Old 07-15-2017, 12:57 PM   #15
I see where ol @Tcoat cleaned that one up back in post #2 ......
Old 07-28-2017, 10:33 AM   #16
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
I have this issue, and this morning after getting my morning coffee, went to start the car...
As soon as I reset the power (have a battery disconnect switch and never had problems with it or power going off while driving - which would be a bad thing), everything came back to life. Got back in the car, it's like as if I tried to start the car but without the clutch depressed. I'm starting to wonder if there's a relay that's acting up....
Mike
tanner is offline   Reply With Quote
Old 07-28-2017, 11:15 AM   #17
Where in the system is the disconnect switch wired? There are many components that are designed to be powered all the time and it may be messing with them now for some reason. Nothing was changed?
Old 07-28-2017, 11:42 AM   #18
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Originally Posted by Gray Fox View Post
Thanks for the suggestions, guys. I ended up removing the starter and took it to get tested, and it turned out to be good as well, which really surprised me. Starter itself looked pretty dirty, so I checked the cables that connected to the starter, and they were incredibly dirty as well; turned out to be the source of the issue! Cleaned them really well and she starts up just fine now, no hesitation whatsoever. Super happy I saved money on parts thanks to you guys
Just a heads up, while they are clean, it's a good time to disassemble the connections to the starter and battery, and put a light coating of dielectric grease anywhere the connections COULD get dirty or corroded in the future.
I had a similar issue with my 2005 FXT, and found a few connections that were beginning to fail from age/heat/mileage. I built a new charge and ground harness from scratch with beefy 4awg wire, crimped, soldered, and heat shrunk connections, and dielectric greased every contact point. Terminals look perfect still.
JazzleSAURUS is offline   Reply With Quote
The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post:
Gray Fox (10-09-2017), Tcoat (07-28-2017)
Old 07-28-2017, 12:01 PM   #19
tanner
It's a "big green knob" as they call it.
https://www.amazon.com/Battery-Termi.../dp/B00B2ATRGK
And yes, before I untightened it to disconnect and tightened to reconnect the power, the thing was on tight. Absolutely no corrosion on the battery terminals.
Mike
The Following User Says Thank You to tanner For This Useful Post:
Tcoat (07-28-2017)
Old 07-28-2017, 12:11 PM   #20
HMMMM that certainly should not be it then. Maybe the clutch switch itself? There have been a few reports of issues with them but usually something on the car had been changed that was the root cause.
Old 07-28-2017, 12:30 PM   #21
tanner
If the clutch switch was not working I wouldn't hear that noticeable click when the engine doesn't start, so believe the clutch switch is okay.
I'm suspecting the starter relay, will be calling up the dealer to see if they have that part and just replace if it and see if the "click only" start behaviour disappears.
Mike
Old 07-28-2017, 12:33 PM   #22
True. There would be nothing. You did check the wire connections at the starter like this thread's original outcome was right? (Not being insulting just clarifying)
Old 07-28-2017, 12:54 PM   #23
tanner
Plan to when I have time to troubleshoot further.
I just found it odd that there was absolutely no power to the entire car so one thing for sure, it would be a problem that's above and beyond the starter.
Mike
Tcoat (07-28-2017)
Old 07-28-2017, 12:56 PM   #24
OH! I didn't catch there was no power at all. Then why replace the starter relay?
Old 07-28-2017, 02:39 PM   #25
tanner
Gotta start somewhere
Mike
Tcoat (07-28-2017)
Old 07-28-2017, 02:46 PM   #26
Start with the connections then move on to replacing parts. Replacing random parts to trouble shot is throwing money away.
BirdTRD (07-28-2017)
Old 07-28-2017, 03:12 PM   #27
....... pay attention.....
If the car has no power ....... either the battery has no electrons ...... or something is not letting them out of the battery.
So, there be your starting point(s) .......
Old 07-28-2017, 06:34 PM   #28
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Sometimes snow birds down here use those. They are junk. They can look great, no corrosion and still not work. Knife switches are the same.
That said if you have power that's not it. Sometimes I go to start my car and it acts like the clutch isn't pushed in and won't start. I have to adjust that switch. To get it to start when that happens I have to stomp the clutch like I'm pushing it through the floor.
guybo is offline   Reply With Quote
Car doesn't start without fully charged battery. frsq5 Issues | Warranty | Recalls / TSB 6 06-09-2017 10:59 PM
Key battery dies, anyway to start firs manually. cfee40 Electronics | Audio | NAV | Infotainment 11 05-21-2017 12:31 PM
Losing all battery voltage when trying to start car. armstrom Issues | Warranty | Recalls / TSB 14 11-18-2016 04:15 AM
Car WON'T START dead battery? AnthonyArcaro Issues | Warranty | Recalls / TSB 17 01-19-2016 01:00 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
