#295 | |
I challenge you (or anyone else) to do the math with the formula shown in post # 272. If you accept, please indicate what factors you used for the variables in the formula. ![]() humfrz |
#296 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (08-06-2017) |
#297 | |
Drives: Toyota GT86 Coupe Red (UK)
My point was to get across that small increases in speed require lots of power increase. So claims of cars going 23 mph faster than the stated manufacturer number (137mph I believe, from memory) are highly unlikely. Also that speedo readings are also highly unreliable. GPS for that matter isn't much better. It greatly depends on the GPS used, it's accuracy and refresh rate and any equations used to smooth the usually jumpy data. Also depends on how straight and level the road is. A proper calibrated laser or radar reading or a track day timing beam speed trap I might put more value in.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#298 | |
The published COD for a 2013 FR-S is 0.27. The frontal area could be estimated (just take a look see at it from the front. OR, someone who has a CAD program could calculate it. So, are you gonna do the math or not ...... ?? I would, but it's my nap time ..... ![]() humfrz |
#299 |
Drives: 2015 Limited
When people post their speeds, it would be good to know if they are stage 1/2/3 and if Manual or Auto or have changed their Final Drive Ratio. Also many tunes remove the speed limiter. As to this thread giving the cars a bad rep, it's too late. These are one of the most ticketed vehicles. People just need to try to speed "Safely". Also be aware that negligent driving is a felony in Canada, so if you get busted in the US for Negligent you are not eligible to travel to our Neighbor in the North.
#300 |
Drives: 2017 manual BRZ
So everyday driver europe did a run and hit 149 mph in a 2017 Toyota 86. That's with a 4.3 FD.
Sent from my Pixel XL using Tapatalk |
#301 | |
power=147000 (fly wheel watts) aird=1.3 area=2.28 (sq m) cod=0.27 x = (2*power) / (aird * cod * area ) v = e(l(x)/3) (this is a cube root) v * 2.23694 (m/s to mph) 160.20993999770118933534 The frontal area is a guess from the total width and total height on the spec. 147,000 watts = 197 bhp. When we modify that to "wheel hp" from a bit of googling we get: power=117000 (157 wheel hp) x = (2*power) / (aird * cod * area ) v = e(l(x)/3) v * 2.23694 148.47236739928096565100
#302 | |
Your figuring appears to be accurate ........ However, the values I used are a bit different. I used: 160 WHP (averaging several values reported on the internet) density = 1.3 Cd = .27 frontal area = 21.2 sq. ft. (figure published by Car & Driver) Plugging those numbers into the formula, my abacus gives me a calculated top speed of a stock 2013 FR-S, of roughly ...... 157 MPH. (I think your estimated frontal area of 2.28 m squared is a bit high) Your thoughts ......?? humfrz |
#303 |
Drives: 2017 Toyota 86
So I did another speed test last night on I-405, I got it to 134 again, kept going, but it wouldn't climb anymore, I suppose the MY17 is electronically limited to 134, I was getting rev bounce like you'd see while bouncing off the rev limiter, but this was only at like 5.5kish in 6th, and the needle was bouncing slightly and not letting me go faster, so my speed limiter is 134.
#304 | |
I wouldn't think so, but I don't know ..... ![]() humfrz |
#305 | |
Drives: 2013 Scion FRS
Sent from my HTC6535LVW using Tapatalk |
| The Following User Says Thank You to MurderousPandas For This Useful Post: | humfrz (08-07-2017) |
#306 |
It certainly felt like it, it's also hot as ass in our state right now, so maybe the conditions weren't as good as they could be. But it certainly felt like the revs were bouncing as if it were limited.
#307 | |
![]() ![]() humfrz |
#308 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
Could be Europe and the rest of the world don't have any limitations in place (Autobahn needs make a good case, after all), but looks like it's just shy of 150 if you have enough time and road to get there. Tom certainly loves what it can do at any speed.
[ame="https://www.youtube.com/watch?v=dPtX42Ttkqo&t=1s"]2017 Toyota GT86 (86, BRZ) Review - Autobahn and Hatch Comparisons - Everyday Driver Europe - YouTube[/ame]
-O/D
2016 FR-S, Hot Lava |
| Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
| Need For Speed... Really? | Texas BRZ | Tracking / Autocross / HPDE / Drifting | 61 | 01-11-2013 11:59 PM |
| Top Speed | L3P47 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 12-18-2012 12:06 AM |
| top speed | JLMtm | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 10-30-2012 09:23 AM |
| speed | eindio | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-27-2012 10:59 AM |
