Old 07-04-2012, 12:38 PM   #29
Boxer-Guy
Boxer-Guy's Avatar
Drives: Not Yet
wow runfile15 is nice (170hp)
Boxer-Guy is offline   Reply With Quote
Old 07-04-2012, 12:44 PM   #30
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Just saw this!
Thanks for posting this up.
I think the gain is most likely from the advance multiplier increasing allowing the car to run more timing.
I suspect it is a combination of things.
First, I only run shell and chevron 93 octane, so it is likely that the motor is not having to pull any timing for knock response. Toyota's ECUs actually start at Maximum timing, and then they use a long term and short term knock trim to pull timing back out to the currently desired level. You can reset this value by resetting the ecu (disconeccting the battery). Those values both exist in the FRS ECU when viewed with a Toyota Techstream scantool, so I suspect it is the same as the rest in that respect. Now there MAY have been some fuel related timing reduction for the first pull, but it did have 93 in the tank from an Exxon station across from the dealer.
And a good deal of it is from break in. We actually felt a huge difference after we took it to the drag strip at @300 miles or so. We made over 16 runs, and about the first 12 were literally back to back. The next day there was a definite increase in power. I have also seen a corresponding increase in fuel economy even when driving hard.
It should be noted the ambient temps were warmer on the more recent pulls as well.
Boosted2.0 is offline   Reply With Quote
Old 07-04-2012, 12:45 PM   #31
Boosted2.0
Boosted2.0's Avatar
we had one run that was even higher, but this one was the closest to the middle of the pulls we did this time around.
Old 07-04-2012, 02:02 PM   #32
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
So, this means ~15% drivetrain loss assuming the engine is truly putting out 200hp at the crank?
Not too shabby. Eh?
Chewie4299 is offline   Reply With Quote
Old 07-04-2012, 02:21 PM   #33
Visconti
Drives: 05 STi
Although that might be the case for Toyota ECUs this is not the case for Subaru - the ecu in these cars.
After ecu reset the car does not run maximum advance. Car needs to e given a drive cycle and go thru some things in order for the advance multiplier to jump up allowing maximum advance.
By default the advance multiplier is at .7. Car won't see full advance until the advance multiplier jumps up to 1.0
John
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
jedibow (07-05-2012)
Old 07-04-2012, 03:16 PM   #34
Dimman
Kuruma Otaku
Dimman's Avatar
I thought they both use Denso?
Because titanium.
Old 07-04-2012, 03:41 PM   #35
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Not bad numbers at all.
SUB-FT86 is offline   Reply With Quote
Old 07-05-2012, 12:37 AM   #36
Boxer-Guy
Boxer-Guy's Avatar
Drives: Not Yet
I wonder if a full exhaust on this car would raise the HP from
170 to maybe about 5-10 more horses or just stay the same ?
Old 07-05-2012, 01:35 AM   #37
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
John
Is the table temp based? Or load based? Interesting...
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-05-2012, 12:00 PM   #38
ImAwesome
Drives: 99' M3, 13' SWP Brz
haven't been reading much, Nameless has seen >20whp from their full exhaust and Vtune has another 18wp gain from tuning, I'm sure if you tuned in the full exhaust and an intake you could see >40whp gains
ImAwesome is offline   Reply With Quote
Old 07-05-2012, 01:53 PM   #39
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
That would be incredible; same lvl of gain seen from the K20 in my RSX-S.
I would be seriously impressed with the boxer & DI if it could manage that =D
Here's to hoping for the best results!
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Old 07-05-2012, 01:54 PM   #40
Visconti
Drives: 05 STi
Would be VERY awesome
Old 07-05-2012, 02:38 PM   #41
jeebus
John
unless of course, you set the advance multiplier to 1 through a tune.
jeebus is offline   Reply With Quote
Old 07-05-2012, 05:12 PM   #42
Boxer-Guy
Boxer-Guy's Avatar
Drives: Not Yet
It would be awesome if a tune by it self would offer just 20-25whp.
We just have to wait and see.
Oh and thanks for message Boosted2.0
BRZ on the dyno Symbiont BRZ Photos, Videos, Wallpapers, Gallery Forum 1 05-22-2012 01:17 PM
When will magazines start testing the performance? swift996 BRZ First-Gen (2012+) — General Topics 10 03-23-2012 02:10 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
