Drives: 2013 Scion FRS
Which problem parts should be replaced while engine is out of the car?
My engine developed a bad knock so it's coming out. Don't know if it's getting repaired or replaced with another oem engine yet but my question is are there known issues that should be addressed while the engine is out of the car? I know older Subaru engines had issues with head gaskets and water pumps, is that still and issue with the FA20? Any other recommendations on how to take advantage of the engine being out of the car?
Thanks |
#2 |
Remove and thoroughly clean clutch fork, throwout bearing, and transmission front cover.
If there are signs of wear on the front cover, replace both it and the throwout bearing. Reassemble, ensuring all pivoting and sliding joints are properly lubricated.
#3 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#4 | ||
Good call, my throwout bearing is definitely messed up and the clutch fork squeaks like crazy |
| The Following User Says Thank You to Asus For This Useful Post: | Turdinator (07-30-2017) |
#5 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
I say the cam plate, easy if the motor is out.
#6 | ||
Because compromise ®
Drives: Red Herring
http://www.ft86club.com/forums/showt...highlight=fork Unfortunately many pics have been deleted by Photofuckit but some pics are here: http://www.ft86speedfactory.com/velo...2013-ft86.html http://www.ft86speedfactory.com/velo...2013-ft86.html
#7 |
Only happy when it rains.
Drives: series.blue
lots of other transmission parts can go in too, the mtec springs maybe stronger mounts if you are interested, etc.
#9 |
Drives: 2017 manual BRZ
Rods.
Sent from my Pixel XL using Tapatalk |
| The Following User Says Thank You to Somerandom18 For This Useful Post: | Cole (07-31-2017) |
#10 | |
#11 | |
FI, track it, DD .....other ......?? humfrz |
#12 | |
Drives: Red Herring
*I don't mean that literally but the Velox fork (and knife and spoon if they're available) is my list of things to do when the clutch needs replacing.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Ultramaroon (07-31-2017) |
#13 |
Drives: Scion FR-S | 6MT | Ultramarine
Anyone have the subaru part number for that transmission front cover (snout)? I might get it while I'm replacing the TOB and clutch fork anyways.
#14 | |
| Replaced transmission fluid, now it's causing problem | frslee | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 37 | 11-02-2016 05:35 PM |
| Buying BRZ with replaced engine | PSim | Engine, Exhaust, Transmission | 14 | 10-21-2016 03:06 PM |
| Reliability of engine with short block replaced | ShadowTS | Issues | Warranty | Recalls / TSB | 4 | 08-22-2014 11:49 PM |
| What do you do with the stock parts you've replaced? | qtwre | Engine, Exhaust, Transmission | 23 | 05-11-2014 02:52 PM |
| Low Idle/Cam gear - Anyone request to inspect your old/replaced parts? | ahausheer | Issues | Warranty | Recalls / TSB | 7 | 08-26-2012 03:31 PM |
