#309 |
Drives: '14 981CS, '99 NB1
#311 |
Drives: Q5 + BRZ + M796
#312 |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Anyone one here use their,own freight forwarding company to get a harrow kit?
I'm looking for quotes.... some shipping quotes I've had are over $1000!!!
I like driving!
#313 |
Of course it matters. HP is a byproduct of torque at RPM. As VTEC motors can keep their torque from falling off at high RPM due to the additional lift/potential flow provided, they will generally have more HP than another motor of the same displacement.
#314 | |
This is precisely the principal upon which a restrictor works. Whether you have a 2L engine, or a 4L engine, if you have a restriction at the intake... |
| The Following User Says Thank You to CSG Mike For This Useful Post: | CxG (01-05-2018) |
#315 |
Drives: FRS, Supra, Colorado D, GLC63
| The Following User Says Thank You to The Racers Line For This Useful Post: | 86 South Africa (08-08-2017) |
#316 | |
Reckon that's about the best I'd get?
I like driving!
#317 | |
Drives: GT86 Cosworth
The TVS chargers are limited to a pressure ratio of 2.4 (that 1.4Bar boost) and they have a 20k rpms limit. On the FA20 with a pressure ration of 2.2 and e85 Harrop could not squeeze any more power (more boost = less efficiency due to moving into a very inefficient region of operation for the SC). On the K20 with a higher rpm ceiling for the same SC rpm at peak revs (and thus same airflow) it runs less boost due to lower restriction in the head. Therefore you can spin it faster whilst staying within spec and get more power. The TVS1320 hits max boost way before it hits max rpms on the FA20. Stock harrop runs about 8k rpms, not even half but you ant run it at 20k as the pressure ratio will be way out of spec. |
#318 | |
Likewise, a stock K20 would never be able to even do 1 pull at this power level. |
#319 |
Well I have a built engine and could run 1.4bar of boost easily.
Sent from my S60 using Tapatalk
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | CSG Mike (08-05-2017) |
#320 | |
Sent from my SM-G935F using Tapatalk |
#321 |
Drives: none
Does anyone know what the scaling is for the IAT sensor Harrop uses in the kit? I can't seem to find any information on it. I'll be dropping Harrop an email tonight but they might be slow to respond.
Thanks! -Matt |
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 04:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
