go_a_way1, MisterSheep
Old 08-06-2017, 10:30 PM   #17249
Kaotic Lazagna
Drives: GR Corolla
Drove to an 86 day event and filled up with 94 octane (rarity here in Cali) on the way home (didn't want to go from 101 octane straight back to 91).
Old 08-07-2017, 01:53 AM   #17250
notout86
Drives: GTS 86 auto
Originally Posted by KDad2 View Post
I hit a semi truck tire on the way to work today. There was no time to avoid it without causing a wreck or more damage to the car. Bent up my bumper real bad. That was the first thing to pop back into place and reattach just to get home. The impact also pushed in the grill so that it was loose and bent the license plate in half. Also, my bumper is cracked and has a hole where the end of the crash beam passenger side is located. It was actually sticking out of the hole. Tore up my under panel pretty good. Luckily no damage that I can see to the radiator. I was able to get the car on jack stands and put the bumper back on after removing what was left of some damaged clips. I'm glad I have extra clips. For most of the front skid plate I was able to drill holes and use zip ties to stitch it back together. Some tabs are broken on the bumper and used some more zip ties there. It could of been worse and I'll probably take it in to have it inspected for more damage. So, at this point, I can replace with an OEM bumper, upgrade to a custom bumper, patch the hole and use rattle can touch up, or just slap a sticker on it and be done. As a daily driver, it has a lot of road rash on it. I'm leaning more towards patch and touch-up paint, or a sticker to cover the damage.
Ultramroon has a link (with part of his forum signature) that leads to
For service & mechanical
https://demos.starbase7.net/t3Portal..._rm_index.html
This link has plain language descriptions & diagrams
For Collision repairs/ bodywork
https://demos.starbase7.net/t3Portal..._cr_index.html
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post:
KDad2 (08-07-2017)
Old 08-07-2017, 08:58 AM   #17251
Lava
@Tcoat may be able to verify, but I believe the brown in the engine bay is what Lava looks like before the clearcoat is applied. Since they don't apply the clearcoat in the engine bay the color is brown.
Old 08-07-2017, 09:11 AM   #17252
Teseo
Drives: frs
Mine looks orange, like a pumpkin
The Following User Says Thank You to Teseo For This Useful Post:
Dadhawk (08-07-2017)
Old 08-07-2017, 09:14 AM   #17253
Guess I'm wrong then, just seems I recalled seeing someone had said that at one point.
Old 08-07-2017, 09:40 AM   #17254
Ashikabi
Ashikabi's Avatar
Guess I'm wrong then, just seems I recalled seeing someone had sad that at one point.
It makes sense. It's a similar color to what the paint looks like when it's cloudy or dark out. The clear likely has the metallic flecks or whatever in it. Less of a "clear" coat and more of a "top" coat
Password JDM has some nice covers that would hide nearly all of the ugly in the engine bay. Probably just go with that instead of paint. There is a lot of ugly to be hidden in there
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 08-07-2017, 10:50 AM   #17255
At least it's not as bad (in my opinion) as the Solar Orange cars as @n0thing showed in his pictures below in this thread:
Old 08-07-2017, 10:51 AM   #17256
Teseo
Drives: frs
Ahhh... thats the new model
Old 08-07-2017, 10:56 AM   #17257
Ashikabi
Ashikabi's Avatar
Damn, that's awful. It is indeed worse
Old 08-07-2017, 11:13 AM   #17258
You can vpcall it orange but my eyes see a more brown tint. It is the base paint without the pearl coat so there is nothing to refract the light and give the dazzle effect that make lava look different depending on light source.
Old 08-07-2017, 11:18 AM   #17259
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Originally Posted by Quentin View Post
My road bike fits well. Only the front wheel has to come off.
Didn't have to drop the seatback to do that? Nice!
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 08-07-2017, 12:47 PM   #17260
Overdrive
Sittin' Sideways
Overdrive's Avatar
Cloudy day today, but I can help with this a bit, at least for visualization. Here's my engine bay (yeah, I know, it's a bit dirty) and you can see on the left is the original fender. On the right is the replaced fender after I got hit in late March. The whole engine bay has that brownish dull look to it, and the only part under the hood that matches the outside body color is the driver's side fender where it attaches. Even the bolts attaching it still have the original dull color to them.
-O/D
2016 FR-S, Hot Lava
The Following User Says Thank You to Overdrive For This Useful Post:
Old 08-09-2017, 05:45 PM   #17261
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
Installed new spoiler
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
The Following User Says Thank You to Raven86Project For This Useful Post:
RallySport (08-10-2017)
Old 08-09-2017, 07:02 PM   #17262
mrg666
pessimistic skeptic
mrg666's Avatar
Looks pretty clean to me. It seems like they replaced the fender pretty nicely. You are missing a screw on the driver's side headlight though.
