| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 | |
Badass Member
Drives: 2014 SWP BRZ Limited
Thanks! Do you have pictures? Your TRD Sensor plate would be the first one on the stack right? I dont plan to add the pressure sender in the sandwich plate. Just temperature so I have a different method of monitoring. I do just realize now that I need to make sure I am reading temperature before it goes to the cooler. Or I will probably read higher temp when it is really 10 to 20C cooler going back to the engine. |
#16 | |
Drives: 2015 FR-S Release Series 1.0
#17 |
Badass Member
#18 |
Yeah, the TRD provides sufficient clearance for a sandwich plate without the need for the stacking plate. I left it on cause I didn't want to buy a whole new plate and new fittings, and also the extra height gives better clearance for the hoses with the Vortech airbox.
#19 |
Drives: 2016 Halo FRS
This is how mine is setup as well, with 1/8 p/t defi sensor
#20 | |
#21 | |
Drives: DGM BRZ
I have no idea how accurate it is below that. I'm guessing within 10F? My roommate stuck his inside the oil drain pan, which I think is supposed to be the most accurate of doing it? |
#22 | ||
Drives: World Rally Blue BRZ
Am currently using the Perrin oil cooler. |
| Stacking Up: 2016 WRX STI and BRZ [Canada] | JPxM0Dz | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 04-29-2016 11:05 AM |
| WTB Oil Sandwich Plates for turbo lines. | els7x5 | Want-To-Buy Requests | 3 | 12-04-2015 11:54 PM |
| Sandwich plate - oil temp reading "accuracy" | 1Cor10:23 | Engine, Exhaust, Transmission | 3 | 04-08-2015 01:36 AM |
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 05:47 PM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-29-2013 11:50 PM |
