMHO get a Apexi drop in filter and call it a day. Enjoy the car for now and learn how to drive it well. As for headers just FYI, your power train warranty will not be honored once you install aftermarket headers. If you don't care about the power train warranty then do whatever you want. Join your local FT86 Club and then you can hear some exhaust systems for yourself. Suggestions for catless headers are Gruppe S, Tomei and catted JDL. Just my 2 cents!
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
The Following User Says Thank You to 86geek For This Useful Post:
Tcoat (08-08-2017)
Old 08-08-2017, 01:22 PM   #23
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Instead of telling you what you should do, I'll just tell my favorite mods on my car, and you can take it for what it's worth. Everything else is in my journal, link in signature.
Gruppe-S UEL header
OFT E85 tune
TRD quickshift kit
Wheels/Tires (too many options to be specific)
BigTuna is offline   Reply With Quote
Old 08-08-2017, 01:36 PM   #24
fierostetz
fierostetz's Avatar
Drives: '87 Buick GN, '16 500 Abarth
No luck w/ magnusson-moss on that?
Past Rides: '87 Mazda 626 with junkyard turbo, '86 Fiero SE v8 swap, '87 Fiero GT v8 swap, '87 Grand National, '96 Nissan Maxima (s/c), '04 Dodge SRT-4, '08 VW Rabbit 5cyl, '10 VW Golf 5cyl.
Current: '87 Grand National '16 Fiat 500 Abarth (dumb, immature fun!!)
Shopping for a BRZ/'86 right now as an additional toy.
fierostetz is offline   Reply With Quote
Old 08-08-2017, 01:39 PM   #25
Somerandom18
Drives: 2017 manual BRZ
This is a 2017. Stop saying get a filter. It doesn't do much if anything for a 17.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
The Following User Says Thank You to Somerandom18 For This Useful Post:
Tcoat (08-08-2017)
Old 08-08-2017, 01:46 PM   #26
It helps the owner feel like they did something.
Good point though.
Old 08-08-2017, 01:57 PM   #27
Submarinesonce
Drives: Frs
The low end torque bump from a header and tune is definitely worth the money IMO.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Old 08-08-2017, 02:11 PM   #28
86geek
86geek's Avatar
Nope, according to dealership. My dealership specifically said aftermarket header the warranty will not be honored. As for drop in filter there's one available for 2017 models. Blitz I think is the brand
gt86, header, modding, mods, throttle body
Advice for Mods Bakchoii Scion FR-S / Toyota 86 GT86 General Forum 19 07-16-2015 02:28 PM
Need advice AnthonyQ Engine, Exhaust, Transmission 1 01-04-2015 06:01 AM
I Need Advice About An Fr-s! DViper0020 Issues | Warranty | Recalls / TSB 13 05-09-2014 10:15 AM
I need some advice The Robot Cow Scion FR-S / Toyota 86 GT86 General Forum 16 04-06-2013 03:43 PM
Advice EDCOVEY FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-10-2012 08:16 AM
