Old 07-25-2017, 09:15 AM   #855
zeal86
zeal86's Avatar
Drives:
Originally Posted by ka-titties View Post
As a welder/fabricator, you should definitely have the outside of the seams welded, not the inside. If you weld only the inside, the outside is going to look weird.
Yes... I understand that... I'm looking for someone that can do it. Not one of my skills.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 07-25-2017, 10:14 AM   #856
zeal86
zeal86's Avatar
Drives:
In my final version... aka my personal one, I want it tig welded for sure on the outside seams. I'm currently using Devcon aluminum putty on my two prototypes to see how well it works. I'm using it on both inside and outside seams... I will sand the outside seams round when dry. If it looks ok I will make others using Devcon.
@ka-titties What is your opinion on Devcon aluminum putty in general? Do you think it would hold up in this particular application?
Old 07-25-2017, 01:18 PM   #857
zeal86
zeal86's Avatar
Drives:
Pics of Devcon Aluminum Putty applied on the inside and outside seams...
[Edit] Btw, the pictured aluminum is not the weldable type, it is 2024... Luckily I have access to some 6061 T6. 040" as well.
Once dry I'll sand the Devcon to the proper contours
Old 07-26-2017, 08:30 AM   #858
ka-titties
Drives: 2013 BRZ Limited 6MT
I dont have a ton of experience with the Devcon, but I think it should hold up for a while. My only concern would be the affect of vibration over time. But, if you're planning to build one out of 6061 anyways, get a trusted welder to stack some pretty dimes down the outsides of those joints and you'll be good to go.
ka-titties is offline   Reply With Quote
The Following User Says Thank You to ka-titties For This Useful Post:
zeal86 (07-26-2017)
Old 07-26-2017, 03:40 PM   #859
zeal86
zeal86's Avatar
Drives:
Devcon sanded down...
Old 07-26-2017, 08:50 PM   #860
zeal86
zeal86's Avatar
Drives:
Ok... so while filing a small revision to my design the Devcon cracked and one corner opened up. Since this is only a prototype, I reinforced the corners with some angled brackets.
Old 07-27-2017, 11:37 PM   #861
zeal86
zeal86's Avatar
Drives:
Started a third prototype... I corrected some things I figured out through trial and error and added a cut out of the throttle body shape.
Old 07-28-2017, 11:47 PM   #862
zeal86
zeal86's Avatar
Drives:
I completed and test fit my third prototype. I just need to fill in the seams with Devcon aluminum putty then sand smooth. I will have this version painted either Beatrush gold or chrome (which will probably look more like polished aluminum) ... I will probably use this version until my final is complete then I will sell it.
Btw, 2024 aluminum is considered unweldable and the Devcon withstands heat up to around 250°F so polishing and powder coating aren't options.... that's why I'll paint these versions. My final version will be made out of 6061 T6 aluminum which is weldable.... I plan on polishing the final version.
**Top hardware is temporary. Final hardware will most likely be a counter sunk hex head.**
Old 07-29-2017, 01:20 AM   #863
zeal86
zeal86's Avatar
Drives:
Found some left over hardware from my ZSpec kit... and installed them on the ECU and back of my prototype manifold cover.
Old 07-30-2017, 02:48 AM   #864
zeal86
zeal86's Avatar
Drives:
Picture overload....
Saturday Hangar Shoot...
The Following 7 Users Say Thank You to zeal86 For This Useful Post:
carsebuco (07-30-2017), Clipdat (08-01-2017), FRS_PR (07-30-2017), Guff (07-30-2017), ichitaka05 (07-31-2017), jubella2 (08-02-2017), wolffbite (07-30-2017)
Old 07-30-2017, 01:51 PM   #865
zeal86
zeal86's Avatar
Drives:
I really like these gritty pics...
Old 08-01-2017, 05:42 PM   #866
zeal86
zeal86's Avatar
Drives:
Grainy as f#@% but it has substance...
Old 08-01-2017, 07:03 PM   #867
zeal86
zeal86's Avatar
Drives:
Here is a shot of my Uras driver side sideskirt. Look closely and you'll see the Uras logo and a plane.
Old 08-01-2017, 11:43 PM   #868
zeal86
zeal86's Avatar
Drives:
Here is a video of my third Red Intake Manifold Cover Prototype . I've decided to polish it first...if the Devcon I used to fill the gaps doesn't look good after I polish it, I'll have it painted. It will serve as my temp until I complete my final version. Afterwards I plan on selling it if anyone is interested.
The following pics in the link above are pre Devcon but illustrate the fitment of this third prototype. The temporary top hardware will change to a countersunk hex head bolt.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 08:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 07:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
