#71 |
#72 |
Drives: '13 BRZ
^^^^ weird. I just ordered these a few weeks ago and got them.
#73 |
Drives: DGM BRZ Limited
#74 |
Drives: 2014 FRS SR1
Anyone know where to source these anymore?
#76 |
My VTEC fluid is full
Drives: EFF JAY
Sorry for the noob question, but will this fit the FRS bumper?
https://www.japanparts.com/parts/detail/49087 |
#77 |
Drives: 2014 Subaru BRZ
It should. Thats the same one I ordered
Sent from my Pixel XL using Tapatalk |
#78 | |
| The Following User Says Thank You to Ashikabi For This Useful Post: | iLuveKetchup (10-13-2017) |
#79 |
Drives: 2019 Mazda Miata RF
#80 |
Don't have any, sorry. There is a plastic bracket/mount that surrounds the headlight. This is what the bumper hooks onto. That will need modified slightly for clearance. You'll see when you try to mock up the bumper. If you don't use the included screws, you won't need to do this. If you don't use the screws, there will be a chance that these bumper reinforcement tabs will pop off. It's a small chance but it could happen
| The Following User Says Thank You to Ashikabi For This Useful Post: | Gunman (10-15-2017) |
#81 | |
The modifications being mentioned involve filing down a notch so that the forward most screws have room for the nuts. There’s a super tight gap between the fender and headlight bracket that just won’t accept the thicker, modified bumper tap. And I didn’t see this mentioned but when you install the bumper there’s 2 things you have to keep in mind. 1) When you push the bumper under the front of the headlights, you want all four tabs BELOW the plastic flap. The inner most tabs can easily slip over the plastic flap and cause stress on the ends of the bumper. 2) When you push the bumper under the fender to finish up, use one hand to pull the bumper up and over the clip on the headlight bracket (basically squish the bumper into to the fender simulating zero gap). Use your other hand to push on the bumper to apply pressure, and carefully pull the bumper down and over the headlight bracket (while applying pressure still). I didn’t hear a gratifying click or anything but damn I’ve had this gap for years and it’s finally gone. |
| The Following 3 Users Say Thank You to norcalpb For This Useful Post: |
#82 |
Drives: EFF JAY
For those that have installed the new version, did you use the screw/nut AND also glue?
#83 |
Drives: 2013 Scion FRS
So I basically fabricated my own version of this and it was a fail whatever I did. QL-25-SB "Mini" http://www.ft86club.com/forums/showthread.php?t=106110
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
#84 |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Just bought this. Going to give it a try with the MY2017 bumpers.
| The Following User Says Thank You to Elliotw For This Useful Post: | Tristor (02-28-2018) |
| bumper sag repair, anyone tried this yet? | nickmerronesucks | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 07-28-2016 10:14 PM |
| Bumper repair | keneyy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 10-19-2015 05:30 PM |
| WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement | mariolefty1 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 05-06-2013 04:52 PM |
| Front Bumper repair | grgonium | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 01-15-2013 06:25 PM |
| Bumper Repair | Thatruth2001 | Northwest | 1 | 09-12-2012 01:15 AM |
