#4075 |
pessimistic skeptic
AUC is "Area Under Curve", right? What aspect that determines the AUC is more important? Rev range on the horizontal axis or power peak on the vertical axis? I think, given the same weight, a more powerful car can have a disadvantage if it needs to shift before the other less powerful car keeps building up the power on a wider rpm range. Do you agree?
#4076 |
Drives: UK GT86
If 2 cars have the same peak power, similar gear ratios but one has more torque over the entire RPM range then that one will be quicker. This is undoubtedly the case with V8 engines with similar peak power to weight ratios. Throw in longer ratios with more torque to put down then there's no chance.
.: Stealth 86 :.
#4077 | |
![]() FA20 + C30-94 JRSC + header (lower line is generic UEL + E85, higher line is Ace + E70) ![]() Notice the S2000 has more area under the curve, particularly noticeable on the torque side. |
#4078 | |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#4079 | |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
#4080 | |
Drives: Q5 + BRZ + M796
#4081 | |
Torque is force times distance of lever arm. Force is mass times acceleration. Acceleration is the change in velocity or distance over time. A large, flat, torque curve would feel like a kick in the pants at any moment the foot is dropped, and that acceleration or change in velocity would feel constant or consistent. In contrast, the acceleration or force with the JRSC would not feel high at the start of a long gear from low to high rpms. Instead on gaining 10 mph per second with a flat curve, the JRSC might gain 2 then 4 then 6 then 8 then 10. As you can see the power curve would still be linear but forces wouldn't be felt until the end of the rpms. The force behind gaining 10mph per second or maybe 8 is what feels like a knock in the pants. To me, this is why it may feel smooth. Because the forces build gradually and are smaller at lower rpms so they don't shock the driver with the feel of instant torque unless the driver drops a gear to throw the rpms into higher rpms where there is more torque. Last edited by Irace86.2.0; 08-03-2017 at 08:13 PM. |
#4082 | |
#4083 |
Why use synonyms for force?
Im describing low end torque/force and a flat curve or constant force vs a car that has variable force that builds low to high. Kinda like the difference between a Tesla and most vehicles where the force hits instantly and constantly; it sends you against your seat and the pressure against you feels constant like someone tossed a fifty pound blanket instantly over your body. The JRSC would feel like a five pound blanket is weighing against your body at first and is slowly getting heavier and heavier pushing you into your seat more and more until at peak rpm it finally feels as heavy as a fifty pound blanket. The JRSC would feel far less intense and much more gradual. In a way, your body can prepare for it like warming up to faster and faster pitches with a baseball than getting a surprise pitch at 100mph with no warning. Im sure this makes for an interesting and maybe unpredictable driving experience. Yes more rpms means more torque, but without a flat torque curve it may be hard predicting how much force the driver will be getting. |
#4084 | |
Force over time is acceleration. Change in force over time is Jerk. Force applied over time is impulse, aka the integral of the force over time. |
#4085 |
Drives: 2013 FR-S Argento
So you're saying anyone who drives a V8 car (mustang,camaro,vette) is an impulsive jerk?
Sent from my SM-N920V using Tapatalk |
#4086 |
CAR-AHOLIC
I was not prepared for your post while having my morning coffee, you sir owe me a keyboard.
#4087 | |
Drives: 2013 FRS / 2013 427 Vert
You can include several of the newer turbo 4 cylinders as well. Our Audi weighs 3200 pounds, makes about 350/350 at the crank but hits peak torque at 1900 rpm. Add in AWD and DCT and it simply leaves my FRS by bus lengths. Similar results for the 718 S which is a much faster street car than the previous flat 6 versions and I've heard it's a near stalemate with the GT4.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#4088 |
pessimistic skeptic
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
