Old 07-16-2017, 11:42 AM   #15
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by reynierpm View Post
First of all thank you. Now it's a good idea to start changing, maybe, part by part and with this I mean follow what you did before by starting first with the tweeters, then if I don't like continue with the middle range and so on.
In general, drivers aren't interchangeable.
Without sensitivity matching (and a few other things) you may end up with crap frequency response... And it can be tough to figure out what's going on. It can even sound good if its just louder in the right places by making you hear things in a new way, yet still have bad frequency response. Lots of big box speakers play these tricks to stand out in a crowd, but the reality is they grow very tiring to listen to at best... And get the wrong mix of parts or wire up wrong for those parts and you can end up with big holes in the sound...
C
The Following User Says Thank You to cjd For This Useful Post:
pfaffendorn (07-16-2017)
Old 07-31-2017, 04:03 PM   #16
reynierpm
Drives: Toyota 86 2017 Black
Does any one knows if this C5 650 will fit in this car?? As per this post I am not sure at all.
Also does any know the amp measures?
reynierpm is offline   Reply With Quote
Old 08-02-2017, 03:47 PM   #17
driggity
Drives: Silver Coupe with a Boxer
I've already replace the OEM head unit for the Sony XAV-AX100 which is pretty good (sometimes I get some issues with Bluetooth)
What Bluetooth issues do you have? I've been considering this head unit because I like Android Auto and the physical volume knob but I pretty much only use Bluetooth so that's got to be reliable.
driggity is offline   Reply With Quote
Old 08-02-2017, 03:51 PM   #18
reynierpm
When I turn on the engine and the head unit goes on sometimes - is not all the time - I can't connect the phone over Bluetooh, I am not sure if it's a problem from the Unit itself or from the wiring
Old 09-14-2017, 04:43 PM   #19
kowalski
kowalski's Avatar
Drives: 2016 brz
Originally Posted by Chimera View Post
the front mid is largely un-necessary. it adds complication and options, but for a basic build, a 2 way component is good.
I just did a front-mid install of jl audio c1-400x, you can check it here.
I also thought that it woul'd not make much of a difference but to my surprise it did. So I woul'd rather suggest that you give it a try. You can check speakers in these locations just fixing the wires with electric tape to the harness (once OEM speaker removed) and see for yourselves befor fitting anything. I agree on the rear speakers though. They do not do much. I also like to fade the sound a little bit forward and to the passenger side. That's how I feel my system is more balanced. But that's just me.
PS: @Chimera I woul'd thank you for the threads and comments also but I do not have the option to do so, yet.
kowalski is offline   Reply With Quote
Upgrade sound system/ Pioneer HU and JBL sub Helios Electronics | Audio | NAV | Infotainment 25 06-19-2017 09:02 PM
Sound System Upgrade - Lots of Questions from a Relative Newbie Stang70Fastback Electronics | Audio | NAV | Infotainment 15 06-08-2016 12:17 AM
Complete Sound System Upgrade Help! vinceqt Electronics | Audio | NAV | Infotainment 16 07-05-2015 06:53 AM
easy OEM Sound System Upgrade with DSP OnkelC Electronics | Audio | NAV | Infotainment 0 05-24-2015 09:12 AM
Can you upgrade the sound system for around $500? Jar Electronics | Audio | NAV | Infotainment 4 03-26-2015 06:44 PM
